signs that i need new piston rings
All Forums >> [Most Popular Discussions] >> Tech Questions >> signs that i need new piston rings Page: [1]
signs that i need new piston rings - 10/2/2008 4:53:10 PM
tytyrecon
00 recon
completely rebuilt engine and rear end
soon to have 2" lift
no winch
25x12.5-9 kenda bearclaws on 250ex rear rims out back
completely stock out front
Homemade 1.5" PVC Snorkel
jeep taillight
custom monster warning labels
One 15 y. o. operator
http://myspace.com/clutz_tyler
hit me up!!
RE: signs that i need new piston rings - 10/2/2008 5:19:39 PM
toyazman76
smoking and loss of compression.
2003 Grizzly 660, Snorkeled, Mudbuster cam, Wiseco piston, DIY split audio Tube, 27" laws, EPI clutch Kit, Relocated radiator, Temp-gauge, Custom cooler rack.
1992 Banshee-SOLD
(in reply to tytyrecon)
RE: signs that i need new piston rings - 10/2/2008 5:56:02 PM
southernmudder420
how do you tell if u have lost compression?
(in reply to toyazman76)
RE: signs that i need new piston rings - 10/2/2008 6:20:11 PM
VT_Grizzly
Get a compression guage, pull the spark plug and insert or thread in the guage.  Turn over the quad and it'll give you a compression reading.  You'll have to find out what the spec is for your quad.  Blue smoke out the exhaust is oil going by your rings.
(in reply to southernmudder420)
RE: signs that i need new piston rings - 10/2/2008 6:45:32 PM
tytyrecon
well i do have blue smoke coming out of the tail pipe but when i try to go if i dont floor it, it wants to stall
is that a loss of compression?
00 recon
no winch
jeep taillight
hit me up!!
(in reply to VT_Grizzly)
RE: signs that i need new piston rings - 10/2/2008 7:11:29 PM
muddyfuzzy
how long has there been a loss in perfomance, not after the bike was snorked per chance.
< Message edited by muddyfuzzy -- 10/2/2008 7:12:32 PM >
MINE-08'outty800max-xt/lawed with28"skinnys/ snorked/w2"intake/radiator relocated/skidded out
"Power down in the hole"
WIFE'S-07'trx420fm/uni/lawed with 28" skinnys/custom snorked/supertrapp mudslinger/high lifter outlaw clutch kit/dynojet pcIII power commander(tuned by "THE JOHN CANNON")
RE: signs that i need new piston rings - 10/2/2008 7:18:06 PM
tytyrecon
well i took it out b4 i put the snorkle on it and sank it around 4times that day
i flushed the motor a few times and it ran ok then i put the snorkle on and it ran great
but the second time i rode it, it was smoking very very litlle with the snorkle i sank it becouse one of my carb hoses came off
so i flushed it 1 more time then rode it somemore 2day and that when i realized it was really smoking blue
btw i WOT'ed about a month ago
00 recon
no winch
jeep taillight
hit me up!!
(in reply to muddyfuzzy)
RE: signs that i need new piston rings - 10/2/2008 7:25:13 PM
VT_Grizzly
You need to take a compression reading, and then more than likely open it up to see if you need new rings, possibly a piston, cylinder or bore.  You won't know until you open it up.  At the very least, it'll probably need rings, but more than likely a small bore and the next size up piston - depends what you find.
RE: signs that i need new piston rings - 10/2/2008 7:32:19 PM
tytyrecon
how will i be able to tell what i need
how much will it cost for a 250 recon
00 recon
no winch
jeep taillight
hit me up!!
RE: signs that i need new piston rings - 10/2/2008 8:09:40 PM
toyazman76
I paid a little over a thousand. High comp piston,bored and installed a cam but i already had the cam.
1992 Banshee-SOLD
RE: signs that i need new piston rings - 10/2/2008 8:11:11 PM
tytyrecon
OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
there is no way i will be able to put that much into it
00 recon
no winch
jeep taillight
hit me up!!
