snorkel question
snorkel question
All Forums >> [Most Popular Discussions] >> Tech Questions >> snorkel question Page: [1]
snorkel question - 8/28/2008 12:48:13 PM
CNM
does it matter if the carb air hose breather is too small?
250 Honda Recon 2002
snorkled
Under Construction
RE: snorkel question - 8/28/2008 2:12:00 PM
ibrokeit
yes it does. what size u running?
it's gots that thing that makes it go fast----A V-TWIN!!!!!!
09 Can-am 800r xt camo
07 brute 750-29.5 laws, 2"lift, snorked,moose module,uni filter, maroon/red clutch springs. FOR SALE $5k
07 king 700-pc3, 3"lift,custom bumpers, tranny snorked, 29.5 laws,coop 45 mod 1.5mm,some shock spacer doo hickies, rear seat w/foot rest,stero .
(in reply to CNM)
RE: snorkel question - 9/3/2008 3:48:21 PM
CNM
why do i still get water in my carb when it is snorkeled?
snorkled
Under Construction
(in reply to ibrokeit)
RE: snorkel question - 9/3/2008 4:01:47 PM
bhmudder11
cuz something you snorkeled is not sealed
TEAM ABS (Always Breaking Stuff)
MONEY WELL WASTED OFFROAD
07 AC 650 H1
BLACK ON BLACK
H.P.A.C.
You Know What It Means
(in reply to CNM)
RE: snorkel question - 9/3/2008 9:04:23 PM
CNM
i had trouble puttin the hose on cause it was really tight, would that leak?
snorkled
Under Construction
(in reply to bhmudder11)
RE: snorkel question - 9/3/2008 9:14:49 PM
bansheefan03
no it should not matter
2006 rhino 660
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ ****s ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb
98 300
not really sure how much lift, ape axles,gear reduction,xl2 wheels, axle paddle,and lots more to come
(in reply to CNM)
RE: snorkel question - 9/4/2008 12:45:11 PM
CNM
would it be the drain hose?
snorkled
Under Construction
(in reply to bansheefan03)
RE: snorkel question - 9/4/2008 2:37:39 PM
toyazman76
My Grizz has two vents one on each side of the carb.
2003 Grizzly 660, Snorkeled, Mudbuster cam, Wiseco piston, DIY split audio Tube, 27" laws, EPI clutch Kit, Relocated radiator, Temp-gauge, Custom cooler rack.
1992 Banshee-SOLD
(in reply to CNM)
RE: snorkel question - 9/4/2008 3:45:03 PM
CNM
o i'll look and see if there is but i dont think so cause its a really small motor
snorkled
Under Construction
(in reply to toyazman76)
RE: snorkel question - 9/6/2008 12:04:37 AM
conmann
you will have a carb vent line that is on the side of the carb.  It is usually 3/8 I think. but anyway that is the problem just run it up with the snorks and problem solved
800
29"s
lift
spacers
bumpers
winch
huge ice chest
hottie on the back
snorks in the box
(in reply to CNM)
RE: snorkel question - 9/6/2008 11:39:14 AM
CNM
i did run it and that is the problem, something aint sealing right
snorkled
Under Construction
(in reply to conmann)
RE: snorkel question - 9/6/2008 12:59:03 PM
minitrk
you own a honda, it is the drain line hanging off the bottom of the carb, nothing more. if you own a honda you had, have, or will have this problem. Either get a second one way valve and run it in line with the factory valve or plug the line before you play in the water, the rear driveshaft boot clamp bolt works good for a plug. just be sure to unplug it when you arent in the water or you COULD fill your airbox with gas... heck it can happen while in the water too so the best bet is just get a second valve then you wont have to worry about it.
04 foreman 450 yellow
- disk brakes
- clutch kit
- Triangle atv snorkle
- jet
- uni filter
- perfex ltk
- hl springs
- 27 bi/tri claws on type 4s
- warn 3.0
- warn bumper
- plasma rope
- sealed pull start
- back up light
- hmf eco
- rear box/seat
- fener protectors
- f&r tow hooks
- pod light shut off switch
- full prm armour
- reverse button override
(in reply to CNM)
RE: snorkel question - 9/6/2008 1:01:16 PM
CNM
where can i get one of those valves from? and bout how much am i looking at?
snorkled
Under Construction
(in reply to minitrk)
RE: snorkel question - 9/6/2008 1:09:47 PM
minitrk
you should be able to get one from the parts store of your choice, bring in a small piece of the line to be sure you get the right size. tell them you need a oneway check valve, maybe 5bucks. Also heard the popo ones work real good if you dont mind cross-breeding your honda lol.
just be sure to put it on the right way.
- disk brakes
- clutch kit
- jet
- uni filter
- perfex ltk
- hl springs
- warn 3.0
- warn bumper
- plasma rope
- sealed pull start
- back up light
- hmf eco
- rear box/seat
- fener protectors
- f&r tow hooks
- full prm armour
(in reply to CNM)
RE: snorkel question - 9/6/2008 1:31:58 PM
CNM
lol k, ill go check that out thanks
snorkled
Under Construction
RE: snorkel question - 9/7/2008 8:00:39 PM
GoinDeep09
You gotta run vent lines. there is 2 from the carb and one in the rear diff and one in the front diff. its really cheap and easy. just run them to your handlebars.  and if you want to test the seal on your snorkel just put your hand over it and if it shuts off right away ur good.
(in reply to CNM)
RE: snorkel question - 9/9/2008 8:49:40 PM
CNM
i got a vent line ran and its sealed, and there is not a nother one on the other side, there is only one and the drain aint sucking water, i tested it by putting a glass of water and it didnt shut off, whats wrong?
snorkled
Under Construction
(in reply to GoinDeep09)
