will a 2002 250EX motor fit on a 2003 Recon?
All Forums >> [OEM Discussions] >> Honda >> will a 2002 250EX motor fit on a 2003 Recon? Page: [1]
will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 2:53:24 PM
TRX300man
I didn't know if they would interchange. I think the 250ex is autoclutch on a sport frame? Correct me if I am wrong.
Member of Harlan County Ridge Runners and Bell County Holler Crawlers
http://www.flickr.com/photos/trx300man
www.ridgerunnernation.com
www.hollercrawlers.com
2000 Honda Foreman 400
1988 Honda 300 2 wheel drive.
God does not believe in atheists!
Your getting hurt not wearing a helmet contributes to ME losing MY riding area!
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 4:22:21 PM
jrafter
it should the motors are the same
400ex
yoshi full pipe
amr coil and curtis sparks revbox
k&n airfilter
tcs front shocks
420 rancher
itp mudlites on the front
kenda executioners on the rear
power commander
heated grips and thumb
1.5 xt warn winch
custom snorkel
2 12v sockets
HMF pipe
uni filter
temp gauge
gettoblaster
lots of mud
04 roadking
IT AINT ROCKET SCIENCE
http://s262.photobucket.com/albums/ii111/moondog8u/?speci
(in reply to TRX300man)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 6:58:40 PM
jeepthing07
are they both chain drive?
07 Suzuki Vinson
02 Honda 426ex
(in reply to jrafter)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 7:22:11 PM
BRASSO11
recons are shaft drivin
(in reply to jeepthing07)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 7:38:30 PM
jrafter
250ex is shaftdrive to
400ex
yoshi full pipe
k&n airfilter
tcs front shocks
420 rancher
power commander
1.5 xt warn winch
custom snorkel
2 12v sockets
HMF pipe
uni filter
temp gauge
gettoblaster
lots of mud
04 roadking
(in reply to BRASSO11)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 7:51:36 PM
BRASSO11
ah crap i forgot about that.. my bad
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 9:03:43 PM
buzz007
They are the same engines both are shaft driven and both have the same rear end.
2006 foreman 500 es
HMF SWAMP SERIES
G--RILLER Axles
28" Mud Bugs on Vision wheels
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
Ricochet skids
"W / TUNES "
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/22/2008 10:12:22 PM
ragginrancher2008
do both have the same power too?? not much of an upgrade imo
Arthur Lewis
2004 Honda Rancher 350 4x4
Jet Kit
K&N
2in lift
HMF
26in Vamps
http://www.teamackrite.net/
(in reply to buzz007)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/23/2008 7:58:57 AM
ARK_SWAMP_RIDER
250ex is quite a bit faster than the Recon. I'm not sure if it's just a difference in weight, maybe a gearing thing (although it was said they have the same rear). I had a 01 Recon, friend had a 250ex (not sure what year, this was no later than 2003, so would have been early 2000's). He'd smoke me in a race every time. I'd be pegged out on the highway, he'd be able to fly by me. Both were stock. There is more there, not sure exactly what, but there is a difference (may just be weight).
2005 Honda Foreman 500 S 4x4 with 4 26x12x12 bear claws on itp c series type 6
93 Honda 300 4x4-Mostly stock
90 GMC-6" superlift, 315 buckshot mudders (sold)
96 Ford Mustang Mystic Cobra
My Pics
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/23/2008 10:51:36 AM
outlanderrider
"Although the engine has been pilfered off the Recon, a few performance features have been incorporated to deliver on the sporty side of the 250EX. A new two-valve cylinder head design features performance-optimized valve timing. A 31.5-mm diameter intake valve (1-mm larger than the Recon's) and a 27-mm diameter exhaust valve produce a broader usable powerband. Also new is the 55-degree intake valve angle as compared to the Recon's parallel intake valves. The 1-mm larger intake valve and more efficient angle give the 250EX 10% more power than the Recon. The new cylinder head gives it a slightly higher 9.2:1 compression ratio as compared to the Recon's 9.0:1 The power increase is matched to a new set of higher gear ratios that give the 250EX a more "sporty" feel than the utility-oriented Recon."
From http://atvconnection.com/Features/ATV_Reviews/2000-Honda-250ex-review.cfm
2007 Can-Am Outlander 400 H.O. Max Xt
BRP Mirror
T-M-2 Front pre-load adjusters
BRP Rack Extension
RCM Shift Knob
BRP Fender Flares
2001 Honda Rancher 350
ITP Blackwaters
PowerMadd Handguards
Moose Precision Filter
(in reply to ARK_SWAMP_RIDER)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/23/2008 3:12:51 PM
ragginrancher2008
ORIGINAL: outlanderrider
so if you bought all these parts for a recon 250 head, you would basically have a 250ex motor??
Arthur Lewis
Jet Kit
K&N
2in lift
HMF
26in Vamps
(in reply to outlanderrider)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/24/2008 10:36:47 AM
TRX300man
OK, thanks everyone. I have been looking for a Recon motor for a while, now I can look for a 250 EX motor as well.
(in reply to ragginrancher2008)
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/24/2008 11:33:19 AM
ARK_SWAMP_RIDER
One thing I do know is that the exhaust from a 250ex will not fit the Recon without modifying the brackets. Not sure about how the actual pipe goes into the motor, but that may be a problem you encounter with the ex motor.
My Pics
honda4trax.com
RE: will a 2002 250EX motor fit on a 2003 Recon? - 11/24/2008 5:18:34 PM
squirrel500
Well if you find 2 motors that are good. Ill take 1 of them.  Been looking for a motor for over a year now.
2006 A/C 500m
26" 589s
2" rear lift
That all I will say on line
Hard Pack Arctic Cats
It all seems HardPack when you ride a CAT
2002 Honda recon 22" swampwitch
FMF ext
snorkel K/N
08 366 lime green with 26s 26s too big went back to 24" Why did A/C put 3.1 in the new quads?
THANK YOU STEEL HORSE. YOU KNOW WANT YAL DID. KEEP UP THE GOOD WORK