RE: signs that i need new piston rings - 10/2/2008 9:01:10 PM
kidsoncoffee
ORIGINAL: toyazman76
You got hosed.  It shouldn't cost more than $125 for the piston, rings, and wrist pin.  About $40 for the neccessary gaskets.  $50 tops for the bore and hone.  Tops $10 a piece for the 2 valve oil seals.  Chalk on another $10 for a few cans of carb cleaner to get all the carbon residue off the head and you should be good to go.  This is if you're gonna do it yourself.
2008 Big Bear 400 4x4
Extreme Products 2" Lift
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
55W Halogen on the Back
More to come......
1999 Yamaha Kodiak 400 4x4
2" Home made bracket lift
1.5" Snorkel
DynoJet Kit
UNI Filter
27" Swamplites on 14" ITPs
RE: signs that i need new piston rings - 10/3/2008 7:12:49 AM
tytyrecon
ive already replaced the rings and cleaned everything up and it only cost me $80 for rings and gaskets but im hopeing thats all i need
00 recon
no winch
jeep taillight
hit me up!!
(in reply to kidsoncoffee)
RE: signs that i need new piston rings - 10/3/2008 5:44:10 PM
kidsoncoffee
Did you hone the cylinder before you put everything back together?
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
More to come......
1.5" Snorkel
DynoJet Kit
UNI Filter
RE: signs that i need new piston rings - 10/4/2008 10:58:12 PM
tytyrecon
what is honeing the cylinder
00 recon
no winch
jeep taillight
hit me up!!
RE: signs that i need new piston rings - 10/5/2008 11:47:43 PM
longdude17
oh my.....when you change the rings your suppose to hone the cylinder  to give the new rings a good new fresh seating surface...else your pissin in the wind by JUST changing the rigs if you have ANY kind of scoring or scratches in the cylinder walls.
05 kodiak 450 4x4 Camo....currently puking smoke...Up for trade
26" ITP Mudlites
homemade snorkels
CnC Machined Muffler Power tip
K&N air filter
12 point deer horns on the front rack
Lookin for a good Mechanic to rebuild
92 blue kawasaki bayou 220 (the blue beast)
UNI filter
Super Swampers
12 point deer horns strapped to front rack
08 Honda Rancher-Lil Red
Stick Stoppers and Basket Racks
27" ITP Mudlites
soon to come: PCIII, HMF, Springs
RE: signs that i need new piston rings - 10/6/2008 7:19:39 AM
tytyrecon
so what would i need to do to hone the cylinder?
00 recon
no winch
jeep taillight
hit me up!!
(in reply to longdude17)
RE: signs that i need new piston rings - 10/6/2008 8:03:32 PM
kidsoncoffee
If I were you, I'd take the cylinder and piston up to a machine shop.  The machine shop can tell you if your piston is even in spec with the cylinder anymore.  If it is, and it's not egg shaped or scarred up too bad, then have them hone it.  Then you can reinstall the components.  Make sure to use plenty of motor oil as a lubricating agent when installing these parts.  If you don't have some piston ring pliers, I would recommend them, otherwise you could bend a ring and waste $30.  Get a friend to help you compress the rings as you put the cylinder back over the piston.  Also make sure to align the ring openings correctly, if not, you'll have oil blow by and have to take it all back apart.  I'm sure one of the honda guys can give you a pic of where the rings need to be aligned.   You'll also need the torque specs for the head bolts.  And I'd go ahead and adjust the valves while you're in there.  Good luck to ya.
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
More to come......
1.5" Snorkel
DynoJet Kit
UNI Filter
RE: signs that i need new piston rings - 10/6/2008 8:35:28 PM
tytyrecon
ok thnx 4 all the info
what is a machine shop
is it like a machanic place
00 recon
no winch
jeep taillight
hit me up!!
RE: signs that i need new piston rings - 10/6/2008 9:47:46 PM
kidsoncoffee
Yellow Pages + Machine Shop = Where you need to go.
Custom 2" Snorkel
27" MudZillas
2 Front Apes
DynoJet Jet Kit
UNI Filter
More to come......
1.5" Snorkel
DynoJet Kit
UNI Filter
RE: signs that i need new piston rings - 10/7/2008 7:59:08 AM
tytyrecon
lol thnx
00 recon
no winch
jeep taillight
hit me up!!
