trans. cooler on z71
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> trans. cooler on z71 Page: [1]
trans. cooler on z71 - 9/22/2008 5:59:59 PM
GRIZZMATIC
I have a 2003 gmc ext. cab sierra 1500 Z71.   Can anyone tell me how i can tell if it has a transmission cooler.  thanks
2008 grizzly 700fi camo
RE: trans. cooler on z71 - 9/22/2008 8:10:06 PM
gmcz71
I bet you do.
easiest way to tell is look thru your grille, and behind the bumper area... do you see a mini-radiator?
Also, if your truck has the factory towing package theres a very good chance you have a tranny cooler.
< Message edited by gmcz71 -- 9/22/2008 8:21:58 PM >
1998 Suzuki Quadrunner 500 -
A work in progress. Slowly being built.
USA EDL's for sale... http://www.highlifter.com/forum/28%22_USA_EDL's%25%25%25_checking_interest/m_3044302/tm.htm
2000 GMC Sierra Z71 - 5.3 - ecsb
- Cherrybomb Extreme
- Blackbear 87oct tune
- Vette servo's
My Pics...
http://s523.photobucket.com/albums/w358/tylerz71mud/[/cent
(in reply to GRIZZMATIC)
RE: trans. cooler on z71 - 9/22/2008 8:22:17 PM
GRIZZMATIC
yea behind the grill there is a small one about 5" tall and maybe a foot long.  I guess that is it.
(in reply to gmcz71)
RE: trans. cooler on z71 - 9/22/2008 8:28:01 PM
gmcz71
ORIGINAL: GRIZZMATIC
yep thats it.
If you plan to tow a lot / increase your power output, I suggest you beef up your 4L60E.
- Vette servo's
My Pics...
RE: trans. cooler on z71 - 9/23/2008 11:08:48 AM
GRIZZMATIC
what kind of upgrades would you suggest
RE: trans. cooler on z71 - 9/23/2008 12:53:37 PM
drake08
first i would pull out the 4l60e but thats just me i have had bad luck with them and put in a turbo 400 if u dont do that i would get a shift kit put in they make on just for towing for like 150 bucks
06 rubicon, 2'"hl lift,28" in laws hmf on the way, next jetkit and clutch kit
RE: trans. cooler on z71 - 9/23/2008 9:04:45 PM
nonnieselman
ORIGINAL: drake08
How about a 4L80E?
2005 Red Foreman 4x4 S
-Rubi Rims w/ 26" MST
2000 Silverado ECSB
LQ4 4L80E STS Nitrous
(in reply to drake08)
RE: trans. cooler on z71 - 9/23/2008 9:06:20 PM
nonnieselman
a corvette servo is a easy mod to do and its cheap.
2000 Silverado ECSB
RE: trans. cooler on z71 - 9/28/2008 10:14:14 PM
drake09
i would stick with a turbo 350 or 400 the are so much eaiser to work on and alot cheaper to repair if u do break something
2006 rubicon 2 in lift 28 outlaws and hmf on the way
(in reply to nonnieselman)
RE: trans. cooler on z71 - 9/28/2008 10:26:11 PM
JRICH
ORIGINAL: nonnieselman
Can you elaborate?
Sup.
RE: trans. cooler on z71 - 9/28/2008 10:34:06 PM
gmcz71
ORIGINAL: JRICH
Can you elaborate?
I couldnt tell you exactly, BUT:
nonnieselman installed Vette servos in my truck (2nd and 4th gears?) and now it shifts a bit firmer and is supposed to help "beef up" the tranny for the tune Im getting.
Along with a little tune he did, it really woke the truck up.
In tow/haul, when it shifts into 2nd it chirps the tires and kinda slings me back in the seat.  I like it.
- Vette servo's
My Pics...
(in reply to JRICH)
RE: trans. cooler on z71 - 9/28/2008 10:57:45 PM
drake09
iam guess you basicaly but a corvette shift pateren in it you should have just but a b/m shft kit in it would have improved in all gears but thats just my opinion
RE: trans. cooler on z71 - 10/1/2008 2:35:09 AM
nonnieselman
ORIGINAL: drake09
Gah.. whats a corvette shift pattern? its the same transmission except tail housing and servo..
Have you ever seen a 4L80E fail? this is a TH400 with overdrive just incase you didnt know.. also has a lil better parts in it..
Do you even know what your talkin about?
Corvette Servo gives the trans a lil more "clamping" force on the 2nd gear drum..
Depends on what you plan on using the truck for, but a Vette Servo and a tune will help the trans last longer and makes driving it a lil funner..
Also, can you explain why a TH350 and TH400 is better than a 4L60E and 4L80E?
Transgo HD-2 shift kits are better than the B&Ms.
2000 Silverado ECSB
(in reply to drake09)
RE: trans. cooler on z71 - 10/1/2008 2:38:40 AM
nonnieselman
ORIGINAL: drake08
Ive had to pull my built 4L60E 16 times and my last built 4L65E once... After that i put a 4L80E in it with the new Transgo HD-2 kit in it.. and it was $98.
Gear ratios are differnt from the 60E and 80E but the turbo loves a load.. also used the stock Torque Converter.
2000 Silverado ECSB
RE: trans. cooler on z71 - 10/1/2008 12:06:51 PM
drake09
i said that i hadnt had any good luck with 4l60e and rreplaced them with th350 and not had a problem imo there just a stronger trans i have never missed with a 4l80e just because the luck i have had with 60's
RE: trans. cooler on z71 - 10/1/2008 2:57:55 PM
nonnieselman
ORIGINAL: drake09
I know the feeling... ive had screwed up Torque converters, broken pumps, broken output shafts, Valve body gasket leaking... you name it..
A 4L80E in stock form can handle way more than a built to the gill 4L60E. Add a Transgo HD-2 and they should handle 800RWHP with easy..
2000 Silverado ECSB
