what should i get next?
All Forums >> [OEM Discussions] >> Kawasaki >> what should i get next? Page: [1]
what should i get next? - 8/25/2008 10:42:04 AM
xtrem4x4
Its a 2002 kawasaki prairie 650 its completly stock except for it has gator tires and it has a K-N airfilter what should I get to get the best bang for my buck i have about $400 to put into it right now?
Thumbnail Image
Attachment (1)
RE: what should i get next? - 8/25/2008 11:22:44 AM
jakedogg
Dnyatek - $174 on Ebay
or VDI - $400
That'll wake it up quite a bit, and it's a good start.
Brute Force 650 (SRA)
27" Laws
Fully Snorkeled
Relocated Radiator
Dyna CDI
2" Lift
Custom Skids
Water Temp Gauge
Big Gun Exhaust
(in reply to xtrem4x4)
RE: what should i get next? - 8/25/2008 1:06:27 PM
dirtdiggler25
SNORKELS!!!!  They are cheap and very useful if you ever plan on getting with in 10ft of water or mud hole.
08 TEAM GREEN Brute
853 Big Bore (Xtreme Racing)
Hot Cams
Custom Center Snorkels
Power Commander III
HMF Exhaust
28" S!lverbacks
ITP SS212 Wheels
EPI Xtreme Clutch Kit
Highlifter 2" Lift
03 450 Forman S (SOLD)
Custom Sorkel
Dynojet Jet Kit
K&N Air Filter w/Outerwear Prefilter
2" Bracket Lift
28" ITP 589's
ITP Chrome Bullet Holes
www.myspace.com/godfrey25
(in reply to jakedogg)
RE: what should i get next? - 8/25/2008 1:11:30 PM
James Chapman
dynatek and a pipe and filter..and snorkle the beast
Support our Military and their mission
00 Dakota 4wd
BFG A/T's
Cherry Bomb
She's fast . She's real fast.
Past bike 08 brute
(in reply to dirtdiggler25)
RE: what should i get next? - 8/25/2008 1:37:53 PM
JKPFORCE07
clutch kit if u decide to run in mud and are going to be puttin on some bigga tires
2007 BRUTE FORCE 750
1994 HONDA 300
(in reply to James Chapman)
RE: what should i get next? - 8/25/2008 3:47:04 PM
xtrem4x4
So what does the dynatek do to help me?
(in reply to JKPFORCE07)
RE: what should i get next? - 8/25/2008 4:13:13 PM
xtrem4x4
what does the dynatek do???
RE: what should i get next? - 8/25/2008 4:33:39 PM
jksimpson
dynatek and exhaust if you  play your cards right you can find both for under 400 and build your own snorkels is cheap under 50 bucks for sure
750brute force
RE: what should i get next? - 8/25/2008 10:53:10 PM
xtrem4x4
whats a good size lift for these things like a 2?
(in reply to jksimpson)
RE: what should i get next? - 8/26/2008 9:24:33 AM
dirtdiggler25
2" is about the biggest lift you can put on them with out buying new axles.
08 TEAM GREEN Brute
Hot Cams
Power Commander III
HMF Exhaust
28" S!lverbacks
ITP SS212 Wheels
Highlifter 2" Lift
Custom Sorkel
Dynojet Jet Kit
2" Bracket Lift
28" ITP 589's
RE: what should i get next? - 8/26/2008 9:56:22 AM
xtrem4x4
would you recomend the lift or leave it?
RE: what should i get next? - 8/26/2008 9:57:52 AM
devildog12210
You can never have too much ground clearence. IMO
RE: what should i get next? - 8/26/2008 11:17:49 AM
xtrem4x4
alright so spending $95 is good for a 1.5 to 2 inch lift?
(in reply to devildog12210)
RE: what should i get next? - 8/26/2008 2:37:46 PM
08bruteforce31
the dynetek will give you 6 hp on low end 4 through the mid range and 2 on top end hmf and jet kit together will be around the same #s but these are the quickest and easiest ways without extensive mtr work to gain hp later when you find out that is still not enough you may try some wegg 150i cams this will wake that baby up big time
mine 08 camo 750 brute 12 maxxis 29.5skinnieslaws 1" spacers 2" highlifter lift, epi extreme clutch kit, optimizer, hmf, 2" center,snorkels, 2500lb winch for all the places i thought i could go
Hers 05 camo 750 brute 12 itp 27" tri claws and bi claws 2" highlifter lift, hmf, dyno jet kit, 2" center snorkel, 2500lb winch dyan tek cdi
06 360 prarie 4X4 28 " edl on black itp snorkel oil cooler relo camo 2500lb winch
07 slammed whiteavalanche on 22" vct custom boxwith pair of t1 12"subsandpun
RE: what should i get next? - 8/26/2008 2:53:54 PM
PUDDLE JUMPER
you can find used 2 inch lifts for these bikes for under $50 all the time
SUNBEAM RED LE TERYX!
28" bugs "YOU AINT STUCK TILL YA RUN OUT OF GAS"
msa-nukes
audiopipe
snorks
dyna
jet kit
xpatv lift
clutch mod
k&N billet intake
night owl hids
http://www.teryxforums.net
http://www.teryxhq.com
(in reply to 08bruteforce31)
RE: what should i get next? - 8/26/2008 9:27:42 PM
xtrem4x4
where can i find one for that does anyone hove one on here?
(in reply to PUDDLE JUMPER)
RE: what should i get next? - 8/26/2008 10:58:30 PM
xtrem4x4
bump
2002 kawasaki prairie 650!!for sale or trade pm if intrested!!
2000 yamaha blaster 200!!
RE: what should i get next? - 8/27/2008 1:20:27 AM
bruticus
might try ebay also...........that is where i got my dynatek also........Bruticus
06 Silver Brute
Wiseco High comp pistons
Custom Port and Polish Job
Hotcams
SSATV 2 Inch Lift
29.5 outlaws on Stock grizzly rims
MIMBS' LRD TORC slip on
Dynatek
Dyno Jet Kit
Worst Mad Kaw disease
Strobing in Headlights!
Crazy,Stupid Driver!!
MIMB Snorkels
Things in progress......
Rack Radiator Mount
RE: what should i get next? - 8/27/2008 12:33:37 PM
xtrem4x4
alright thanks guys?
(in reply to bruticus)
0.750
