rhino bogging
rhino bogging
All Forums >> [OEM Discussions] >> RUVs (Recreational Utility Vehicles) >> rhino bogging Page: [1]
rhino bogging - 11/28/2008 6:07:15 PM
93 Cobra
What's up guys, I just bought a 05 rhino 660 a few weeks ago. I've rode it around the house for a while the last two weeks and everything was great. I took it trail riding today and after a couple of hours the bike was pitching me some fits.
The bike will run fine sometimes then all of a sudden it will feel like it is bogging down and not want to rev, then if I let of the gas going slow it will back fire and try to die. Any suggestions? I was thinking the fuel filter might be getting clogged. It looked pretty rough.
The only thing I did to the bike was put a tank of 93 in it, and a half a bottle of carb cleaner (bottle said it was good for 15 gallons).
RE: rhino bogging - 11/28/2008 6:42:22 PM
r6realtor
my guess would be the fuel filter, start there.
2009 Polaris RZR
26x9x14/26x11x14 terra cross w/Black ss108 wheels, walker evans suspension, rear cage/seats. 3000# venom winch, skidplates, , shock covers, lock and ride accesories.
2009 Yamaha rhino 700 Camo
26x9x14/26x11x14 terra cross w/Black ss212's. GPS holder.
(in reply to 93 Cobra)
RE: rhino bogging - 11/28/2008 8:49:07 PM
neverrideahonda
Use 87 octane. Higher octane is a waste and your bike will run better on 87. Change the fuel filter, keep some in the glove box. You will change them often.
Chad Broadus
www.undergroundatv.com
Home of Team Tipsy aka "The Party Crowd"
If you don't stand behind our military, maybe you should try standing in front of them.
(in reply to r6realtor)
RE: rhino bogging - 11/28/2008 8:53:13 PM
Solitude
Yea why do you change them alot, I have to change mine on about every ride afterwards. Get this silicone looking stuff in there.
06' SLC Lifted King Quad 700 EFI For Sale: http://easttexas.craigslist.org/mcy/960791955.html
94' Honda 300 4x4
EDL's, ITP Black 212's, Lift, Progressive 512 Shocks, DJ Kit, K&N w/ Outerwears, Savant Floorboards, Gear Reduction, EPI Clutch Kit, XP Disk Brakes, Snorkles, Gutted Exhuast, Pro Grips
(in reply to neverrideahonda)
RE: rhino bogging - 11/28/2008 8:56:35 PM
dbmachine
the fuel filters stop up really fast which is a good thing but not good to be stranded somewhere..
(in reply to Solitude)
RE: rhino bogging - 11/28/2008 11:38:34 PM
r6realtor
ORIGINAL: Solitude
it's the silicon that yamaha used to seal up the were the fuel line goes in the gas tank, it starts to disinagrate and fall in the gas tank because of gas and gas fumes, If you take the passenger seat off I think??(I haven't owned a rhino for years now) but there is 3 small bolts holding the fuel line in,, if you take them out and the plastic thing they are holding down you will see the silicon pull up with it. I redid mine years ago with a better more gas resistant sealant.
< Message edited by r6realtor -- 11/28/2008 11:39:45 PM >
2009 Polaris RZR
RE: rhino bogging - 11/29/2008 12:34:59 AM
93 Cobra
Really, I thought the owner manual told me to run 91 or higher. I will have to look again. I understand the whole octane thing, I figured the 660 had a decently high compression ratio to require it.
RE: rhino bogging - 11/29/2008 8:26:49 AM
neverrideahonda
No, 87 is fine. I even ran mine with 87 after putting a 12.5:1 hi comp piston in it. 87 is plenty fine for stock. You can buy the fuel filters for like $2 at auto zone. Just bring your stock one in and they can find one that will match up.
Chad Broadus
RE: rhino bogging - 11/29/2008 9:09:10 AM
93 Cobra
Will do thank you guys!
