one way bearing/starter clutch liston to it
All Forums >> [OEM Discussions] >> Arctic Cat >> one way bearing/starter clutch liston to it Page: [1] 2   next >   >>
one way bearing/starter clutch liston to it - 9/22/2008 3:29:34 PM
Wonder if anyone has had one go bad, mine is still allowing the starter to spin once the motor is running and offcourse this is making it wine real loud once it warms up. My question is mine spins free with no binding or anything and wondered if anyone has changed one with the same issue.?
cant figure out why it would be bad but yet still spin so freely, i also had pulled this out of my other motor and it was good when i did this so why putting it in this motor did it all of a sudden go bad..???
I had the motor running and pulled the starter off and sure enough the starter was still spinning so this tells me the oneway bearing is bad as the starter should not be spinning with the motor running.
guess i am just baffled that it spins so free yet still is spinning the starter over while its running and the fact it was good when i pulled it off the other motor and put it on this one.
< Message edited by GWC -- 9/23/2008 9:58:20 AM >
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
RE: one way bearing/starter clutch - 9/22/2008 3:54:54 PM
2 years of owning this camera and i finially firgure out how to put a video up..LOL
anyway if someone can say if this looks right or not sure would be helpfull . click the pix.
ps does everyone hate the sound of their own voice..lol
< Message edited by GWC -- 9/22/2008 4:16:51 PM >
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to GWC)
RE: one way bearing/starter clutch - 9/22/2008 4:58:12 PM
8upwithmud
I've had them apart on a 300,400, 500, and v2.  They spun about the same as yours does.  Is ther amyway the starter is putting it in a bind?
05 Evil Twin
Bored, stroked, camed, ported, polished,
piped, jetted, snorkeled, clutched, geared,
dynateked, Gorrilla'd, lifted, and lawed.
13 axles
6 motors
6 differentials
1 fan
? belts
04 500M with 28 laws
05 400A with 27 lites
06 Night Rod
http://myspace.com/leebo1973
........................HPAC.........................
.............Hard Pack Arctic Cats.............
(in reply to GWC)
RE: one way bearing/starter clutch - 9/22/2008 5:02:16 PM
I can pull the starter out and it still spins the gears while its running, i also tryed a different starter on it as well.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to 8upwithmud)
RE: one way bearing/starter clutch - 9/22/2008 5:34:31 PM
8upwithmud
With the cover on and the starter off, does it still spin freely?  That's if you can reach the starter gear thru the starter hole.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
(in reply to GWC)
RE: one way bearing/starter clutch - 9/22/2008 5:37:27 PM
I will have to install the cover and see, i no the gears are still spinning and should not be while its running but have not check what it feels like when not running i will do that.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: one way bearing/starter clutch - 9/22/2008 5:51:36 PM
8upwithmud
I wonder if it has some kind of a side-load on it.  I don't know how because nothing else touches that gear.  idk?
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
(in reply to GWC)
RE: one way bearing/starter clutch - 9/22/2008 7:48:11 PM
buggin450s
GWC, while looking at your video, I noticed that you could potentially have one of the same problems I did. That "saddle" or circle to the right, which one of the starter idler gear pins fits in, looks to have a piece missing on one side. Here's a pic of what I'm talking about:
Thumbnail Image
To your original question, the bearing on my 500 spun exactly as yours is. So I would say that is normal.
Attachment (1)
Custom Audio Setup
My Pics
"Team Throwed Offroad"
Powered by MORA Fueled by Monster Energy
RE: one way bearing/starter clutch - 9/22/2008 8:02:27 PM
2BADKITTYS
i'm having same problem, mine is making a heck of a clanking noise when i crank it, can someone tell me what to look for when i get in there, what it mite be making it do that.
TEAM DOUBLE "D"
DORCHEAT DIGGERZ
"06" 500M
28" LAWS
SNORKLED
JETTED
EPI CLUTCH KIT
HMF
http://www.flickr.com/photos/9966672@N04/sets/
(in reply to buggin450s)
RE: one way bearing/starter clutch - 9/22/2008 8:05:39 PM
buggin450s
2Bad, look at the picture in my post above. I'm willing to bet that is your problem. You may also have chipped a tooth on one of the starter gears.
