C1iffBurton
i know a snorkel tries to serve a purpose as letting the bike go deep and i know there is some sort of mathmatics that go along with making them and the jetting that goes along with them but my delimna is this but really its not to me and my thinking this is the same thing between the two of these, anyhow going from a 1.5" flex hose from the airbox to a 1.5"x2" reducer then going with a 2" 90 turning up and a foot or foot and a half of pipe then another 90 or 180 on top or going with a 2" flex hose out of the airbox then doing the same thing as above stated but the pipe sizes just change locations to me the bike will get the same amount of air no matter what but i know it has to do with volumes and stuff like that, so lets hear what yall have to say about it to me if u have a 2" hole at the end of the snorkel getting reduced down to 1.5" then going into the airbox that is easitially the same as having a 1.5" hole at the end of the snorkel and the reducer instead of reducing it just opens up to a 2" pipe to the airbox now i want to say with the foremans which is what this is for the 1.5" going into the airbox actually fits into the stock piece and can still use the stock clamp to hold it together, whereas with the 2" at the airbox it goes on the outside of the airbox piece and u have to use a bigger hose clamp....now i know inside of the piece that the stock snorkel hooks to at the airbox, it reduces or has a shoulder in it that only lets u push the piece so far into the tube before it wont go anymore, meaning the opening at the end is a little bigger than the shoulder inside so when u stick the stock snorkel piece or whatever in it the inner diameters should be the same size per say i also know alot of it has to do with how many bends u get in the pipe and such and has to do with the airflow running through it and all but to me if u ran the snorkel the exact same way as i stated above just the pipe sizes are flip flopped, it will only suck so much air so hard at 2" at the top of the snorkel and im sure if u put a 1.5" at the end it will still suck the same amount of air but it will just seem to be sucking it harder is my theory on this correct or incorrect, i did go to college and graduated but there are just so many aspects to this that im either overlooking or cant determine or i am just looking to far into this whole thing sorry for the long post but ive always wondered and would like to know even more now since im about ot snorkel a friends bike for him, i have found 2 different plans to make them both of which the design is the same but the pipe sizes are flip flopped, each plan that i got it from didnt have to rejet but im not fully convinced which one to go off of, one of which the plans is a personal riding buddy of mine and id trust him before id trust someone just randomly off the internet thanks, lets see what yall can pop out of yalls heads on the issue
MINE*08 big bear 400, 27" skinny black love outlaws, CRSbear custom snorkel, Gumbo03 custom lift, oil cooler relocated, fan switch, audiopipe, viper 2500 max --TEAM ANYTING GOES RACING-- R.I.P. JAYSON MATTHEW PARKER
