Xplorer470
i bet the sp 500 would stand up easy with mud lites...heel clicker clutch, high comp. piston, 38 mm flatside carb, aaen exhaust, with everything fully snorkeled, believe it or not it felt like that bike gained a good bit of power when i snorkeled it.
96 Xplorer 400.AAEN 470 bbk,44mm carb,14:1 compression,aluminum head,roller clutch,6"lift.31"laws, axle paddles.80-85 hp at the fly =) 03 sp 700.800 bbk,6"lift,32" sbacks,stage 3 motor work,gear reduction,pinned crank,cam,42mm carb, 12:1 pistons
