will only go into 4x4 at very slow speeds
All Forums >> [OEM Discussions] >> Kawasaki >> will only go into 4x4 at very slow speeds Page: [1]
will only go into 4x4 at very slow speeds - 10/4/2008 7:44:51 PM
steveo3318
it will go into 4x4 no prob, it just stopped doing it at any speed, now you have to almost let the wheels stop turning for it to engage, it will not just kick in at any speed like it use to.  Any ideas on what i could do to help this.  no flashing or anything just have to almost stop.
08 Brute Force 750
NRA fuel injected
2" SS lift
HL lift springs
Black HMF Utility exhaust
HMF optimizer
29.5" Outlaws on 112 SS ITP
WARN 2500 winch
UNI air filter
RED secondary clutch spring
ASR X series tie rods
Moose bushings
snorkel MIMB
1992 honda 300 4x4
26 outlaws and clean
hunting bike
RE: will only go into 4x4 at very slow speeds - 10/4/2008 8:28:25 PM
clemzexp6969
probably a good thing, putting the brutes in 4x4 in any speed isnt good
2006 Brute force 750I
27" MST'S
**** Winch 3000lb
Moose module
Savant a arm guards
Audiopipe
Strobes
Billet Shift Knob
Led's
(in reply to steveo3318)
RE: will only go into 4x4 at very slow speeds - 10/4/2008 8:31:54 PM
bushhog750
mine was the same way brand new then it got slower and slower but never failed to engage.
08 outlander 800 red- MaD Cannon tuned- snorkled- vented- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- 6orilla radiator relocate- ricochet skid plates- xt front bumper- coolanol radiator fluid- crankcase vent mod- amsoil fluids- sponsored by VISA and 60 hours a week.
(in reply to clemzexp6969)
RE: will only go into 4x4 at very slow speeds - 10/4/2008 9:07:37 PM
phreebsd
i think it wont do anything at all over 15.. it says that in the manual of my p360 so i think they have the same logic on the brute..
2008 Kawasaki Brute Force 750
Outlaws - 27x9.5 F, 27x12 R
1" Spacers
HL 2" Lift
Lime Green Secondary
M.I.M.B Snorkles
Viper Max 4000 with Amsteel Blue synthetic
2007 Kawasaki Prairie 360
Mudbugs - 26x10 F, 26x12 R
Twin Air filter
Viper 3000lb winch
Visit the MudInMyBlood Forum
(in reply to bushhog750)
RE: will only go into 4x4 at very slow speeds - 10/5/2008 8:36:10 AM
steveo3318
ok sounds good, it still works fine just have to almost stop. just wondering.  thanks guys
08 Brute Force 750
NRA fuel injected
2" SS lift
HL lift springs
HMF optimizer
WARN 2500 winch
UNI air filter
Moose bushings
snorkel MIMB
1992 honda 300 4x4
hunting bike
(in reply to phreebsd)
RE: will only go into 4x4 at very slow speeds - 10/5/2008 9:06:55 AM
speedy81304
my 05 p700 wont click in unless im moving around 5mph. if i stop and switch it in, it wont click in untill i start moving, over time things start to wear in and the actuators get worn in and the res. goes up witch changes the speed of things. nothing to worry about yet. worrie when it dont click over over to 4wd and there no flashing on the dash.
2004 KVF700 4x4. Adventure quad. built to go wear i wont to and not look back.
Making mine better then yours is worth the money well spent.
RE: will only go into 4x4 at very slow speeds - 10/5/2008 10:26:23 AM
BRUTE750ii
i stop fully, when i engage 4 wheel, and when i go from 4 wheel-2 wheel
PINNEN AINT EASY....
2008 BRUTE 750
2500 WARN WINCH
27' OUTLAW MST'S
RICOCHET SKIDS
(in reply to speedy81304)
RE: will only go into 4x4 at very slow speeds - 10/5/2008 10:56:05 AM
GoatManx
I never stop... just flip the switch when i see that i need it and when i'm done un flip it... as long as the front and rear tires are turning at the same speeds you cannot hurt anything.
Brute Force 840 V-Twin
(in reply to BRUTE750ii)
RE: will only go into 4x4 at very slow speeds - 10/5/2008 12:02:10 PM
steveo3318
come to think of it that may of been my problem goat,  i was in some really deep water cleaning it off underneath and the rear wheels was spinning fast but front not at all due to wheelies in the water,  may be a safety feature.  it seemed to do fine on land
08 Brute Force 750
NRA fuel injected
2" SS lift
HL lift springs
HMF optimizer
WARN 2500 winch
UNI air filter
Moose bushings
snorkel MIMB
1992 honda 300 4x4
hunting bike
(in reply to GoatManx)
RE: will only go into 4x4 at very slow speeds - 10/5/2008 1:03:04 PM
GoatManx
It will be hard for it to engage in 4wd in water if the front tires don't have a load... When it engages the front end it will throw the front tires foward which will in turn make it dis-engage and then try and re-engage and vice versa. They have to spin at the same speed so the collar can line up right in the front diff.
RE: will only go into 4x4 at very slow speeds - 10/5/2008 1:52:04 PM
bushhog750
being in water is tatally different steveo. i ride alot of sandy rivers and stuff and if the rear tires bury up i have to stop spinning the rear flip the switch then let it engage goatmanx is right no load it will be harder.
RE: will only go into 4x4 at very slow speeds - 10/5/2008 2:17:39 PM
steveo3318
sounds good thanks guys. always a ton of help on here
08 Brute Force 750
NRA fuel injected
2" SS lift
HL lift springs
HMF optimizer
WARN 2500 winch
UNI air filter
Moose bushings
snorkel MIMB
1992 honda 300 4x4
hunting bike
0.453
