minitrk
vent f & r brakes, diffs, fan, carb. vent all into one EXCEPT the carb that needs seperate vent, get second check (1way)valve and stick in carb drain that hangs down from bottom of carb. only way to test is take it swimming. EDIT: wait an 06 has front disk doesnt it? if so no vent on those
< Message edited by minitrk -- 8/27/2008 8:58:32 PM >
04 foreman 450 yellow - disk brakes - clutch kit - Triangle atv snorkle - jet - uni filter - perfex ltk - hl springs - 27 bi/tri claws on type 4s - warn 3.0 - warn bumper - plasma rope - sealed pull start - back up light - hmf eco - rear box/seat - fener protectors - f&r tow hooks - pod light shut off switch - full prm armour - reverse button override
