oil in airbox
oil in airbox
All Forums >> [OEM Discussions] >> Yamaha >> oil in airbox Page: [1]
oil in airbox - 11/25/2008 4:38:30 PM
grizzly guidry
alright i went ridding this weekend.. well i started cleanning my bike today an when i  pulled my airbox lid there was some oil in the airbox.. everything is snorkeled an i have my crank case vent line running into my airbox with a small fitler on the end of the ventline... any idea why i would have got oil in the airbox or what should i do????
TEAM "doin it dirty" OFFROAD
07 grizzly 700 fi
29.5 x 10 Outlaws, 4
2"HL lift kit
HL Extreme clutch kit
HL Tripleflow radiator relocation kit
1" wheel spacers
4 monkey axles
HMF Swamp Series Exhaust
PowerComanderIII
UNI airfilter
fully custom snorlkeled
silvastar lights
Ricohet skide plates
yamaha front bumper
2.5 warn winch
http://s37.photobucket.com/albums/e71/wendi_martin_photo/
http://www.doinitdirtyoffroad.com
RE: oil in airbox - 11/25/2008 4:50:47 PM
bckdrft75
It could be several things. Mine does it to sometimes. Poor starting, erratic idle,running at full throttle & backing off. High rpms at low speed. Bad oil. Not right oil. Going up steep hills. Walking it. Water wheelies. All kind of things.
MINE
2002 Grizzly 660
28x10.5 laws on all 4's, Snorkeled,Relocated Radiator, PoMan HMF, Dynojet Kit tuned by MaD Motorsports, HL Clutch Kit, Overfenders, Warn winch, Milano Grips
WIFE'S
2003 Ozark 250
Snorkled, 25" Stock Grizzly tires
My Myspace
(in reply to grizzly guidry)
RE: oil in airbox - 11/25/2008 6:09:21 PM
grizzly guidry
man thats alot.. looks like i got my work cut out for me trying figure out that bug or should i say bugs maybe.. well i got the right oil in because i just got it changed 2 weeks ago..
07 grizzly 700 fi
2"HL lift kit
1" wheel spacers
4 monkey axles
PowerComanderIII
UNI airfilter
silvastar lights
yamaha front bumper
2.5 warn winch
(in reply to bckdrft75)
RE: oil in airbox - 11/26/2008 12:16:08 PM
bckdrft75
It might not be the fact of trying to fix it. It just happens sonetimes when it gets rode hard & the conditions. The things are made for play so I say play hard!!! As long as its not continious. I would just test it see what happens. Good luck. I have seen where some people put filters on the end of the hose that helps from blowing out so much.
< Message edited by bckdrft75 -- 11/26/2008 2:11:35 PM >
MINE
2002 Grizzly 660
WIFE'S
2003 Ozark 250
My Myspace
RE: oil in airbox - 11/26/2008 1:00:15 PM
Ball
Just an unprofessional observation but maybe the filter on the breather is catching the oil vapors and soaking the filter until it drips into the airbox where as the vapors would normally spread evenly across the larger air filter and be soaked up by dirt, etc.
Could have been overfilled during last oil change.
One solution may be to replace the stock breather hose with a couple of feet of rubber hose and route it a couple of times around the outside of the air box before connecting it in the stock location. In theory, that would give the oil vapors more chance to condense in the hose and run back into the crankcase , not making it to the airbox. i have seen ppl do this to remedy oil accumilating in the airbox from excessive wheelies, I think it was the Kawies that were having a big problem with it.
Parting out Grizzly 660
RE: oil in airbox - 11/26/2008 2:12:40 PM
bckdrft75
Sounds like a profeesional answer to me Ball. It makes sense.
MINE
2002 Grizzly 660
WIFE'S
2003 Ozark 250
My Myspace
(in reply to Ball)
RE: oil in airbox - 11/29/2008 6:59:39 PM
kingquad300
only time i had somthing like this happen is when my float stuck and draind about a gallon of gas in my engine then when i started it up it shot a mix of gas and oil about 10 foot out of my crank case tube and it has about 2-3 foot of tube b/c i snorkled it
Main Ride: Izzy
Grizzly 600
belt snorkled
motor intake snorkled
oil cooler re-locate
HMF (Polished)
carbonfiber fan overide switch
2 Inch lift front and rear
Jetted (Again and again and again)
oil temp guage
wheel spacers (1.5 inches all the way around)
bored 40 over
EPI clutch kit
29.5 Swamplites on sum full moons
split stero (2 6 1/2's)
and my best investment DGL LOCKER
