REBELRIDER
ORIGINAL: green700efi alrighty ill try to find something to plug the weep hole when i get the new seal put in DO NOT DO THIS! The weep hole is there, so that when the seal goes bad, the coolant has somewhere to go. If its plugged and the oil seal (behind the coolant seal) goes bad, you WILL milk your oil with coolant.
07' Polaris 700 29 Outlaws AAEN Snorkt' Through The Tunes Visions Keystone Light
