radiator overflow
radiator overflow
All Forums >> [OEM Discussions] >> Yamaha >> radiator overflow Page: [1]
radiator overflow - 12/2/2008 7:32:39 PM
grizzly guidry
okay my grizzly 700 is snorkeled an i got all my vent lines snorkeled as well.. today i went riding in the back of the house an my radiator overflow ventline started to shoot out hot radiator fluid.. the temp light on the pod came on an couple of times an would just go off.. any idea why it would be doing that??? i mean shooting fluid an overheating???
TEAM "doin it dirty" OFFROAD
07 grizzly 700 fi
29.5 x 10 Outlaws, 4
2"HL lift kit
HL Extreme clutch kit
HL Tripleflow radiator relocation kit
1" wheel spacers
4 monkey axles
HMF Swamp Series Exhaust
PowerComanderIII
UNI airfilter
fully custom snorlkeled
silvastar lights
Ricohet skide plates
yamaha front bumper
2.5 warn winch
http://s37.photobucket.com/albums/e71/wendi_martin_photo/
http://www.doinitdirtyoffroad.com
RE: radiator overflow - 12/2/2008 9:40:40 PM
txjgrizz
make sure you radiator is clean, & your fan is working
'02 660 Grizzly:
29.5-12 Laws, Viper 3500lbs wp Winch, Snorkeld Belt Housing & Vents, HL radiator/fan, Xtreme 2" & HL Springs, Swamp Series XL; Airbox mod & snorkel
(in reply to grizzly guidry)
RE: radiator overflow - 12/2/2008 10:03:02 PM
grizzly guidry
thr fan is working for sure an i always pressure wash my bike an radiator real good after i ride in the mud... the radiator is clean because i was checking it out today after i rode.. an i was just riding on some trails cutting some branch an twiggs to make the trails a little more cleaner.. wish someone could shead some light on my problem because im kinda scared to go ridding an burn the bike up or something...
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
(in reply to txjgrizz)
RE: radiator overflow - 12/2/2008 10:38:51 PM
txgrizz9
there may be your problem you pressure washed you radiator. I did mine once and bent the radiator all up. You need to take it out and check that will be the best thing to do before you over heat your engine and also get stranded
05 Grizz
9'' lift
high rev box
30'' backs
custom snorkel
moose clutch kit
warn bumper
g-axles
fmf exhuast
k/n
jet kit
relocated radiator
monster coil
RE: radiator overflow - 12/3/2008 1:09:23 AM
grizzly guidry
i dont think thats the problem because i looked at it realy good an can only see a couple of fins bent... put it this way i can count the number of fins that or bent on one hand,, but i will try to pull the radiator out this weekend.. an being i have it out an the front all torn down, i may as well relocate it to the front rack... just need to save a little money for the relocation kit.. it just might be awhile before i can get it all back together so i can see if that was the problem.. ANY IDEAS ON THE PROBLEM ANYBODY?????
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
(in reply to txgrizz9)
RE: radiator overflow - 12/3/2008 10:57:51 AM
BNYCE
uummmm, thats happened to me a couple of times on the grizz, bike was just running a little hot no big deal. My light never even came on when it was happening to me. just periodicaly check the fins on the radiator and make sure their clean. nothing to worry about
09 DU grizz 700eps fi
stuff to make it better
RIP 08 bf 750 Metallic Blue, stuff on it
The Wifes
08 BF750 Team Green
PINK SNORKELS
PINK RIMS
PINK AMO CANS
other stuff too
Deep and Dirty ATV Spring TX
Chip Chip
RE: radiator overflow - 12/3/2008 11:01:38 AM
txjgrizz
If your radiator, fan & coolant level is good, That could only leave a few general possibilities. One would be your thermostat, another your water pump, another could be your running too lean which would make the head temp hotter. Maybe put a new thermostat in and see how it does, or you could take it out and put in a pot of hot water on the stove to see if its opening up. Shouldnt be hard to eliminate that.
'02 660 Grizzly:
RE: radiator overflow - 12/3/2008 11:06:51 AM
grizzly guidry
okay i will check my plug an see how it looks... where is the thermostat an water pump located on my bike..
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
RE: radiator overflow - 12/3/2008 11:26:29 AM
txjgrizz
Follow the radiator hose on the right side of the bike to the engine head. The hose connects to a little housing. Remove the housing & the there is the thermostat. Try not to mess up or lose the o-ring.
'02 660 Grizzly:
RE: radiator overflow - 12/3/2008 11:45:40 AM
grizzly guidry
okay.. will look into it in a little while... thanks
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
RE: radiator overflow - 12/3/2008 5:32:44 PM
txgrizz9
your water pump is under you pull starter
05 Grizz
9'' lift
high rev box
30'' backs
custom snorkel
moose clutch kit
warn bumper
g-axles
fmf exhuast
k/n
jet kit
relocated radiator
monster coil
RE: radiator overflow - 12/3/2008 5:43:51 PM
farmerboy700
U could have air in ur lines causin the fluid not to flow!! happened to me
"Team Do Work!!"
700 Grizz
32'' Silverbacks
03 Gorilla Lifted 660
31''Outlaws
07 Polaris Ranger 700
http://profile.myspace.com/index.cfm?fuseaction=user.viewProfile&friendID=58900083
RE: radiator overflow - 12/3/2008 6:55:15 PM
grizzly guidry
the grizzly 700 dont have a pull start...
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
(in reply to farmerboy700)
RE: radiator overflow - 12/3/2008 6:57:09 PM
grizzly guidry
if i would have air in my line's, which line would it be ??? in the radiaroe lines itself ???
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
RE: radiator overflow - 12/3/2008 7:02:56 PM
grizzly guidry
i looked at all the fins an they or all good to go an the radiator is clean... i took the thermostat out an it was like stuck in the open position.. took some needle nose pliyer an wiggeled it an it went back in place... put the thermostat back in an went ridding it did good for awhile but the temp light would come on again then go off.. it shot fluid out the vent line twice an not much at all... you think the thermostat got stuck in the open position again??? will check it out tomorrow morning.. if it isnt stuck in the open position what else could it be???
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
RE: radiator overflow - 12/3/2008 9:15:20 PM
DEEZ
Just something to think about.
Antifreeze doesnt transfer heat from the engine to the radiator as efficient as water.
Antifreeze raises the boiling point & lowers the freezing point of the fluid.
07 Grizz 450
27" laws
Highlifter 2" lift
Backup light that works only in reverse & headlights on
Reverse rev limiter mod to the bypass button
Snorkled intake, beltdrive & sometimes exhaust
All 5 vent lines run to handlebars
Axle guards
K&N filter, 140mikuni jet
Coop45 Mod
My pics
4sale
plug
RE: radiator overflow - 12/3/2008 9:16:25 PM
txjgrizz
If its stuck whether open or close you need to replace it because its not functioning properly. I would think that is your problem.
'02 660 Grizzly:
RE: radiator overflow - 12/3/2008 10:33:25 PM
grizzly guidry
i'll order a new one in the morning an pull the old one out.. you think i should drain the antifreeze out an just put water as was suggestion to think from DEEZ????
< Message edited by grizzly guidry -- 12/3/2008 10:38:37 PM >
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
(in reply to DEEZ)
