chevy68
well this is very interesting, Camlaw i am in the same shoes as you. i have a 2007 wolverine 450 with pretty close to the same milage as you. and have the exact same problem , slips big time on at low end, now i do have some mods done to mine, not sure about you but any info you can give would be great.. i have an epi clutch kit for big tires, hmf pipe , jet kit , and k an n air filter, so a bit more power. i have been phoning everyone with any clutch knowlage i can trying to figure out what caused this premature wear. i have to replace my whole unit including all the bearings as it was making one **** of a noise in there, i thought i had a conecting rod bearing out forsure... i sent my sheave off to hauck machine works today to have my primary machined to gain top and bottom end , plan on using my stock wet clutch springs this time( some people think the epi ones were to stiff ) was your clutches wearing on one end way more than the other? mine was, i do not think it has been fullin engaging could be from the springs being to stiff. i am aslo trying to figure out if the rollers or weights are not correct size.... all i know is i do not want to replacing 500 bucks worth of wet clutches every year... that is brutal.....
07 Wolverine hmf pipe Jet Kit K&N Filter 26" Zillas with ss108 Detroit gearless locker Epi clutchkit 2500lb warn winch powermad hand guards heated grips