RE: signs that i need new piston rings - 10/7/2008 9:38:43 AM
longdude17
dude before you go rippin the motor apart...spend a few days researchin your bike, reading and askin questions...if you dont know what your doin your gonna get in over your head real quick....and cause more problems to your bike than you fix.
+1 for coming here and askin what to do...your on the right track.
26" ITP Mudlites
homemade snorkels
K&N air filter
UNI filter
Super Swampers
27" ITP Mudlites
Post #: 22
RE: signs that i need new piston rings - 10/7/2008 9:47:48 AM
sscard
find atvtech in the honda forum, he will have all necessary honda info, gaps, compression lbs, etc
but ring position should be on the new piston and if i remember correctly it has 5 rings total 1 oil ring with two keepers, and two compression rings, the compression ring gaps should go one to the left of bike and one to the right of bike
the oil ring split should go to the rear and the keeper rings make a y facing forward, one toward front right wheel and the other to the front left wheel
drop one new ring into the cylinder before proceding and use a gap tool to find the ring clearance, that will tell you right off if your cylinder is ok, and look for gaps behind the ring to tell if cylider is out of round or egg shaped, but since you have swamped it multiple times, im guessing you are getting an overbore, while you are doing that split the cases and clean em, not just a little bit, but completely clean every little spot or youll be back in there again soon, hondas are notorious for holding mud, and order a new oil cooler too, those hold mud
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
Pink Dipped Plastics
Post #: 23
RE: signs that i need new piston rings - 10/7/2008 11:00:00 AM
YAMAFORD
You have the perfect bike as your first to rebuild if your doing it yourself. go ahead and take off the plastics this time so you can see what you are doing and get a better understanding of whats going on. you have a pushrod engine, its different than 80% of the other brands bikes in that you dont have to wory with timing the cam after doung a ring job. The best advice I can give you from way over here is ...
PUT CLEAN RAGS AROUND THE ROD UNDER THE PISTON AS SOON AS YOU REMOVE THE CYLINDER.
You don't want to drop anything down in there or you will be in over your head.
Kelvin http://photobucket.com/yamaford
funny vid
MINE
04 660 black
27" SB's CATVO's 10" lift
WIFES
660 RHINO CAMO 28" mudzilla's ss212 black wheels Pioneer CD and 4 Alpine 6x9's.
(in reply to sscard)
Post #: 24
RE: signs that i need new piston rings - 10/7/2008 11:09:05 AM
sscard
a while back i was changing the top end on my grizzly and dropped a nut down the timing chain slot, got a long telescoping magnet and was living right that day, i got it out first drop, and it was way down there by the flywheel
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to YAMAFORD)
Post #: 25
RE: signs that i need new piston rings - 10/7/2008 11:30:21 AM
YAMAFORD
sscard thats a good hole to drop it down. wort case senerio you gotta pull the side cover. 1/2 inch the other way and you'da been hanging the grizzly from the rafters upsidedown shaking it. . I've split cases before only to find the piston pin clip on the shop floor the next day. talk about a bad week.
funny vid
MINE
04 660 black
WIFES
Post #: 26
RE: signs that i need new piston rings - 10/7/2008 3:30:17 PM
tytyrecon
ORIGINAL: longdude17
ive already done it once
00 recon
no winch
jeep taillight
hit me up!!
Post #: 27
RE: signs that i need new piston rings - 10/7/2008 3:58:29 PM
tytyrecon
what im gonna do is take it all apart and take the piston and cylinder to a machine shop then put the new rings on and put it all back together after cleaning everything
00 recon
no winch
jeep taillight
hit me up!!
Post #: 28
RE: signs that i need new piston rings - 10/8/2008 5:58:32 PM
YAMAFORD
sounds good to me so long as he doesn't tell you you need a new piston.
funny vid
MINE
04 660 black
WIFES
Post #: 29
RE: signs that i need new piston rings - 10/9/2008 7:51:27 AM
tytyrecon
yea true that
00 recon
no winch
jeep taillight
hit me up!!