Custom Audio Setup
My Pics
(in reply to 2BADKITTYS)
RE: one way bearing/starter clutch - 9/22/2008 8:07:35 PM
2BADKITTYS
ok, tnx i will look for it when i get in it.
TEAM DOUBLE "D"
DORCHEAT DIGGERZ
"06" 500M
28" LAWS
SNORKLED
JETTED
EPI CLUTCH KIT
HMF
RE: one way bearing/starter clutch - 9/22/2008 8:14:55 PM
2BADKITTYS
ORIGINAL: buggin450s
Thumbnail Image
what exactly is the piece that is missing from that hole
TEAM DOUBLE "D"
DORCHEAT DIGGERZ
"06" 500M
28" LAWS
SNORKLED
JETTED
EPI CLUTCH KIT
HMF
RE: one way bearing/starter clutch - 9/22/2008 8:19:59 PM
Yes this motor was a pile of crap when i bought it off e-bay( thanks e-bay) and had been swamped and rode that way, i put all new bearings crank gears and a complete top end on it. It was doing this when i first got it running and it tryed to lock up(before i went rebuilt it) and when it did that it broke that peice off.
It does still set tight in the hole and does not move so i just have left it alone.
But this is what i thought i spun it and it seems to spin very free and does lock up tight going the other way but after the motor gets warmed up it whines pretty loud and if i pull the starter off it stops whineing so i know its the starter getting hot , so in my mind this tell me the one way is bad but it seems to work just fine and i hate to buy another one only to have it do the same thing again..
was hoping someone might have had the same thing happen and know what the fix would be..lol
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: one way bearing/starter clutch - 9/22/2008 8:33:04 PM
buggin450s
Part of the case broke off. There is a pin that sits in that hole that supports a starter idler gear. It relays the force from the starter to the crank, thus starting the motor. Since it's broken, the gears lose alignment which cause more problems other than not starting.
My conclusion as to why the case broke is rider error. I think my problem could possibly be due to starting the motor with water on top of the piston. This is the only culprit I can come up with.
Custom Audio Setup
My Pics
RE: one way bearing/starter clutch - 9/22/2008 8:44:26 PM
People have had that happen when trying to start one with a allmost dead battery, the starter can kick back putting it in a bind. or like your aid alittle water on top of the piston trying to lock up the motor.
problem is once it breaks out completely you have to either find someone to weld it up and hope it works buy new cases $$ or take the idler gears out and pull start it from now on..
mine did it because of a freshly charged battery and a crank that was locking up in its bearing.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: one way bearing/starter clutch - 9/22/2008 8:44:55 PM
2BADKITTYS
ok tnx
TEAM DOUBLE "D"
DORCHEAT DIGGERZ
"06" 500M
28" LAWS
SNORKLED
JETTED
EPI CLUTCH KIT
HMF
RE: one way bearing/starter clutch - 9/22/2008 11:01:14 PM
mr. potato head
when my one way bearing messed up the other day i could turn it by hand, but when the engine was running it would seize up.  but if i would wiggle it by hand it would free and i could turn it again.  so possibly could be the extra speed and maybe a little damage to the housing could heat it up and seize it.  how hard is to pull the flywheel, and inspect the housing for damage.
RE: one way bearing/starter clutch - 9/23/2008 7:30:28 AM
Its real easy to pull it if you have a puller  other wise you cant get it off. Iam going to put it back together and see what its doing ,iam going to feel the gears and see if its anydiferent all put back together and then se what force it takes to stop the gears from turning while its running or if they will even stop, might be like you said and once running at speed it locks up for some reason.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to mr. potato head)
RE: one way bearing/starter clutch - 9/23/2008 8:36:00 AM
8upwithmud
There is your side-load.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
(in reply to GWC)
RE: one way bearing/starter liston to it - 9/23/2008 9:50:25 AM
Ok i put it back together and fired it up, with the starter pulled out the ideler gears do spin but you can stop them with the lightest touch so iam thinking maybe this is not the problem its like they are spinning because of the vibration of the motor..?  iam not even sure it is spinning with the starter in place. it also is makeing the same noise with the starter out.
but anyway liston to it and see how bad it is (the whining)  only does it when its fully warmed up and when you ride it the noise goes away. but at a idel it does not matter if its in gear or not.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: one way bearing/starter liston to it - 9/23/2008 10:17:58 AM
8upwithmud
Does the noise stop when you stop the idle gear?
