shimming the primary
All Forums >> [OEM Discussions] >> Suzuki >> shimming the primary Page: [1] 2   next >   >>
shimming the primary - 3/29/2008 3:53:52 PM
full mod. king quad
I finally got some pics of the primary shim mod, the demension of the shim is 22mm ID and 32.5mm OD and it needs to be 2mm thick, the Nyroc forum has the part number so you can order two 1mm shims from Yamaha but i just gave the demensions (listed above) to a machinest and it took him about 2 hours and $10 and i was out the door.
The primary is the sheave on the right, the shim goes in between the inside half of the sheave and the spacer.
2001 Yamaha Kodiak
2005 King Quad GREEN
http://www.us-atv.com/
RE: shimming the primary - 3/29/2008 3:58:53 PM
full mod. king quad
My finger is on the added shim, i had my machinest make the shim out of brass so it wouldn't rust. You can clearly see how much lower the belt rides by looking at the dark place going around the outer edge of the sheave, before the shim, it was right on the edge. Best mod for the money as far as im concerned, lower gear ratio and better engine braking.
2001 Yamaha Kodiak
(in reply to full mod. king quad)
RE: shimming the primary - 3/29/2008 4:53:10 PM
kingkev
The part numbers for the Yamaha washers that everyones buying is.They usually get one 1 mm washer and two 1/2 mm washers for a little adjustably.
90201-222F0-00   1/2 MM
90201-225A4-00   1 MM
ps (hope you don't mind the treadjacking full mod)
< Message edited by kingkev -- 3/29/2008 4:56:45 PM >
05 King Qaud,K&N filter,VDI Copperhead CDI,Yoshi exhaust,EPI clutch kit,WCRP a-arms,29.5 Outlaws on ITP SS108s for the mud,27 in. Mudlites for the trail,XPATV 3" lift.
RE: shimming the primary - 3/29/2008 8:05:11 PM
4man0822
     full mod. king quad Is it a night & day difference? Just wandering, getting a list of future projects! Ha! Ha! Later....Brandon
4 a single, she hauls!!
filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& **** 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
RE: shimming the primary - 3/29/2008 8:28:55 PM
full mod. king quad
ORIGINAL: 4man0822
Yes, there is a big difference, definitly put this one on your "to-do" list, it's easy and quick.
ORIGINAL: kingkev
90201-225A4-00   1 MM
I don't mind at all, KingKev.......
2001 Yamaha Kodiak
(in reply to 4man0822)
RE: shimming the primary - 3/29/2008 10:42:57 PM
4man0822
ORIGINAL: full mod. king quad
ORIGINAL: 4man0822
ORIGINAL: kingkev
90201-225A4-00   1 MM
    10-4. Most of us Honest folks don't mind, especially when it's on topic, helpful, & most of all HONEST! Ha! Ha! LOL! I know most of us know who I'm referring to, huh?....Brandon
RE: shimming the primary - 3/30/2008 6:57:50 AM
kingkev
I didn't think so....
RE: shimming the primary - 3/30/2008 3:41:23 PM
kinglivinbig
why yamaha shims
Dont follow me you wont make it
2006 King Quad 700
Project new life
Tow rig
Its TEXAS I ride were I roll.
(in reply to kingkev)
RE: shimming the primary - 3/30/2008 4:24:55 PM
full mod. king quad
Because they have the ID and the OD that you need for the mod.
2001 Yamaha Kodiak
(in reply to kinglivinbig)
RE: shimming the primary - 3/30/2008 4:33:07 PM
kingkev
ORIGINAL: kinglivinbig
why yamaha shims
It was what the guy that originaly did this mod and showed the rest of us used.He did this mod on a 660 grizzly he had before he got a king.
RE: shimming the primary - 3/30/2008 8:42:46 PM
kinglivinbig
how long did it take to do this mod i would l8ike to befor nats but i only have about 1-2 hours of time between now and then
2006 King Quad 700
Project new life
Tow rig
RE: shimming the primary - 3/30/2008 9:57:26 PM
kq700rider
Have you ever messed with the clutch?  If your not mechanically inclined, I wouldnt recommend that you get into the clutch assy.
06 KQ 700 Black, 29.5 Outlaw Tires, VDI, HMF, M109inj, ITP Series 5 rims, 1.5" HL Spacers, HL Clutch/lime green spring,Coop Mod, HL Springs, HL Radiator & Relocation kit, 3"XPATV Lift, Fully Snorkeled, Twin Air, Warn XT25 and a few other things
Pictures & Videos
RE: shimming the primary - 3/30/2008 10:04:08 PM
Solitude
I could get this mod in and on in about 15 minutes cause Ive taking this clutch apart so many times haha.
07 Yamaha Yellow Rhino 660 SE - 2" Lift with 27" Zillas on Chrome 112's
06 Suzuki King Quad 700 EFI - 8" SLC Lift with 29.5x10 Outlaws on Black Torks
02 Yamaha Grizzly 660 SE - 26" Mudlites on MSA Black Torks
94 Honda 300 - USA EDLS, Black ITP SS 212, 2" Lift, Progressive 512 Shocks, K&N, Custom Exhaust, DynoJet Kit, Snorked, Disk Brakes, HL Clutch Kit, Savant Floorboards
RE: shimming the primary - 3/30/2008 10:06:03 PM
kq700rider
ORIGINAL: Solitude
Im the same way.  Part of my routine maintenance.
