Jake450s
I've spoked about magic shmutz for the radiator before many times, if anybody want's the long version it a couple of them are pretty recent, should be easy to find. DO NOT put magic shmutz into the radiator until you isolate, identify, and FIX THE PROBLEM you are having with the cooling system. The cooling system not inadequate, something is wrong with it. I've tossed out a guess as to what is wrong, and I could be incorrect, but something IS wrong with the cooling system, that's not a guess, there IS a failure somewhere. The cooling system is not inadequate for the amount of engine you have. That being the said, the magic shmutz may not help, or worse, it may fool you into thinking you're ok until you're a bunch further out than you'd have otherwise been.
