what do i do to get a broken bolt removed
All Forums >> [Most Popular Discussions] >> Tech Questions >> what do i do to get a broken bolt removed Page: [1]
what do i do to get a broken bolt removed - 7/23/2008 11:01:19 PM
polarismaster800
i have a sportsman 800 and i noticed the tire wobling then i realised the rear swing arm bolt had completly broken off and i could easily replace it but the old one is broken off and half way into the treads i can't reach it to turn it with vice grips is there any way to drill it out or something    please help.
Proud owner of:
Trailblazer 250
Honda cr 80
Yamaha ttr 90
Sportsman 800
ITP Mudlight XTR---Heated Grips---Stick Stopper Axel Protecters---Front and Rear Bumpers---K&N Air Filter---Hardened Front Suspension---60" Glacier Plow---Warn 2500 Winch---3 Gallon Spare Fuel Tank Mounted on Font Rack---Polaris Rear Storage Box
RE: what do i do to get a broken bolt removed - 7/23/2008 11:27:49 PM
croc_j2001
yup thats easy enough. just get a bolt extractor or "easy out" and drill a hole in the middle of the bolt, pound in your easy out and presto.  should be able to get an easy out at any hardware or tool store.
2008 Honda Foreman 500
Power Steering
27x12x12 Outlaws
2 inch lift
Supertrapp pipe IDSX (junk)
Heated Handlebars
Itp Rims
Skid Plates
Jet Kit
Waterproof Stereo
Mod's To Come
Gear Reduction
Lockers
Snorkel
Better Shocks
Louder Pipe (mine is too quiet)
(in reply to polarismaster800)
RE: what do i do to get a broken bolt removed - 7/24/2008 12:10:10 AM
bansheefan03
and if its not rusted up in it lots of times u can just use a reverse drill bit and it will pull it out
2006 rhino 660
29.5 swamplites
lift
rear steer
snorkled
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ ****s ,axle paddle,102 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler
(in reply to croc_j2001)
RE: what do i do to get a broken bolt removed - 7/24/2008 8:06:06 AM
OldSchool
The bolt you are talking about is Grade 8, so expect it to be difficult to drill through.  The bolt extractors work awesome, just dont force it - remember easy does it.  If you break the tip off inside the bolt you are going to have a REAL fun time trying to drill that out!
1997 Polaris SP 500
2" Lift
1.5 spacers
28x10 Laws
2003 Polaris 500 HO Sportsman
CAMO
1" Lift
27x9.5 Laws
(in reply to bansheefan03)
RE: what do i do to get a broken bolt removed - 7/24/2008 12:35:03 PM
J_Fred
Exact same thing happened on my 500 SP.  These guys have the right advice, took me about 5 minutes once I had the parts off and the right tools.  Easy fix.
2001 Polaris 500 H.O.
K&N, 27x12 Vamp rear /American EDL fronts
Gone -- AC 500m
28x12 Mudzillas, Snorked, G*rillas all around
SOLD
2001 Honda Rubicon - Lift, 27x12 Vamps, snorkels, the works.
www.myspace.com/joshfrederick
(in reply to OldSchool)
RE: what do i do to get a broken bolt removed - 7/28/2008 4:13:39 AM
thetubster
try a backwards drill bit like said above i have had to use that trick
2002 Red Rancher 4x4
27x12x12 laws
375 big bore kit
web cam
clutch kit
itp c series
2 inch spacers
highlifter lift springs
2 inch lift
HL front bash plate
diamond plate stick stoppers
moose floorboards
custom snorkel
shaved fenders
fmf megamax exhaust
k&n air filter
k&n jet kit
oil cooler on front rack
strobes
MY PICS:
http://photos.yahoo.com/arod12342000
(in reply to J_Fred)
0.250
