Setting up a 500m , this is all just my opinion on what needs to be done to one to spin BIG tire correctly. 1. snorkel with a 2" snorkel. and Dielectric grease every plug or connector you can get your hands on. and Move the Radiator up on the rack it will save you headacks down the road. also seal up the pull start as it does not have a gasket on it and will fill up with water and rust up never to work again..lol 2. Need a High flow muffler, Black Magic , Super trapp Mudslinger or Speed werx muffler. 3. Dyno jet kit, with the slide mod and the spring clipped.. jet size around a 148 150 or 155 with the needle on the 4th knotch and something close to a 42 pilot 2 turn out. this is a starting point for jetting as all motors are different. 4. EPI clutch kit, well worth the money and time to do it ( about 2hrs or so) the cheap $49 kit works just fine 5. Web cam , with a pc680 battery other wise it will be hard to start. 6. 4.0 diff gears, i would do these gears first as it takes away the most stress from the bevel gears. imop 7. 18% gear reduction at the clutches. 8. anything over a 2" lift will need new axles and tie rods, and a 2" lift will try to pull the fronts out if the shocks are ran on max settings. (I think with all this done a 500m would spin up to 32s and clear them with a 2" lift.) from here down is just more Power..lol 9. Their is a 581bbk for it from F. S. tech. 10. Also a stroker crank for it from Turners as well.. 11. NOS system dont run over a 10 shot on it. jmop think thats it.. 05 500m with a home built 3" lift... Thumbnail Image
Attachment (1)
08 650H1 LE Warn 3.0 Snorkeled,Rad relocated Custom mounted gauges muffler tweaked Dynojet, slide mod, spring clipped Custom clutch kit, 4.0 gears HL springs, HL spacers "G" axles 29.5 Laws on custom LE wheels 30" MLs on Black Castle Roks 05 500m Dynojet,slide mod spring clipped muffler tweaked Hidden snorkel HL temp gauge 26" 589MTs on ITP type 6s Hard.Pack.Arctic.Cat
