paintin plastic
paintin plastic
All Forums >> [OEM Discussions] >> Honda >> paintin plastic Page: [1]
paintin plastic - 11/20/2008 4:48:38 PM
finch801
what is the best way to paint the plastic on your 4wheeler an make it STAY there an not just peel off??? i wanna paint a 300 black if that helps any.
RE: paintin plastic - 11/20/2008 7:39:21 PM
Foreman1989
if you want a good color  i would dye it
(in reply to finch801)
RE: paintin plastic - 11/20/2008 7:40:47 PM
HBrancher
prep it really good and use Krylon Fusion and spray thin layers of it for the best results.
HB MUD MOB
Honda Rancher 400 AT
XP Lift
28in Outlaws
snorkle
HMF pipe
Jet Kit
Project Bike
Honda Foreman 500 S
In the process of HB modifications
(in reply to Foreman1989)
RE: paintin plastic - 11/20/2008 8:25:40 PM
Badforeman475
I did mine with the fusion
Blue 98 Foreman 450 Geared and locked SS112 wheels 28" Silverbacks
Red 07 Foreman 500 Clutch kit snorkled more to come soon
Pic of my bike http://www.myspace.com/blueforeman450
(in reply to HBrancher)
RE: paintin plastic - 11/21/2008 6:54:38 AM
pinetag
Mine is fusion also...
Thumbnail Image
Attachment (1)
(in reply to Badforeman475)
RE: paintin plastic - 11/21/2008 7:21:02 AM
foreman2000
FUSION PAINT DOSENT DRY COMPLETELY RIGHT ?
2000 honda foreman es
custom snorkle
hl lift kit & springs
27 X 10 & 27 X 12 s-backs
hl clutch kit
ebc primary clutches
hmf pipe & uni filter
dynojet 126 and needle
hl spool locker
hl un locker
3000 lb warn
reverse button mod
AND ONE EVIL MONKEY!
*new* 2006 yamaha rhino
upgraded to lcd display
yamaha roof and windsheild
alum stick stops and skids
brp cdi 28 X 10 laws ful
(in reply to pinetag)
RE: paintin plastic - 11/21/2008 8:57:53 AM
HBrancher
ORIGINAL: Badforeman475
what all did you do to prep it first that looks great.
HB MUD MOB
XP Lift
28in Outlaws
snorkle
HMF pipe
Jet Kit
Project Bike
Honda Foreman 500 S
RE: paintin plastic - 11/21/2008 2:44:12 PM
rrsi_duke
good preping and fusion is the way to go, but if want it to last a little longer also use BULLDOG ADHESION PROMOTER as the base coat then use the fusion and you should be good to roll
THA DUKE BOYZ
99 450s foreman / 29.5x10 laws all around / 2" hl lift / hl springs w/ spring spacers / gear reduction / custom dual snorkel (yes the air box is back on) / HMF !!!!!!! / jetkit / clutch kit / warn 424 / rack mounted oil cooler
*Soon to have a touch of Pondhopper*
http://www.youtube.com/user/monroecountymudsters
RE: paintin plastic - 11/21/2008 4:45:28 PM
Badforeman475
like duke said I used BULLDOG ADHESION PROMOTER and clear on top of that
(in reply to rrsi_duke)
RE: paintin plastic - 11/22/2008 7:46:11 AM
HBrancher
so do yall spray clearcoat on top of the fusion?
HB MUD MOB
XP Lift
28in Outlaws
snorkle
HMF pipe
Jet Kit
Project Bike
Honda Foreman 500 S
RE: paintin plastic - 11/22/2008 9:33:42 AM
Badforeman475
yeah I did on mine
RE: paintin plastic - 11/23/2008 2:39:45 PM
farmtoy
did you hand scuff or use a sander on the prep work?
if it cant take it, i dont need it
04 grand cherokee "bmf"
89 toyota 4in lift...32s...straits...black tape...hay wire
06 suzuki z400 yosh...ground jets...drilled air box
07 honda 500 foreman "stock" (got sum pvc...silicone...and beer in mind)
RE: paintin plastic - 11/23/2008 2:50:49 PM
MudWild680
i would think just a few rounds of 220 over the plastic should rough it up enough.
maybe something a little lighter.
(in reply to farmtoy)
RE: paintin plastic - 11/23/2008 2:57:28 PM
buzz007
Like they say the 1. the prep( scotch bright pad works great ) then wipe it all down with a cleaner 2. adhesion promoter 3. atleast 3 coats of fusion 4. few coats of clear but needs to be inside and above 60 degrees or the clear will kinda yellow on ya.  I did this on a 94 kodiak and it turned out great and held pretty well too.
I personally wont do the clear so that I could just wipe it down and spray more fusion on,for touch-ups.    Also just my opinion but a Flat black looks best on a painted wheeler and is always easy to touch-up. Kinda like the stealth Popo's but on a real machine!
2006 foreman 500 es
HMF SWAMP SERIES
G--RILLER Axles
28" Mud Bugs on Vision wheels
ramsey wireless
hlp leak sheild
moose hand gaurds
k&n w/t outerwear
dinojet kit
Ricochet skids
"W / TUNES "
