solenoid?
solenoid?
All Forums >> [OEM Discussions] >> Arctic Cat >> solenoid? Page: [1]
solenoid? - 8/24/2008 5:34:15 PM
zillaman450
i turn the key on and the display says volt and it wont start and the battery is good and all fuses are good also could it be the solenoid??
Boudreaux Customz
06 H1
(THE RECOVERY VEHICLE)
29.5-12-12 LAWS on all 4's(sold)
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
RE: solenoid? - 8/24/2008 5:35:43 PM
bustedknuckles
Are you sure the battery is good? What about the connections?
click here and buy my suburban
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
(in reply to zillaman450)
RE: solenoid? - 8/24/2008 5:37:15 PM
mudracer80
Take a screw driver or a pair of pliers and jump the post's and see if it will roll over.  If it does first try cleaning all the connection and if it still doesnt work then yes its the soleniod
06 Arctic Cat 665 V-TWIN 11.5:1 CWR450 cams
Swx full exhaust, dynatek
2" lift, ape'ed, lawed
jeted and clutched
Wifes Bike
07 Grizzly 660, 5.5" Ape lift,
clutch kit, custom snorkel,
30" Mudzillas, Rad Relocated
Hard Pack Arctic Cats
It all seems HardPack when you ride a CAT
STEEL HORSES
(in reply to bustedknuckles)
RE: solenoid? - 8/25/2008 1:53:45 AM
rancherben
Mine has done that and it also started flashing the display after a while. What I found was that were the wiring harness goes over the frame directly under the seat had rubbed a hole in it. The wiring harness only has electrical tape wraped around it for pretection which sucks. I ride in Crosby alot and the sand got in there rubbed through 6 wires. It took a while but found the bad wires replaced them and put new wire looming around the wiring harness. I fixed it last year and has worked great since.
06 h-1
snorkeles, radiator relocated with roll cage, custom jet kit, glass pack,warn3000, HL spacers,29.5outlaws, vision 161 briusers, front spring spacers, rear prowler springs, gorrila axles x4, custom 2" lift, Speedwerx clutch springs and rollers.
You can talk smack if you can back it up
RE: solenoid? - 8/26/2008 8:39:59 PM
zillaman450
well put the new solenoid on today and shes dead as a door knob still so what else could of gotten fried??
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
(in reply to rancherben)
RE: solenoid? - 8/27/2008 5:18:46 AM
1badkittykat
i think it is what ben said... i had the same problem on mine, and he warned me a year ago to check out the harness... well one day it just shut off... and never came back on, i tore the bike down to the frame, and completly tore apart the wiring harness, and found 3 broken wires under the seat where a sharp spot on the frame got it, and 1 of those wires was the hot going to the ignition, fixed them, re-electrical taped the entire thing, and wire loomed EVERYTHING... its been about 3 weeks now, and its workin good except for a bad battery now
07 Kitty Kat 650 H1
28'X9.5' LAWS, Black Magic Exhaust, Full Snorks, Aluminum Products Skids, Jams w/ ipod n Otter Box, Strobes, Death Grips, Jetted, LE Wheels & Bumpers, Oddysee PC-680 Battery, AC Backrest
http://www.myspace.com/itsajeepthing699
http://youtube.com/user/maddmatt469
Matt
RE: solenoid? - 8/27/2008 6:38:19 AM
BIGBLACKCAT
Mine did the same thing and it was the starter.
08 650 h1
Lemon
(in reply to 1badkittykat)
RE: solenoid? - 8/27/2008 7:36:13 AM
Bunk650
my money's on a grounded wire harness. check the frame by the tank and battery, and check down your steering column...
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
(in reply to BIGBLACKCAT)
RE: solenoid? - 8/27/2008 10:49:59 AM
zillaman450
thanks guys well i had put one of those temp gauges on it from o'reillys and wired the backlight to it straight to the battery well i was riding it after i washed it and flipped my toggle switch to turn the light on and it all shorted out i forgot to mention this earlier sorry. when i pull start it i have to hold on the throttle and everything will work for about 5 seconds then the display goes dark and volt blinks and when i let off the throttle it will die now im stumped once again??     I think ima just call good ole Steel Horses
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
RE: solenoid? - 8/27/2008 10:52:10 AM
zillaman450
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
RE: solenoid? - 9/3/2008 11:08:17 AM
zillaman450
well i have changed the solenoid the voltage regulator and its still doin the same thing, the only other thing i can think of is the CDI box? what exactly does this control?
