sealing up belt housing
All Forums >> [OEM Discussions] >> Can-Am BRP >> sealing up belt housing Page: [1]
sealing up belt housing - 10/6/2008 3:44:39 PM
muddslinger03
i snorkeled out my outty this weekend and went riding yesterday and it got a little bit of water in it and after reading some posts ive come to the conclusion that its leaking aroung the belt housing. how hard is to take off the cover and silicone around it?
06 can am outty 800, HMF exhaust, custom snorkel, 2" RD lift, 28 " silverb****
07 honda rincon, SS 112 ITP's 28" Silverb****, Dynatek Programmer, HMF exhaust, 3" xtreme atver lift, custom snorkel kit.
98 chevy z71, 9" of lift, 37 mud grapplers,
RE: sealing up belt housing - 10/6/2008 3:53:03 PM
Justin Q.
http://www.youtube.com/watch?v=RygvYcsk5mo
That should do the trick.
2007 Can-am Outlander 650
30" Backs
14" Moto Sport Climax
Pipe lift front & rear
Aaen exhaust
Custom snorkels
Custom Suzuki SV taillight
PM me for the best atv mechanic in the baytown area.
(in reply to muddslinger03)
RE: sealing up belt housing - 10/6/2008 4:09:37 PM
007BF
The easiest thing to do is upgrade the rear cover and you won't have problems.
I-45 RACING
powered by Pit Proven Performance
Russell Coker #55
Texas A&M class of 07'
WHOOOOOP!!
C.M.R POINTS SEASON FINAL
1st OPEN/PRO SWAMPCROSS
1st CLASS 1 MUD BOG
3rd CLASS 2 SWAMPCROSS
3rd CLASS 2 MUD BOG
(in reply to Justin Q.)
RE: sealing up belt housing - 10/6/2008 4:17:36 PM
muddslinger03
who sells the upgrade kit?
(in reply to 007BF)
RE: sealing up belt housing - 10/6/2008 4:20:16 PM
bushhog750
being that yours is the 06 madel yours may leak around the rear housing where it meets the motor. but it may not also. it is really simple to seal between the covers. just undo all the clutch cover bolts. put a bead of silicone around the stock gasket and reinstall be sure not to tighten the outside cover bolts to tight or they will strip the inner cover nuts loose. tighten them til they stop then torque just a touch more all the way around.
08 outlander 800 red- MaD Cannon tuned- snorkled- vented- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- 6orilla radiator relocate- ricochet skid plates- xt front bumper- coolanol radiator fluid- crankcase vent mod- amsoil fluids- sponsored by VISA and 60 hours a week.
(in reply to 007BF)
RE: sealing up belt housing - 10/6/2008 4:21:56 PM
bruterecoveryman
It is a can am service bulletin, that may be covered under warranty. the easiest way to check the belt housing for leaks is to fill it up with clean water and find out where you are getting water leaking out. Then seal it up in that area. but I reccomend the upgraded backing plate. The original ones have a history of warping.
RE: sealing up belt housing - 10/6/2008 4:41:01 PM
muddslinger03
do i have to take off the floor board and foot pegs? working on four wheelers is something i used to but this is my first belt drive wheeler
RE: sealing up belt housing - 10/6/2008 4:42:08 PM
bushhog750
no you dont have to remove the floorboard but it will give you a lil more room if you do.
RE: sealing up belt housing - 10/6/2008 4:44:15 PM
bruterecoveryman
what he said
It will make getting to the bottom bolts a little easier if you take them off but it isnt a must
(in reply to bushhog750)
RE: sealing up belt housing - 10/7/2008 4:00:23 PM
matprice
mine and my wifes was warped so bad you could stick you finger inbetween the seals... get the upgrade even if it is out of warrenty its only a 60 dollar part if your in war. it is covered it will be 50 bucks for your deductable with your bst coverage... i am sure its been 6 months since 2006...
Mat Price
BitMore Performance Race Team
mine BITMORE TUNED
2007 Can Am 800 Outlander
2007 outlander 800 xt
RE: sealing up belt housing - 10/7/2008 4:36:24 PM
Truservon
In some cases the outer housing has been known to warp due to the heat from the exhaust.
Adam (MS Mud NutZ)"Ladner -n- Lafontaine Race Edition"
Fueled by COMPETITION SPORTS-Gulfport,MS
BITMORE TUNED
Rollin on Crushloks
www.msmudnutz.com
www.myspace.com/truservon
www.myspace.com/msmudnutz
(in reply to matprice)
RE: sealing up belt housing - 10/7/2008 4:52:16 PM
muddslinger03
where do i get the upgrade kit? from a dealer or from a website? and also where do i get the tools to take the belt pulleys off?
< Message edited by muddslinger03 -- 10/7/2008 4:54:00 PM >
(in reply to Truservon)
RE: sealing up belt housing - 10/7/2008 6:32:47 PM
bushhog750
The dealer will have or order the upgraded housing and tools can be bought on line or from the dealer.
RE: sealing up belt housing - 10/11/2008 6:43:45 PM
bar5721
cyclepartsnation.com sells the upgrade get and it will not leak anymore ... i have a 07 and had to upgrade mine when i snorkeled it... i havent had a problem since...
Can am 800 ...yellow with 28 inch ****s on some 108 SS rims 12inch and 2 inch highlifter lift... and ram cup holder... snorkled ,, HMf quite racing series pipe and hmf programer... custom radio..
04 Honda foreman 450 with snorkel and hmf ,, jet kit... 26 inch vampires with ITP rims... gun rack.. highlifter spring kit.. 3,000 pound warn winch..
RE: sealing up belt housing - 10/11/2008 7:00:28 PM
got wake?
some people who have had their dealers update the backside of the CVT cover still get water in through it.  i trust sealing it up myself or making sure the dealer seals it when they install the new one.
(in reply to bar5721)
RE: sealing up belt housing - 10/11/2008 8:46:53 PM
Superchunk5000
ORIGINAL: got wake?
Just don't use too much or it will push your gasket out and let the water back in...LOL
08' Can Am Renegade 800
27" ITP M/S 589's
Dalton clutch kit
Snorkeled & radiator relocated
(in reply to got wake?)
RE: sealing up belt housing - 10/11/2008 9:31:27 PM
got wake?
or maybe the gasket got caught on something when some half tard was installing it way past his bedtime...   i don't see how to sealant would push the gasket out, so i'm more inclined to believe that when i was aligning the cover i may have bumped it out of place.
(in reply to Superchunk5000)
RE: sealing up belt housing - 10/11/2008 10:03:16 PM
Superchunk5000
27" ITP M/S 589's
Dalton clutch kit
0.688
