sscard
just pull the head, if you drop a valve which you most likely will do your gonna have to pull it anyway its a cheap job but time consuming, ive never done a 450 but have the 660s, it would take me about 2 hours to get it done remove valve cover, then rockers then cam, make sure not to drop the cam chain, then head make sure and order a new head gasket as well you need to inspect the bottom of the head to see if in fact you have a leaking valve seal
04 Grizzly 660 camo Snokl'd,Law'd,5.5 Primate Lift'd, and Rilla'd TRIPLE Flow HMF , HL Xtreme Clutch Kit,StrobesJTM custom stereo The Wifes 02 Rancher 350 4x4 ITP SS106, 26" Terra Cross, Warn 424, K&N Snorkl'd, Jett'd, Lift'd,and Pip'd Pink Dipped Plastics JTM Custom Dipped Stereo 4-6x9's
