tire height v.s width..
All Forums >> [Most Popular Discussions] >> Tire Talk >> tire height v.s width.. Page: [1]
tire height v.s width.. - 11/11/2008 3:55:09 PM
brant
having a rincon i am limited to how much weight i want to put on her with tires...so what is better the 27x10x12 front and 27x12x12 rear or going up a size buy narrow to save the weight and go 28x9.5 all the way around ? wider would i guess grab the sides of ruts better but taller of course more ground clearance ?
Dont Bring It Unless You Can Sling It !!
YOU GONNA BE DUMB , YOU GOTTA BE TOUGH...
2003 Rinny 650
white 08 plastic
2 inch spring spacers
Clipped Carb Spring
HMF Penland Pro
CENTER SNORKLE
ITP Black Type 7 Wheels
28 LAWS - YEP ON A RINNY..
Those that call upon the name of the lord shall be saved.
RE: tire height v.s width.. - 11/11/2008 3:58:13 PM
of put a lift on it with 27s
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
(in reply to brant)
RE: tire height v.s width.. - 11/11/2008 4:00:27 PM
brant
got a lift now ...i can run 28s if want...jus trying to decide which route to go the 28x9.5 only weigh about 32 lbs a piece which is less than the 27x12 at about 35 lbs
2003 Rinny 650
white 08 plastic
Clipped Carb Spring
HMF Penland Pro
CENTER SNORKLE
(in reply to GWC)
RE: tire height v.s width.. - 11/11/2008 4:46:46 PM
ARK_SWAMP_RIDER
I'd say 27's. Going from 27 to 28 only gives you .5 inch more clearance at best. The 27's seem to have a flatter profile known to perform better. The wider tires give you a larger contact area which would mean more traction. It isn't all about weight. The taller tires raise your gearing, making it harder to turn the tires. So, even though the 28's may be lighter, they may not necessarily be easier to spin.
2005 Honda Foreman 500 S 4x4 with 4 26x12x12 bear claws on itp c series type 6
93 Honda 300 4x4-Mostly stock
90 GMC-6" superlift, 315 buckshot mudders (sold)
96 Ford Mustang Mystic Cobra
My Pics
honda4trax.com
(in reply to brant)
RE: tire height v.s width.. - 11/11/2008 7:33:18 PM
speedy81304
also alittle heavier tire you get better traction also in the deep stuff since it helps not make you flat rathern staying on the bottom.
this is why some rider put water in there wheels to make them heavier for the bogs.
2004 KVF700 4x4. Adventure quad. built to go wear i wont to and not look back.
Making mine better then yours is worth the money well spent.
(in reply to ARK_SWAMP_RIDER)