RE: rhino bogging - 12/1/2008 1:12:47 PM
lilhenkeg
93 Cobra
my has done this twice........it was the fuel filter both times......i dont know how but i am managing to get a little dirt in my tank
Henk's Toys
2007 Yamaha Rhino,
HMF
Bayou Snorkel
ITP SS112's
30" Budlites
2009 Black Brute 750i
-3" lift
-14" SS112's
-30"S-bakcs
-HMF Penland
2008 GMC Sierra 1500 4x4
size]
-- Limo
--Aero Turbine Muffler
http://s396.photobucket.com/albums/pp45/henkeg03/
RE: rhino bogging - 12/1/2008 5:08:52 PM
93 Cobra
I put on a new fuel filter, and changed the spark plug. Almost seems to run stronger then when I bought it. Hopefully that was the problem!
(in reply to lilhenkeg)
RE: rhino bogging - 12/1/2008 5:42:02 PM
r6realtor
ORIGINAL: 93 Cobra
it's good you changed the plug but you probably didn't need to, I could almost bet it was all the filter, definitely carry extras and don't forget to clean that silicon out of the top of were the gas line goes in the top of the tank because it will continue to clog the filter.
2009 Polaris RZR
RE: rhino bogging - 12/1/2008 7:10:11 PM
southTXrhino
i am starting to have that same problem, i need to check my filter also...but another problem that i just started  having it my rhino is starting to smoke a little like its burning oil???? i just got done puting a jet kit,clutch kit and exaust on it and when i took it to the trails (for the first time after the mods) this weekend it is starting to smoke out the exaust like i need new rings??? but it had never done this before, any suestions, i really dont want to tear the motor apart
2006 Yamaha Rhino 660
EPI Clutch
28 Swamp Lites
HMF
Dyna Jet
Full Snorkel
Overhead stero W/Speakers
Ice Chest Full of beer
RE: rhino bogging - 12/1/2008 7:18:26 PM
neverrideahonda
Yeah, get it on an air\fuel reading device of some sort before you burn it up. When you snorkeled it they are very hard to get adjusted right. Almost impossible without some sort of oxygen sensor. Are there any dynos close to you?
Check your spark plug. Make sure of the color.
Chad Broadus
(in reply to southTXrhino)
RE: rhino bogging - 12/1/2008 7:23:04 PM
southTXrhino
there are no dynos close to me that i know of....do you think that i should try a different jet and new plug and wire??
EPI Clutch
28 Swamp Lites
HMF
Dyna Jet
Full Snorkel
RE: rhino bogging - 12/1/2008 11:30:42 PM
Dirt2race
If you want to check the fuel/air mixture, you can go to any body that does inspections for cars. Have them put the O2 sensor up the pipe and let you know where the count is. If you feel comfortable, you can weld a bung in the header pipe and use a portable O2 sensor from an auto parts store. Put the guage in, read it, remove the guage and install a plug in the bung. I'm sure some one here can tell you where it should be. Good Luck
2007 Renegade w/ the following MRRPM upgrades, 1004cc BBK, custom Comet clutching, head pipe w/ HMF, custom stretch, aluminum tire clamps, 29.5 Laws, PCIII
2008 Outty Max 800, under construction w/ the following MRRPM ugrades, stock cylinder BBK, head pipe, cams, valves, HMF, aluminum tire clamps, 29.5 Laws, PCIII
2008 Outty 650, XT, 26" Zillas, wifes ride
2009 Polaris RZR, that's right I said Polaris, tired of waiting on the Can-Am SXS, 28" Zillas
2008 ECMR Super Stock and Outlaw Champ
RE: rhino bogging - 12/2/2008 9:14:17 AM
neverrideahonda
What color is your plug?
Chad Broadus
(in reply to Dirt2race)
RE: rhino bogging - 12/2/2008 6:57:30 PM
southTXrhino
i dont know i am out of town for work but i will be back thursday, any certain color that i should look for and what dose the color indicate...its runing to rich or lean??
EPI Clutch
28 Swamp Lites
HMF
Dyna Jet
Full Snorkel
