toyota truck help
toyota truck help
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> toyota truck help Page: [1]
toyota truck help - 11/13/2008 8:28:53 PM
~bigforeman06~
i might be gettin a lil 93 model yota from my mother in law. it needs   a head gasket. its got the 2.4 in it.not sure if its the re or the r. how much does the part cost and how hard is it to put head gasket on??? gettin it for a lil beater truck so i can keep miles off the gmc.
< Message edited by ~bigforeman06~ -- 11/13/2008 8:36:44 PM >
RE: toyota truck help - 11/13/2008 8:54:56 PM
Jordan Petry
Unless that's not the original motor than its the 22relb...  Call your local Orielly, auto zone, car quest, etc. and find the cheapest one, then call Orielly and tell them the price and they will match or beat it.  Plus orielly uses Fel-Pro gaskets for Yotas and they are the next best thing to stock IMO.
I've done headgaskets on 4 cyl before and its pretty easy because they are in the center of the car and there isn't much crap to take off, when you start doing v6's and 8's it gets tough cause its packed.  The gasket set will probably be anywear from $100 -$200.  Make sure you get the set because it comes with the valve cover gaskets, intake gaskets, etc.
BTW the "r" is the carbureteed version I believe.
They are excellent little trucks!  Just keep it clean and out of the weather or it will be a rusted mess in no time.
Good luck.
-1991 Honda 300 - SOLD
-1999 Toyota 4Runner 4x4
(in reply to ~bigforeman06~)
RE: toyota truck help - 11/14/2008 9:39:22 AM
350rancherboy
yall think a 16 year old could do it jw btw..found a 94 v6 wit a blown head gasket...wanna mtn truckk....
2003 Honda 400EX
-White Brothers Pipe
-K&N Air Filter
-DG Nerfbars
-DG Front Bumper
-Renthal Bars/Grips
-Maxxis Razr Tires All Around
1968 Chevrolet C-10 Pickup (Baby Blue)
http://s289.photobucket.com/albums/ll226/350rancherboy/
(in reply to Jordan Petry)
RE: toyota truck help - 11/14/2008 4:17:38 PM
bonpasbrute
Usually when u do a head gasket job on a 2.4 u replace the timing chain guides. They always break and allow the timing chain get into the timing cover causing a water leak. If you've never replaced a head gasket I wouldn't start on a 2.4......ist a fun one. lol
08' Brute Force 750
27" Mud Lite XTR's
14" ITP ss106's
Warn RT25 Winch
Custom Radio
Pen Lock
2" Lift
(in reply to 350rancherboy)
RE: toyota truck help - 11/14/2008 5:02:30 PM
foreman4020
make sure u send the head to a machine shop and have it "worked"
-05 Honda 400ex
-Pro Armor Swing arm Skid
-HMF Sport Series
-03 Honda Foreman ES w/Trax-Lok
-05 Honda Rancher ES 2WD
MY PHOTOBUCKET
http://s450.photobucket.com/albums/qq228/Kry_4020/?start=0
(in reply to bonpasbrute)
RE: toyota truck help - 11/14/2008 10:03:17 PM
~bigforeman06~
arent they ohc? (over head cam)or not. she says its a 93 with a carb. i thought it would have been the re myself but not sure. oh and i found a kit on ebay for like 60 or 70 bucks. it comes with everything.
2006 white 506cc foreman
bbk
web cam
hl leak shield
2'' xtreme lift
hmf exhaust
dual snorkels
dyno jet
(in reply to foreman4020)
RE: toyota truck help - 11/14/2008 11:49:20 PM
foreman4020
nope toyota quit making em with carbs in 87 started making efi standard on 88 and up
-05 Honda 400ex
-HMF Sport Series
MY PHOTOBUCKET
RE: toyota truck help - 11/15/2008 11:39:52 AM
HondaGuy
Yep efi is standard on 88+, as said above if you've never done a head gasket job before this will not be the best one to learn on. Those trucks have about 75 million vacuum lines to keep track of and they all have to go back in the same places or you may have some running probs. It is a ohc engine and you absolutely have to replace the timing chain guides while in there, they do like to break and the timing cover will get cut by the chain very quickly and cause water to leak into the oil. Imo the 3VZ V6s in those trucks are also a pain cause they have all of the same vacuum lines and 2 ohc heads to deal with. They are very reliable trucks though. Is it a Minitruck or a T-100 you didn't say?
Supertrapp Mudslinger
HL EPI Clutch Kit
Relocated Radiator Permacool 8" electric fan
12x7 ITP C Series Type 5s
27in Bi/Tri Claws
Extreme Snorkle
some other stuff
88 Yamaha Banshee (kinda sorta for sale or trade)
Looking for a 4-stroke 400cc or bigger, anybody got any offers pm them to me anything is considered 2wd 4wd etc etc.
RE: toyota truck help - 11/15/2008 11:56:17 PM
~bigforeman06~
i think its a mini.
(in reply to HondaGuy)
RE: toyota truck help - 11/16/2008 12:03:59 AM
oldtrx
a tip i have for you- spend the extra money and get good quality gaskets, not the cheaper ones.
22-r = carb.
22-re= EFI
22-re-c-EFI celica(car, turbo ready)
-abunch of stuff i dont need
-http://www.youtube.com/user/oldtrx2
-www.gaorc.com
-www.myspace.com/haro_bikes_91
ORIGINAL: ydopen
ORIGINAL: white
with a passenger my tires rub my fenders will highlifter springs fix the problem or does my wife need to lose weight
RE: toyota truck help - 11/17/2008 8:24:52 PM
~bigforeman06~
well i got the truck home today.. gonna check it out tomorrow maybe..
(in reply to oldtrx)
RE: toyota truck help - 11/18/2008 11:46:27 PM
MudZukin
I replaced the head gasket on my 82 with the 22r. It was pretty easy, I went ahead and replaced the timing chain which I would so if I were you. If you are looking for some help with toyotas I would you to yotatech.com they have helped me out alot since I got my truck.
the "tiger"
2004 Suzuki Eiger Auto 4x4
Advantage Max-4 HD camo
Air ride double gun rack
Mad Dog rack bag
Warn 2500 winch
Custom snorkel
27 mud lites
Uni Filter
Under construction:
1982 Toyota pickup 4x4
33x14 boggers
