sp 700 overheating.. cant figure out why
All Forums >> [Most Popular Discussions] >> Tech Questions >> sp 700 overheating.. cant figure out why Page: [1]
sp 700 overheating.. cant figure out why - 7/24/2008 9:54:25 AM
Xplorer470
I have a sportsman 700 that was left out one winter and ever since it just hasn't ran right.  It has boiled over out of the over flow bottle, constantly back fires, and has tons of carbon build up.  I have taken it to two polaris dealers and they haven't been able to solve the problem.  One said the head could possible be warped from when it ran so hot it boiled over.  I think it could be out of timing.  Once started up and idleing it only takes about 15 minutes for it to start heating up bad.  Any help would be greatly appreciated.
                                    thanks,
                                     Staton
96 Xplorer 400.AAEN 470 bbk,44mm carb,14:1 compression,aluminum head,roller clutch,6"lift.31"laws, axle paddles.80-85 hp at the fly =)
03 sp 700.800 bbk,6"lift,32" sbacks,stage 3 motor work,gear reduction,pinned crank,cam,42mm carb, 12:1 pistons
RE: sp 700 overheating.. cant figure out why - 7/25/2008 10:32:31 AM
sgt_grinch
I'm no mechanic but are you sure your water pump is working? Sounds like there's no coolant running through the engine.
07 CAN-AM 800
HMF OPTIMIZER
*new* 28 sbacks/12"TORK WHEELS
relocated radiator
HMF UTILITY SERIES
2"LIFT
FULL SNORKS
07 Kingquad(hers)
27" swamplites/14"itp
snorkeled
(in reply to Xplorer470)
0.125
