mm800
Um, thats a big negative on the spacers on the rear with deepdish rims. Im at 53" all the way around as it sits right now, thats wider than some people like. Back to the original question, you should be fine without spacers. If you go taller you may need them because the bulge in the sidewall will be higher which could cause it to rub the tie rod end, if that makes any sense.
05 Sportsman 800 29.5 Outlaws 10s & 12s, Deepdish Torks, Aaen Exhaust, K&N Filter, 3000# Warn Winch, Gor!lla Prop-Shaft, HL Rear Springs, Ranger Front Springs, RD Bar Ends, RD Rear Lift, El-Cheapo Front Lift, Heel Clicker Clutch Kit, Turners Up Front