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
RE: solenoid? - 9/3/2008 2:52:02 PM
8upwithmud
Man it really sounds like a rubbed wire.  If your CDI was out, it probably wouldn't start at all.  The CDI controls your ignition and really has nothing to do with the starting circiut.
05 Evil Twin
Bored, stroked, camed, ported, polished,
piped, jetted, snorkeled, clutched, geared,
dynateked, Gorrilla'd, lifted, and lawed.
13 axles
6 motors
6 differentials
1 fan
? belts
04 500M with 28 laws
05 400A with 27 lites
06 Night Rod
http://myspace.com/leebo1973
........................HPAC.........................
.............Hard Pack Arctic Cats.............
RE: solenoid? - 9/3/2008 4:08:30 PM
zillaman450
Im not sure bc it ran fine until i put that temp gauge and the light on it shorted out when i washed it and it got wet due to me not putting a inline fuse....but with the new regulator when the screen flashes volt about the 5th time the whole 4 wheeler shuts down and it did not do this b4...I have called steel horses and they want me to bring it in but gas is jus to expensive to make that trip so I really need 2 figure it out.
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
(in reply to 8upwithmud)
RE: solenoid? - 9/3/2008 4:20:18 PM
Bunk650
stator
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
RE: solenoid? - 9/3/2008 5:30:05 PM
zillaman450
Thanks man i believe ur right bc jus called steel horses again and he said that the stator would be his next guess luckily i have a parts motor so i jus got 2 change it out and see what happens
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
(in reply to Bunk650)
RE: solenoid? - 9/3/2008 5:34:57 PM
Bunk650
good luck!
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
RE: solenoid? - 9/3/2008 5:51:14 PM
big tony
Whats the condition of your starter, check to see if you are getting voltage to it when you crank, if not look elsewhere, but if so, replace the starter.
08 650 H1 CAMO
07 650 H1 2-Tone...lol
98 454 Bearcat 2x4
90 Kawasaki Bayou 300
84 Suzuki 185
Steel Horses
Catvos
Steve's ATV
RE: solenoid? - 9/3/2008 5:58:15 PM
zillaman450
The starter is good bc it turns over when i jump the solenoid but the start button nor the gauges work.
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
(in reply to big tony)
RE: solenoid? - 9/4/2008 9:32:02 PM
big tony
I'm thinking grounded wire or cdi box. I know you can even unplug your cdi and the bike will still turn over, just won't get spark. So, a bad cdi could cause what your symptoms are. Not sure about all the trouble shooting on the stator.  If you don't figure it out, I'd take it to Jeff @ Steel Horses. I know gas is expensive, but its well worth the drive
08 650 H1 CAMO
98 454 Bearcat 2x4
84 Suzuki 185
Steel Horses
Catvos
Steve's ATV
RE: solenoid? - 9/4/2008 9:45:08 PM
TBONESGRIZZ
I would be SURE your battery is good... Mine thur Voltage up at RCOR and the battery was dead, all in all though I fried the starter and had to replace it.  After charging battery for 2 hours and replacing starter she fired right up.  Good rule of thumb like you said though is that if you can jump the solenoid or run hot jumper cable straight to negative post on solenoid and starter turns over, then starter should be good
'08 Polaris RZR... Project MonstR'
'08 Arctic Cat 700H1
'05 Brute Force 650 SRA
TEAM THROWED OFFROAD
www.myspace.com/msboyzridindirty
Powered By:
M.O.R.A
Fueled By:
MONSTER ENERGY
RE: solenoid? - 9/4/2008 9:56:08 PM
zillaman450
Man do i feel stupid now, pulled the wire harness and found my problem the main power wire was roasted it burnt in half right before it goes by the gas tank.  So thanks 2 all of u guys that tried 2 tell me im jus hard headed
Boudreaux Customz
06 H1
Custom snorks
Relocated Rad
2'' lift
Spring spacers
HMF
Dyno Jet
Brand new motor
H.P.A.C
GIT-R-DUN
(in reply to TBONESGRIZZ)
RE: solenoid? - 9/4/2008 10:05:03 PM
TBONESGRIZZ
ORIGINAL: zillaman450
haha happens to the best of us bud!  Glad you found the problem.
Powered By:
M.O.R.A
Fueled By:
MONSTER ENERGY
Post #: 22