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
(in reply to GWC)
RE: one way bearing/starter liston to it - 9/23/2008 10:52:11 AM
nope its not, its doing it no matter what.  what gets me is i replaced allmost everything in this motor because it was doing this in the first place. when i took this (good motor lol ) apart you can tell it had been swamped and rode that way for some time so i replaced all the bearings crank clutches and took the one way bearing out of my other motor that was not doing this at the time and put in it this one only to have it still do this..
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
Post #: 22
RE: one way bearing/starter liston to it - 9/23/2008 12:19:12 PM
Bunk650
which motor is this? your slower 500??lol
It all seems HardPack when you ride a CAT
{FloGa Chpt.}
'04 650 V2 LE
Dynatek CDI
28" Gators
2.5 Warn
Myspace
(in reply to GWC)
Post #: 23
RE: one way bearing/starter liston to it - 9/23/2008 12:49:23 PM
yeah this is my 500m.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to Bunk650)
Post #: 24
RE: one way bearing/starter liston to it - 9/23/2008 5:53:13 PM
8upwithmud
What's the possibility it's in the centrifigal clutch?  Cause it goes away when you rev it up.
05 Evil Twin
13 axles
6 motors
6 differentials
1 fan
? belts
06 Night Rod
(in reply to GWC)
Post #: 25
RE: one way bearing/starter liston to it - 9/23/2008 8:35:10 PM
fourtraxforlife
meet me at the drop off and i will explain
my pics;
http://community.webshots.com/user/fourtraxman
http://ca.pg.photos.yahoo.com/ph/fourtraxforlife/album?.dir=/b1b9[/url]
[IMG]http://i261.photobucket.com/albums/ii47/Mr_Man76/dad3.jpg[/IMG]
o6 rincon marks pics;
http://ca.pg.photos.yahoo.com/ph/rinconmark/my_photos
Post #: 26
RE: one way bearing/starter liston to it - 9/23/2008 8:56:02 PM
ORIGINAL: fourtraxforlife
if you even had a clue to how i ride or what i ride in you would not be running your mouth, you have been running your mouth about how far you can ride in one day like somone else could not keep up. you dont know me or what kind of shape iam in and i bet money you wont out ride me or out last me on one of your "long rides". you pop off and dont even know what the other person is capable of.
The more you type the more it just proves my point.
If you think i just set in a mud hole and spin my tires all day you are truely clueless ..
I was not the one running my mouth about how i could out do ANYONE, YOU where and you are saddly mistaken, your little rincon could not follow my "whining" 500m  for more then a mile where i ride but yet it will follow your rinCON all day long where you ride..
yeah yeah you got 20 billion miles on your rinCon big freaken deal if i rode on fire roads and groomed paths all day long i would have that as well.
< Message edited by GWC -- 9/23/2008 10:13:23 PM >
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to fourtraxforlife)
Post #: 27
RE: one way bearing/starter liston to it - 9/23/2008 9:14:45 PM
Jason
die hard honda guys usally set on hard ground watch everyone else play, then talk about reliabilty
08 650 h1
27'' swamp lites
snorkels
jetted
slide mod,clipped spring
speedwerxs pipe
secondary mod
(in reply to GWC)
Post #: 28
RE: one way bearing/starter liston to it - 9/23/2008 9:15:00 PM
ORIGINAL: 8upwithmud
I replaced it as well, matter of fact i replaced both the wet clutch and the main clutch the complete units.
guess i should of known better to buy a motor off e-bay thats list as Needs valve seals...lol
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
