noise when in low range
All Forums >> [OEM Discussions] >> Arctic Cat >> noise when in low range Page: [1]
noise when in low range - 9/29/2008 8:51:47 AM
Joel12mi
I have a noise like a popping sound in low range 4 wheel drive on my TRV.
Is this normal?  My brother gets the same kind of popping noise from his Rhino is low range 4 wheel drive.
I was pulling some logs and thought low range would be better but it kept making this noise so I decided to go with high range.
The noise comes from down low it isnt the motor making the pop. Maybe the drive shaft?????????
RE: noise when in low range - 9/29/2008 8:54:02 AM
maybe a CV joint is dirty.. have you checked you cv boot to make sure they are not tore. But it should not be making a poping noise in low or high
maybe the front u joint..?  does it have a rear u joint..?
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to Joel12mi)
RE: noise when in low range - 9/29/2008 9:37:12 AM
Joel12mi
I am not sure about the boots. I wouldnt think they are bad...only had the machine for a few weeks.
My brothers Rhino is brand new.
(in reply to GWC)
RE: noise when in low range - 9/29/2008 10:24:58 AM
Joel12mi
I would think if it was a CV boot issue  it would do it in high range as well.
0.172