Pictures & Videos
(in reply to Solitude)
RE: shimming the primary - 3/31/2008 2:16:56 PM
kinglivinbig
man i know how to ride it thats about it
2006 King Quad 700
Project new life
Tow rig
(in reply to kq700rider)
RE: shimming the primary - 3/31/2008 5:02:13 PM
kq700rider
then you shouldnt be doing any major maintenance or mods by yourself.  Find someone to show you how to work on your bike so you will be more familiar with it so if something does happen, you can work on it yourself.
Pictures & Videos
RE: shimming the primary - 3/31/2008 5:04:06 PM
Solitude
Well I agree with you kq700rider but the way I learned pretty much everything I know was going out to the shop and tear it apart and put it backtogether the same way I took it apart. A clutch is pretty self explanatory so it wouldnt be to bad of a place to start. Just go and read some how tos like I did and it should be pretty easy.
RE: shimming the primary - 3/31/2008 5:18:33 PM
full mod. king quad
Take some pictures to, that might help when you put everything back together. Good luck kinlivinbig, you'll need it......
2001 Yamaha Kodiak
RE: shimming the primary - 4/2/2008 4:19:10 PM
billybob36703
what is the advantages of adding the shim
< Message edited by billybob36703 -- 4/2/2008 4:29:55 PM >
2007 kawasaki brute force 750
14in. SS212 with 28in. Zillas
TOW RIG 1999 GMC Seirra Z71 Readylift Leveling Kit 305/55/R20 Nitto Terra Grapplers
RE: shimming the primary - 4/2/2008 4:22:19 PM
BigRickRollin
better low end torque, I believe
I'M SOFA KING WE TODD DID
05 Camo Vinson Auto
Custom 2" lift
HL Springs
Fully Snorkled
K&N Air Filter
LRD Torc Exhaust
FMF Jet Kit
1/8" Slide Mod
Lime Green EPI Spring
Custom Rad. Relocate
26" MudLites
(in reply to billybob36703)
RE: shimming the primary - 4/2/2008 4:31:12 PM
billybob36703
will it hurt me any on top end
< Message edited by billybob36703 -- 4/2/2008 4:37:39 PM >
(in reply to BigRickRollin)
RE: shimming the primary - 4/2/2008 5:05:09 PM
4man0822
ORIGINAL: billybob36703
    Yes, but not really sure as to how much!  I've heard kinda mixed reviews on it, sooooo . I may do it eventually, but not until I can do the fixed sheave mod also. That gives you what you lost on top-end +, so this is very promising!  Hope this helps....Brandon
Post #: 22
RE: shimming the primary - 4/2/2008 6:07:35 PM
full mod. king quad
You'll lose 5 to 8 mph (it depends on the quad) on the top end when you add the shim. A small price to pay for the added low end grunt.
2001 Yamaha Kodiak
Post #: 23
RE: shimming the primary - 4/2/2008 6:07:50 PM
billybob36703
ok thats the one thing i was worried about i dont wanna lose my top end
Post #: 24
RE: shimming the primary - 4/7/2008 8:19:29 PM
KingPitcher700
Is this as good as a clutch kit or is it even close. how would it be to do this mod and drill the weights to 18g.
07 KINGQUAD 700 4X4
WARN 2500LB WINCH AND MOUNT
WARN FRONT BUMPER
K&N FILTER
29.5" OUTLAWS
FULL SNORKELS
REVERSE LIMITER MOD
REVERSE LIGHT MOD
DIFF LIMITER MOD
3" XPATV LIFT
HMF UTILITY PIPE
HMF OPTIMIZER GEN 3
EPI YELLOW SECONDARY
2MM SHIM
COMP STALL WET SPRINGS
12X7 MOTOSPORT ALLOY TORKS
Post #: 25
RE: shimming the primary - 4/7/2008 8:26:57 PM
swampedeiger
can i do this on my bike? how much will it help if it will work?
Eiger
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=95006984
Post #: 26
RE: shimming the primary - 4/7/2008 8:56:16 PM
4wheel4eva
imgonna do it tomorrow the 9th and ill let ya know,using 1mm shim
07 eiger 2"lift, 27" outlaws, gorillya axles, 1 1/2' spacers, jetkit, slide mod, 2'snorkle all around, baffleless
(in reply to swampedeiger)
Post #: 27
RE: shimming the primary - 4/8/2008 5:38:21 PM
full mod. king quad
ORIGINAL: KingPitcher700
It's not as good as a clutch kit but as far as the price and the ease of doing it, it's a real good mod. to do.
ORIGINAL: swampedeiger
You should be able to but make sure you have at least 2mm of spline going into your roller plate.
ORIGINAL: 4wheel4eva
Did you get it done yet?? How did it turn out for you??
2001 Yamaha Kodiak
(in reply to KingPitcher700)
Post #: 28
RE: shimming the primary - 4/8/2008 11:47:54 PM
4wheel4eva
i didnt atempt it today cuz i got stuck grinding the right rear bearings out and replacing them  i have some questions about shimm mod, does the clutch engage like its geared lower and the whole powerband is geared lower, or it geared lower only when going slow? im debating if i should just do it cuz its easy and to tell yall or my wheeler turns the tires fine,im most likely gonna do it tomorrow and stop procrastinating
Post #: 29
RE: shimming the primary - 4/12/2008 2:10:22 PM
4wheel4eva
the shim  i tryed was 3.5mm thick, way to thick and i cant find the site to the yamaha shims, so when i get a yamaha shim i will do this mod and tell yall how it does on my eiger. BTW can i ruffen up my primary sheeves for more pull?cuz they are almost shinny and waivey
(in reply to 4wheel4eva)
Post #: 30
