stuck axle
stuck axle
All Forums >> [OEM Discussions] >> Polaris >> stuck axle Page: [1]
stuck axle - 9/29/2008 5:13:00 PM
wakeman1322
does anyone have any good trick up there sleeve on how to pull a left rear axle out of an 500 sportman.        this thing want come out
07 brute 750 warn winch,snorkeled,cdi,hmf, k&n filter
temp gauge, 28 oulaws jet kit ss 108's
runs like a top
98 honda foreman 400 back drop rack, 2in lift
26 itp mudd lites,hunting rig
00 popo 500 winch, bumper front and rear, supertrapp,
4 in lift, 2 monkey axles, itp wheels and 28 swamp lites
TEAM THROWED OFFROAD
Fueled By:
M.O.R.A
MONSTER ENERGY
RE: stuck axle - 9/29/2008 5:17:30 PM
Rebel64
Have you soaked it with PB Blaster for a couple days?
07 800 Stealth
(in reply to wakeman1322)
RE: stuck axle - 9/29/2008 5:20:05 PM
mud_duck
Take a small pry bar or a bent tip flat head screwdriver. Wedge it between the cup and the geracase at the bottom. This will get the retaining clip tight against the groove inside the gearcase. Now tap down on the cup with a hammer. This will pop the top of the clip out of the groove. Keep tapping gently and keep preasure with the prybar on the bottom side and you should be able to work it out.
NOTE: be careful with the prybar! don't try to pry it out. The geacase is soft and can break. Just drive it in to put preasure on the cup.
        There is also a seal behind the cup that you don't want to mess up.
< Message edited by mud_duck -- 9/29/2008 5:23:16 PM >
'04.5 Polaris
TEAM CRUSHLOK Powered By Miller Industrial
CLICKMy Pics
______________________________________________
I may be old, but I'm not boring
RE: stuck axle - 9/29/2008 5:22:32 PM
mcrockett
Wakeman,
Is the inner joint intact?? Stary by spraying it with a good penetrating oil and letting it soak overnight. I have been able to drive them out with "ball joint fork" if they aint stuck bad. Others I have welded a link of chain to the outed cup of the joint and then jerket the snot out of it with a slide hammer.
While you have that joint out I would tear down the other side too while you can drive the joint straight out and the use lots of anti seize and or marine grease when you put it back together.
Just my $.02
Good Luck!!
< Message edited by mcrockett -- 9/29/2008 5:24:05 PM >
PoPo 700, 27" Zillas on SS108's & 29.5" Laws on delta steels, 3500# PoPo Winch, bumpers, cooler, H.C. clutch, Aaen Pipe, Tunes, Etc.,
08' Grizz 450 Ltd. edition. (kids bike)
27" Laws on S.R.A. steel wheels
07' Grizz 450 Silver, S.E
Big Bad PoPo Hawkeye, rollin on 22's (kids bike)
(Sold)
86' Chevy S10, with a rowdy stroker motor (Low 10's on the motor) + a 150 shot of gas when I need it.
(Sold)
F250 Crew Cab with 6" of lift and BFG's on Weld Evos + a 15KW PTO generator (RealPow
RE: stuck axle - 9/29/2008 5:23:55 PM
wakeman1322
i had a pry bar between the cup and the diff but didnt want to cut into the diff.  will the diff take alot of abuse
runs like a top
Fueled By:
M.O.R.A
MONSTER ENERGY
(in reply to mud_duck)
RE: stuck axle - 9/29/2008 5:27:05 PM
wakeman1322
thank guys, it has been soaking in pb all day.  so in other words jerk the #@@#  out of it
runs like a top
Fueled By:
M.O.R.A
MONSTER ENERGY
RE: stuck axle - 9/29/2008 5:27:11 PM
mud_duck
Yea. Once you have one side out, you can drive the other side out fron the hole where you removed the first one. The ring gear has a hole all the way thru it. Just take a big punch or a piece of pipe and hit it with a hammer to drive the second cup out.
'04.5 Polaris
CLICKMy Pics
(in reply to mcrockett)
RE: stuck axle - 9/29/2008 5:30:32 PM
mud_duck
ORIGINAL: wakeman1322
No. You can crack the gearcase.
Just get the prybar wedged in near the bottom of the cup (if you notice, the cup will rock up and down a little bit) and tap down on the top of the cup. Works great.
< Message edited by mud_duck -- 9/29/2008 5:32:19 PM >
'04.5 Polaris
CLICKMy Pics
RE: stuck axle - 9/29/2008 11:00:03 PM
mudman3298
mud duck pretty much covered it all
2007 SPORTSMAN 500
Dirtbmw20 RADIATOR BRACKET
29.5 LAWS
TURNER AXELS IN BACK
HSP PIPE
1.5 IN SPACERS
2IN PUCK LIFT
CUSTOM SNORKELS
RE: stuck axle - 9/30/2008 11:42:51 AM
wakeman1322
i got it out last night, lots of sweat and bloody knucks
runs like a top
Fueled By:
M.O.R.A
MONSTER ENERGY
RE: stuck axle - 10/1/2008 10:16:07 PM
mud_duck
Just out of curiosity, how did you get it out?
'04.5 Polaris
CLICKMy Pics
