taking thermostat for radiator off
All Forums >> [OEM Discussions] >> Can-Am BRP >> taking thermostat for radiator off Page: [1]
taking thermostat for radiator off - 8/10/2008 6:40:49 PM
rancherrider
has anyone taken the thermometer off the regulates the flow of radiator fluid to the engine?  my bike was running really hot yesterday and shut off.  i took off the thermometer to allow the fluid to run straight to the bike.  i was just wondering if it ok to run the bike with the fluid going constantantly to the engine?
2008 Can Am Outlander 800
2 inch lift
29.5's
bayou snorkles with a little custom touch
1.5" wheel spacers
radiator relocated
2002 Honda Rancher (currently out of commission)
27's
2 inch lift kit
snorkled
pull starter leak shield
K&N air filter
Supertrapp exhaust
bored .75 over
RE: taking thermostat for radiator off - 8/10/2008 6:54:09 PM
mud_puppy
Let us know how it works
2008 Can Am 800 Renegade
stealth snorkels
29.5 Outlaws
LTE Dual exhaust
(in reply to rancherrider)
RE: taking thermostat for radiator off - 8/10/2008 7:51:22 PM
rancherrider
I ran it for about an hour today and it didnt overheat at all.  tomorrow i will run it a little harder just to make sure.  i was told though that come winter time it would be best to put the thermometer back in because its so cold it could crack the engine.  but i will let yall know how it works.
2 inch lift
29.5's
1.5" wheel spacers
radiator relocated
27's
2 inch lift kit
snorkled
K&N air filter
Supertrapp exhaust
bored .75 over
(in reply to mud_puppy)
RE: taking thermostat for radiator off - 8/16/2008 7:51:12 PM
breederofkoi
I would put that thermostat back in...  With it running straight through the engine & radiator like that, it'll never stay in radiator long enough to cool off (dissapate heat to the radiator fins)..  this usually causes a gradual overheat problem..
RE: taking thermostat for radiator off - 8/16/2008 8:04:38 PM
blevinsbulldog
try the search, john cannon has some info on this. yes you can take it out, but you have to put some kind of washer in to replace the stat.
07' 800 Outlander Max
Innova Mud Gear 26X10X12 & 26X12X12
Motosport Alloys CastleRock Wheels
Dalton Clutch Kit
Stealth Snorkel
Ricochet skids
Warn RT30
Pipe Lift
Hmf pipe
(in reply to breederofkoi)
RE: taking thermostat for radiator off - 8/16/2008 8:10:42 PM
1meanforeman450
take the thermostat apart and just put the ring back in place... thats how we did my grizzly and my cousins can am is the same way... stays cool, never over heats. our fans hardly ever turn on.
07 brute 650i silver
28" mudzillas on ss112s, HMF pipe, dynatek, jet kit, snorkeled, relocated radiator, 2 rear ape's, clutch kit
(in reply to blevinsbulldog)
RE: taking thermostat for radiator off - 8/16/2008 8:46:25 PM
blevinsbulldog
this is from john
Sorry guys. Ive been out of town. The rear washer that you use to replace the t-stat in the same type washer you would use on a car with an electric waterpump.
This is what it looks like
http://www.mudanddirt.com/tech/canam_2.0_parts/imagepages/image23.htm
The only thing I was told was to let the motor warm up before I nailed on the throttle.
Dalton Clutch Kit
Stealth Snorkel
Ricochet skids
Warn RT30
Pipe Lift
Hmf pipe
(in reply to 1meanforeman450)
RE: taking thermostat for radiator off - 8/16/2008 9:12:10 PM
rancherrider
1meanforeman what ring exactly are you talking about to put back in place?  blevinsbulldog, if i put that washer in without the tstat it should be fine to run it like that?
2 inch lift
29.5's
1.5" wheel spacers
radiator relocated
27's
2 inch lift kit
snorkled
K&N air filter
Supertrapp exhaust
bored .75 over
RE: taking thermostat for radiator off - 8/16/2008 11:35:08 PM
JohnCannon
You will be fine without the t-stat. Just be sure the neck is sealed. Most race Can-ams do not run t-stats and now a lot of mud racers also do not run them.
MaD MOTORSPORTS
.: www.MUDandDIRT.com :.
YouTube:. http://www.youtube.com/mudanddirt
MaD MOTORSPORTS CUSTOM EFI TUNING
07 Competition Sports/MaD Outlander X
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
I support the troops 100%. You guys are my heros..
RE: taking thermostat for radiator off - 8/17/2008 6:55:16 AM
rancherrider
John by the neck being sealed you mean the o-ring that sits in place so it doesnt leak?  Also I found some old post's you made and do I need to go and pick up that washer you were talking about?
2 inch lift
29.5's
1.5" wheel spacers
radiator relocated
27's
2 inch lift kit
snorkled
K&N air filter
Supertrapp exhaust
bored .75 over
(in reply to JohnCannon)
RE: taking thermostat for radiator off - 8/17/2008 9:22:37 AM
JohnCannon
The washer is the correct way to seal the water neck. There are many other ways it can be done. However you do it make sure it is sealed and no trash or gasket stuff is able to flow into the water
MaD MOTORSPORTS
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
RE: taking thermostat for radiator off - 8/17/2008 9:38:46 AM
rancherrider
Alright I'm going to do it that way then with the washer.  Is this the correct part number 420 927 837.  I saw you posted that a while back in a previous thread.
