lips450
does anyone know if these two items work? 1) ( Procom Magic Power Rev Box) this is what is says... Increase horse power throughout the entire rpm range Increase torque Increase throttle response Increase spark energy Improve fuel efficiency Easier start-runs cleaner Less spark plug fouling Brighter headlights Longer battery life Reduce the radio noise Tips Of Concept: Without our Magic Power Box, when you throttle up your machines, the battery output voltage is unstable; it changes between 11V and 15V, the spark energy is inconsistent and your machine lacks power. With our Magic Power Box, the output voltage will be almost 100% stable. Your machine can reach the maximum power. 2) TWIST-AIR INTAKE COLD this is what it says.. Improves engine performance by up to 10 %. Increases economy, immediately by up to 15 %. Reduces flat spots. Enhances Nm, throttle response, acceleration and low end torque. Results higher top end speed. (does not unblock electronic restrictions) Supercharging effect (aspirated engines) Great air flow with straight motion vector - perfect vortex within intake tract. Crisp throttle response Works in conjunction with other upgrades as resistors, ECU chips, free flow filters, exhausts. Lifetime endurance - 100 % maintenance free product. It will not affect the work of ECU - no adjustment required. Easy 15-minute universal installation to all models. Very noticeable improvement in acceleration and upper RPM performance. More and regulated air means more usable power and acceleration throughout the engine's RPM range. Twist-Air concept was developed to improve low-range and mid-range power, torque and fuel efficiency. This increased air volume and vortex-like air action results a turbulent air and accordingly vehement combustion in the chambers. Twist-Air gives you ultimate performance and super throttle response, reduces air restriction and increases engine power. Special spiral shaped geometry optimizes and speed up the incoming air charge in the intake. This in return gives you tremendous combustion efficiency. More air charge more power. It provides an improvement in both power and economy.
2008 outy 800xt snorkel, uni air filter, dalton clutch kit, hmf exhaust, 1 3/4" front face lift, itp ss 212 rims, 28" outlaws soon to get: dynojet power commander, skid plates l
