trailing arm
trailing arm
All Forums >> [OEM Discussions] >> Can-Am BRP >> trailing arm Page: [1]
trailing arm - 11/17/2008 6:53:02 PM
grizzlybear
after you get the nut off and there is a plate with a arrow on it how do you get the thing apart
05 grizz 28 laws 2' lift hl springs jet kit hmf hmf snorkled warn 2500 hl temp hl extreme cluch kit gorilla axles 08 rhino 28 laws "https://"[IMG]http://i301.photobucket.com/albums/nn67/grizzlybear_010/rhino005.jpg[/IMG]
RE: trailing arm - 11/17/2008 7:38:54 PM
cobwoy
you must take the snap ring off. the you have to have a spindle nut socket. there is a silver nut thing thats up in there a lil ways. its around 2" accross and it has 4 notches in it.... thats where the spindle nut socket comes in. can am makes the socket but getting one is another story. oreilys has a spindle nut socket that with a slight bit of grinding will fit in the swingarm
'07 outty 800, 6" CATVOS, 29.5 10s and 12 laws on torks, HMF & programmer, snorkel, ricochet skids custom bumper, radiator up high
2005 DODGE CTD
(in reply to grizzlybear)
RE: trailing arm - 11/17/2008 8:19:36 PM
kscowboy
NO NO i dont think he is that far yet. He is talking about the aluminum piece with the 2 tabes. They have a ton of locktite on them. Heat them up a little and then you might have to put one of the nuts back on and hit it with a hammer. If you do this you might screw up the thread on the sway bar (I did this) or you might damage the nuts when you hit them (Did this as well).
TEAM GOR!LLA
POWERED BY CAN AM
#44 REGAN
08 800 outlander max xt
www.myspace.com/kscowboy13
(in reply to cobwoy)
RE: trailing arm - 11/17/2008 8:21:29 PM
Buck Nasty
You have to pull the sleeve out by prying behind the ears. Heating it makes the job easier. After you get the sleeve out, you will need the special socket.
Alcohol Injected Turbo Renegade 800 62+ HP
RE: trailing arm - 11/17/2008 8:21:31 PM
kscowboy
Best way to beat the sway bar out is to either use a piece of wood or a pointed punch so you dont screw up the threads or the nuts. Make sure you have the outer boots off both sides. When you beat the sway bar on one side it will come out of the other side (Obviously).
TEAM GOR!LLA
POWERED BY CAN AM
#44 REGAN
(in reply to kscowboy)
RE: trailing arm - 11/18/2008 7:18:13 AM
grizzlybear
thanks guys for the info
