cointoss
If the Battery is good(make sure volts are at least 12.4v(75%) then Make sure you have a good ground to your engine! There should be a large ground wire next to your hi/low/reverse shifter which connects your engine to ground frame, without it , the starter wont work. Check that. I know lots about electrical, let me know and I'll go step by step how to test the circuit... but check all connections first INCLUDING ground connections...
'06 Green Vinson 5speed 2000lbs Warn 26/9/12, 26/11/12 itp Terracross