2 inch lift
29.5's
1.5" wheel spacers
radiator relocated
27's
2 inch lift kit
snorkled
K&N air filter
Supertrapp exhaust
bored .75 over
RE: taking thermostat for radiator off - 8/18/2008 6:32:05 AM
JohnCannon
In not sure of the part number off hand. I have posted it in other post.
MaD MOTORSPORTS
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
RE: taking thermostat for radiator off - 8/18/2008 9:37:44 AM
VtecGSR95
ORIGINAL: JohnCannon
OK forgive me as I am an auto mechanic and used to car/truck engines.
But if you remove the stat, the engine will never really reach/maintain operating temps......which is where they are supposed to run the best correct?  Or maybe they produce the least emissions....**** I cant remember!  But if this works, I may do it to my rhino.....I have the fan coming on all the time!
Where do I find the link to this mod??
2006 Rhino SE: Rotax 800 V-Twin
Murdered Out!
2-seat custom cage with bed-delete
Triple guage kit
HL 2" lift kit
HMF Slip-on
Dynojet Power Commander
SS108's on 28" Mudlite XL's
RE: taking thermostat for radiator off - 8/18/2008 10:09:50 AM
DaveB
Rancherrider...that is the part number.
VtecGSR95: that part number replaces the thermostat in the front cylinder with the ring that is in the rear cylinder....pretty simple. Make sure you bleed the air out of the system when you're done.
Bones heal. Chicks dig scars. Pain is temporary but glory is forever.
2007 Can Am Outlander XT
Visions with 28" Mud Bugs
HMF Penland
BRP Skids and A-arm guards
Dalton clutch kit
Crutchfield shocks
BRP fender ext.
East Coast Snorkles (Bully Bomb)
(in reply to VtecGSR95)
RE: taking thermostat for radiator off - 8/18/2008 10:59:57 AM
JohnCannon
the engine temp is mostly for emissions. Usually you want to lower the temps to make more power. The problem is that when you are riding hard or in the mud those temps rise and cause your motor to lose HP. Removing the t-stat will cause the motor to run cooler decreasing the HP lose. It also will give you more time to clean your radiator. Most can-ams that have their radiator on the top could have solved their problems by removing the t-stat. Ive had mine out for over a year with zero problems.
MaD MOTORSPORTS
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
(in reply to DaveB)
RE: taking thermostat for radiator off - 8/18/2008 11:46:21 AM
VtecGSR95
Thanks guys.....I think Ill order this part today!
Murdered Out!
Triple guage kit
HL 2" lift kit
HMF Slip-on
RE: taking thermostat for radiator off - 8/18/2008 12:33:34 PM
rancherrider
ORIGINAL: DaveB
i just want to check what you meant what bleeding the air out of the system means?  im lost on that
2 inch lift
29.5's
1.5" wheel spacers
radiator relocated
27's
2 inch lift kit
snorkled
K&N air filter
Supertrapp exhaust
bored .75 over
(in reply to DaveB)
RE: taking thermostat for radiator off - 8/18/2008 1:15:14 PM
DaveB
Any time you open up a cooling system you need to get the air out. There are bleed screws on top of both "thermostat housings" for this purpose. Do the lower one first...engine running, full of coolant, rad cap off...until air bubbles stop. Then do the higher one.
HMF Penland
Dalton clutch kit
Crutchfield shocks
BRP fender ext.
RE: taking thermostat for radiator off - 8/18/2008 7:50:42 PM
greenhead
it works freaking great especially for mud riders. that is one of the first things i have done to my bikes. dont have an overheating problem at all. even on the ones with the rads down.
Team Gander Mountain Racing
MUD NATS 08 MuddaCross 2nd Place
TEXAS MUD JAM 08 Open Bog 2nd Place
TEXAS MUDFEST 08 Fri-Series B 1st
TEXAS MUDFEST 08 Fri-Open 3rd
TEXAS MUDFEST 08 Sat-Series B 1st
TEXAS MUDFEST 08 Sat-Open 2nd
CANAM NATIONALS 08 Swamp Cross Open 2nd
CANAM NATIONALS 08 Open Bog 1st
RURAL SHADE C.M.R 08 class 3-1st
RURAL SHADE C.M.R 08 Open 2nd
BAYOU C M R 08 class 3-2nd
Mudstock Open Bog 1st place
C M R Year 2nd Place Open mud bog Championship
(in reply to DaveB)
RE: taking thermostat for radiator off - 8/18/2008 10:52:32 PM
rancherrider
thanks for all the help guys.  im going order the washer tomorrow and will be putting it in place of the thermostat when it comes in.  hopefully its soon...thanks again for all the help!!!!
2 inch lift
29.5's
1.5" wheel spacers
radiator relocated
27's
2 inch lift kit
snorkled
K&N air filter
Supertrapp exhaust
bored .75 over
(in reply to greenhead)
