Yes look at those pix up top, the 500M is one of easyest quad out to snorkel. there are lots of pictures on how to snorkel 650 autos up there but the air box on your 500 is the same so you can snorkel it just like the 650 if you want to. you also need to make sure youor gas tank vent and top carb vent are both ran up (they should be in the gauge pod allready) and also plug off youo carb float bolw drain/vent hose or water will go back up it and kil the motor.
08 650H1 LE Warn 3.0 Snorkeled,Rad racked Custom gauges muffler tweaked Dynojet, slide mod, spring clipped Dyna Tech CDI Custom clutch kit 4.0 gears HL springs, HL spacers Gorilla axles 29.5 Laws, custom LE wheels 30" MLs, Black Castle Roks 05 500m Hidden Snorkel Dynojet,slide mod spring clipped muffler tweaked HL temp gauge 26" 589MTs, ITP type 6s H.ard P.ack A.rctic C.ats
