JeffinTD
If the smoking is from the rings, the big bore kit replaces the cylinder liner, the piston, and rings with new. Since you will have the head off anyway, it would make sense to have a machine shop measure the valve to valve guide clearance, and to replace the valve seals. That could be your other source of smoke.
680 Rincon camo, warn XT30, Foreman headlight 500 Foreman FM, warn 2.5 Rides in PatioHauler 5th wheel, towed by Ram 3500
