rancher 350 water help
All Forums >> [OEM Discussions] >> Honda >> rancher 350 water help Page: [1]
rancher 350 water help - 8/23/2008 8:47:30 PM
ga300
ok guys i have tried looking but came up with nouthin.here we go i have been tryin to fix my 4 wheeler for a while now every time i get in the water it shuts off.at first i thought maybe got crap in the carb so i clean it out really good didt fix it.yes check valve is plugged.well i got to ride it this past weekend and i found that i can just push it into the water and right when the the motor gets maybe up to a inch in water it shuts off.oh yea and when im doin this im holdin the carb line so i know its not that.so now i know its eletrical so what wires right there that go into the motor?  oh yea all plugs have dieletric grease and i have looked at the wires and see no rubbed threw marks.  any help very welcomed
RE: rancher 350 water help - 8/24/2008 7:44:21 PM
ga300
any help
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 8:06:58 PM
02rancher350
Thanks werid because only a 1'' high up the motor that a ways away from the plug so that couldn't be the proublem with it gettign wet. whats the carb drain line plugged with??
02 Honda Rancher 350 ES 4x4
-26'' Mud bugs on Itp C4's
-SW 2.0 winch
-HMF pipe
-Warn 424
-Dyno jet kit
-Snorkled
-H/L leak sheild
-Kimpex Front bumper
-Quadrax rear bumper
-Uni airfilter
-Outerwears prefilter
-Powermadd handguards
-H/L bash plate
-Moose cv guards
-Moose 2-up seat
-Vent lines to the pod
-Reverse mod
-Carb drain pluged
-Pro grips
-H/L bearings
-Front box w/ strobes & Radio
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 8:08:58 PM
ga300
just a bolt
(in reply to 02rancher350)
RE: rancher 350 water help - 8/24/2008 8:13:12 PM
buzz007
I cant tell by your pic,do you have it snorkled?
2006 foreman 500 es Copy-cat snork
HMF SWAMP SERIES
G--RILLER Axles
27'' swamp witch on vision wheels
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
Ricochet skids
"W / TUNES "
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 8:17:47 PM
ga300
yea its a old pic there.it has a taller snorkel now.
(in reply to buzz007)
RE: rancher 350 water help - 8/24/2008 8:20:37 PM
buzz007
Have you tried the "ol water hose on every little piece of it approach". If you know at what level it's happening it should be even easier to find.
HMF SWAMP SERIES
G--RILLER Axles
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
Ricochet skids
"W / TUNES "
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 8:22:16 PM
02rancher350
Well if the bolt fits tight into the line the water should stay out. hmmm well i dono i yes went out and cheaked my bike theres not very many connections that low so i dono about eletrical but you never no ive never had this happen to me ive had it shut off it deep water but that was the plug i need more delectrical again.
-SW 2.0 winch
-HMF pipe
-Warn 424
-Dyno jet kit
-Snorkled
-H/L leak sheild
-Uni airfilter
-H/L bash plate
-Moose cv guards
-Moose 2-up seat
-Reverse mod
-Carb drain pluged
-Pro grips
-H/L bearings
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 8:27:43 PM
ga300
yea that what sucks i tried the water hose and cant get it to act up.aint that the oil temp at the bottom? i also see two wires that go into the motor.
RE: rancher 350 water help - 8/24/2008 8:39:59 PM
buzz007
If thats the case I say make darn sure that bolt you have is plugging the drain line is doing it's job. It also could be that the drain line and/or wires that are at that level are not rotten or deteriorated.    Just let me make sure of this--- I will happen just by gently rolling it into water about an inch of the motor?
HMF SWAMP SERIES
G--RILLER Axles
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
Ricochet skids
"W / TUNES "
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 8:50:36 PM
ga300
yea i will just roll it in and just shuts off.im even holding the drain line never gets wet.
RE: rancher 350 water help - 8/24/2008 9:10:28 PM
buzz007
Man this is wierd,like someone else said there just isnt much at that level to cause this.  HMMM  I guess I'm of no help please let me know what you find out.
HMF SWAMP SERIES
G--RILLER Axles
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
Ricochet skids
"W / TUNES "
(in reply to ga300)
RE: rancher 350 water help - 8/24/2008 9:13:42 PM
ga300
yea deff up date if i find out.
RE: rancher 350 water help - 8/24/2008 9:42:36 PM
hondareconpby98
did you seal the pull start?
2006 honda recon ES
22" mudlites rear
23"mudlites front
2000lb winch
mad dog rack bag
gun racks
A - arm ski plates
for sale $$2500
2005 honda rancher 2wd
offroad lights
gun racks
viper max 2500 with amsteel
custom snorkel
48 inch plow
2005 yamaha fx high output
2004 yamaha fx
2001 suzuki LT 160 for sale
1300$
(in reply to ga300)
RE: rancher 350 water help - 8/25/2008 4:45:50 PM
ga300
yea
(in reply to hondareconpby98)
RE: rancher 350 water help - 8/25/2008 5:00:54 PM
meatman
tyr getting a cheap kiddy pool, put the bike in the pool and fill it up they crank it up. the dollar store might be able to help you
07 honda rincon 680, 3" lift, 27" mud bugs, full skid plates, daul "no cut" snorkels, and then some
(in reply to ga300)
