TexasMudderBF650
the air/fuel mixture screws are located on the right side of the bike look above the belt cover at the carbs you'll see a brass flat head screw theres one on each carb they are easy to get to. I would first try richening them to see if it runs better to richen the mixture turn them both a alittle under a quarter of a turn counterclockwise. always move them is small movements and turn them the same amount. if it gets worse then try leaning it by turning them clockwise. when you make the adjustments you'll need to run it for a little bit to notice any differences.
< Message edited by TexasMudderBF650 -- 10/2/2007 8:49:11 AM >
2008 POLARIS SPORTSMAN 800 H.O. 3 inch lift, extreme products 1 1/2 spacers, 29.5 outlaws 10 front 12's back, stealth snorkels, 880 6000k H.I.D headlights 2005 BRUTE FORCE 650 SRA 29.5 Outlaws 10 front 12's back, EPI red secondary/ pink primary, Highlifter 2" lift, HMF exhaust S/O, dynatek cdi, Whelen strobes, k&n air filter, HL High capacity springs, http://community.webshots.com/user/jcg4825 www.myspace.com/texasmudder
