psycho ward
Carb bikes Must be jetted properly once it is snorkled. Some can adjust them enough with the same jets to make it run good. The engine is now getting the same amount of fuel it needed with a short air intake pipe, and is sucking thru a straw (snorkel) , which causes it to flood out and run rich. If the needle valve has notches on it ,try raising the e-clip one notch at a time to get it working better,then adjust the mixture screw (not idle screw) in to lean it out some.
07' Can Am 800 renegade (stealth snorkeled), 28" S-Backs on vision 159 rims,Dalton clutch kit, BRP pre filter sock,UNI filter , HMF Penland pro pipe, BRP rear hitch,and Pro Taper handle bars with death grips, custom home made bumper with diamond plating,LED Brake light, 650 helix mod, and diamond plate home made front CV guards 04' Sea-Doo RXP Stage III + (81.3mph on GPS) and still tuning
