will not start
will not start
All Forums >> [Most Popular Discussions] >> Tech Questions >> will not start Page: [1]
will not start - 11/10/2008 6:33:29 PM
yard_dawg
i posted this in the Polaris section but not really much help. got a 97 sportsman 500. been cranking fine,it even has a new battery. wanted to ride this past weekend, went to load it up and all it would do is make a clicking sound from the syliond. was wondering if there is anyway to check it see if it is the slyniod or the starter. thanks.
RE: will not start - 11/11/2008 5:41:55 AM
Honda Mechanic
Put a volt meter on the power post for the starter (red ( + ) to the starter post negative ( - ) to a good ground  , then turn on the ignition & pust the starter button , when the solinoid clicks does the starter have 12v (battery voltage) ..
(in reply to yard_dawg)
RE: will not start - 11/11/2008 6:09:47 AM
yard_dawg
will give this a try. thanks
(in reply to Honda Mechanic)
RE: will not start - 11/13/2008 2:25:52 PM
grizzlyadams
Did you first check the volts at the battery to make sure it was good?
2008 grizzly 700
26in mud lights
fix power clutch kit (with updated kit)
custom exhaust
powermadd hand guards
symtec hand warmers
moose rear box
2002 big bear 400
rebuilt engine hp piston
clutch kit
135cc wheeler for the kid
RE: will not start - 11/13/2008 5:58:57 PM
yard_dawg
brand new batterie
(in reply to grizzlyadams)
RE: will not start - 11/13/2008 8:50:53 PM
Dezz
Just because a battery is NEW does not mean it is good.
Don't forget to check your battery terminals to security and tightness. Since you replaced the battery, maybe you never tightened the terminals tight enough and now they have worked loose and won't turn over the starter. The lights may come on and everything, but as soon as you place a big electrical load (like the starter) it can fail and make the solenoid click. It might even just die and do nothing. Every cirumstance is different.
If that seems ok, then follow the instruction mentioned above on testing the soleniod.
If all that fails, then come back and let us know. We'll point you in another direction of troubleshooting.
Dezz
1998 Grizzly 600
ITP Delta Black Chrome Rims
Uni Air Filter
Warn A2000 Winch
Detroit Gearless Locker
Oxlite CV joint protectors
