stuck cups
stuck cups
All Forums >> [OEM Discussions] >> Arctic Cat >> stuck cups Page: [1]
stuck cups - 7/23/2008 9:16:30 PM
papa_slap
okay i tried it all to get these cups out the diff, the diff's are not on my bike. any suggestions would be awesome i am trying to install my 4.0's in these before i go to can am nationals. what you guys think, BTW it's the gowilla cups.
resurrected: 05 black h1 "BIG BLACK",
it's got alitle bit!!
hers: 07 suzu fi, 450 "queen quad", 3"
xpatv, 28 swamplites on msa castlerocks,
2500 lb. winch yeah it spins them
team anyting goes racing
www.anytinggoes.com
RE: stuck cups - 7/23/2008 9:20:06 PM
I take it neither will come out..?  have you tryed the normal things cv axle puller and so on..?? if you can get one out you can beat the other one out with a sledge and a pipe.
you might not ever get them there are a few people that have had to buy whole new diffs because they wont come out.
TeAm GeT YoU SoMe
Arctic Cat 08 650H1 LE
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
"H.ard P.ack A.rctic C.ats"
It all seems HardPack when you ride a Cat.
MY PIX
(in reply to papa_slap)
RE: stuck cups - 7/23/2008 9:24:08 PM
bustedknuckles
Have you tried GWC's chain and big sledge trick?
Gorilas? I heard they use a large slide hammer with an attachment that grabs the cup real tight.
If its the ones that had the problems, We have tried it all. Including the use of a 3/8 chain a 1 ton dodge diesel and a tree, with no results.
Hopefully this is not the case.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: stuck cups - 7/23/2008 9:31:28 PM
papa_slap
i built a cup puller with a 1.5"x24" bolt with a 30 lb slide on it and it didn't come out.  do you think if i soak in something (i don't know what) that it will let go.  BTW are any of you guys going to be there next weekend i would like to meet you guys.  yall all seem to be my kind of people.
www.anytinggoes.com
(in reply to bustedknuckles)
RE: stuck cups - 7/23/2008 9:42:46 PM
bustedknuckles
What and where is canam nats?
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: stuck cups - 7/23/2008 10:39:18 PM
JUSTINMILLER
Are both axles stuck in the diff???
TEAM CRUSHLOK
2005 arctic cat 400
(somewhat stock)
29.5 outlaws on crushloks/28 edl vampires on crushloks
RE: stuck cups - 7/23/2008 10:43:22 PM
papa_slap
nope front it's stuck on the right side, and the rear is on the rside i don't think this one would be a problem,  But i can't figure a way to get the front one out because of the pin that runs in the spider gears.  IDk.
www.anytinggoes.com
(in reply to JUSTINMILLER)
RE: stuck cups - 7/23/2008 10:49:44 PM
JUSTINMILLER
Ok well on mine I had the right side stuck in the front and I went to a buddy of mines and we split the case gutted it then used a hand press and a torch just be VERY CAREFUL we had about 4,000 pounds of pressure plus a little heating from the torch  before it came out.
< Message edited by JUSTINMILLER -- 7/23/2008 10:56:09 PM >
TEAM CRUSHLOK
2005 arctic cat 400
(somewhat stock)
RE: stuck cups - 7/23/2008 10:52:52 PM
papa_slap
i will definately try that did it mess anything up.
www.anytinggoes.com
RE: stuck cups - 7/23/2008 11:00:22 PM
JUSTINMILLER
No just put a little bit of scratches on the end of the cv.But it is not sumthin to be rushed
TEAM CRUSHLOK
2005 arctic cat 400
(somewhat stock)
RE: stuck cups - 7/24/2008 2:42:52 AM
redneck36049
well i had the same prob today while trin to get the front right axle out of my cuck. i had to call a buddy to come over and we tried everythin.  even went and bought a 12lb sledge hammer and that didnt even work. but all it took was me pullin and him hittin it with a old screw driver through the cuck and it slipped right out.
2007 ARCTIC CAT 650 H1
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
WANT A CAT CALL STEEL HORSES WISH I DID
MY PICS http://www.myspace.com/redneck36049
RE: stuck cups - 7/24/2008 9:56:25 AM
bustedknuckles
Yeah man just get an old big flat head and wedge it thru there and hammer it out.
I thought it was both rears.
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
(in reply to redneck36049)
RE: stuck cups - 7/24/2008 1:04:41 PM
yeap grind a big screwdrive so it will fit by the pin cut the handle off it and get the sledge hammer after it. about 20 to 30 super hard licks and it will pop out..
TeAm GeT YoU SoMe
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
MY PIX
RE: stuck cups - 7/24/2008 1:10:54 PM
redneck36049
you love your sledge GWC. you must have been the guy that killed the pigs in the slater house lol
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
(in reply to GWC)
RE: stuck cups - 7/24/2008 1:13:05 PM
Well its takes more then a 24oz hammer to get the cv cups out that for sure..lol
TeAm GeT YoU SoMe
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
MY PIX
RE: stuck cups - 7/24/2008 1:53:49 PM
drumz2129
if you can have some one pull on the axle while you hit the screew driver. makes it easier and go quicker.
2006 Red 500 Manual
Mud tires: 27" Highlifter Outlaw (27x9.5x12 front 27x12x12 rear) on ITP SS108 Black Rims
Trail tires: Stock 25" Carlisle Badlands on stock rims
LE front and rear bumpers
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Radiator Overflow Tank added and Snorkled
Differentials Snorkled
(in reply to GWC)
0.547
