no cats and no mufflers
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> no cats and no mufflers Page: [1] 2   next >   >>
no cats and no mufflers - 8/13/2008 3:49:48 PM
rednk123
i got a question when you take your cats off people say it messes with your 02 sensor is that true and if it is what do you do about it and what does it do? askin for a friend i told him not to whats yalls opinion?
RE: no cats and no mufflers - 8/13/2008 4:03:19 PM
UltraKodiak400
Leave the cats. They are there for a reason. They usually contain the o2 sensors I believe. But with them your gas milage takes a drop, power takes a drop b/c of no back flow, and it pops to much. Save the trouble and buy a Flow Master 10seris. Just as loud as straights almost except better for your truck.
Join the Army. Go new places, meet new people, then kill them.
Myspace
YZ 125 with goodies - Kodiak 400 4x4 - Rhino 660 4x4
2003 Chevy Z71
Support Our Troops
(in reply to rednk123)
RE: no cats and no mufflers - 8/13/2008 5:37:22 PM
gmcz71
you can cut your cats and tune for the rear O2 sensors to be turned off so it wont throw codes.
especially if you have an LS-motor, I dont suggest you do away with both.  too much loss of backpressure.
probably should just get an aftermarket muffler.
1998 Suzuki Quadrunner 500 - Broken
2005 Kodiak 400 - Sold
1998 Honda 300 4x4 - Sold
1997 Honda 300 2wd - Sold
2002 Recon 250 - Sold
2003 Rincon 650 - Sold
2000 GMC Sierra Z71 - 5.3 - ecsb
- Cherrybomb Extreme
- Blackbear 87oct tune
- Vette servo's
My Pics...
(in reply to UltraKodiak400)
RE: no cats and no mufflers - 8/13/2008 7:41:36 PM
rednk123
thanks for the help guys. But he'll probably get true dual straight pipes with no mufflers but will leave the cats alone
(in reply to gmcz71)
RE: no cats and no mufflers - 8/13/2008 8:27:22 PM
Cledus Earl
i just cut my exhaust off right behind the cab where it goes into the muffler. it's crazy how much more power i have now combined with the k&n intake. plus it sounds bad***, no popping or anything.
'04 foreman 450es: 26" swamplites(they suck) on interco rims
'98 gmc z71: 33x12.5 SSR's, 3" susp. lift, strait pipe with turndowns, K&N intake, 4 KC's on bumper, and some other junk
RE: no cats and no mufflers - 8/13/2008 9:19:51 PM
Foreman4504x4
I'd leave the cats on. Like UltraKodiak400 said, they put them on for a reason. Running no cats is bad for your engine. Find a good aftermarket cat converter and run true dual Flowmasters or Dynomax Bullets.
04.5 Polaris Sportsman 500 HO. 4x4
27" Mudzillas, 2" HL Lift, Warn Winch, Turner Cycles Axles, and more!
www.badchevy.20m.com
www.badsportsman.20m.com
(in reply to Cledus Earl)
RE: no cats and no mufflers - 8/14/2008 11:17:46 AM
rednk123
Alright but what do yall think about true dual straight pipes with 2 1/2 pipe with 4" tips with cats and no mufflers hes goin for that extremly loud poppin and crackin noise
(in reply to Foreman4504x4)
RE: no cats and no mufflers - 8/14/2008 11:41:43 AM
Dock Rocker
There are usually 4 o2 sensors.  The front two measure the air fuel ratio so the computer can make adjustments to the mixture on the fly.  These two are the most important.  You will have to keep these.  The rear two o2 sensors or use to measure how effective the Cat is.  You do not need this but if you dont want a service engine light and loss of engine efficency you will have to use some sort of tuning software to tune the back two o2's out.  Back pressure is needed to keep your torque down low.  The lack of back pressure will move your power up to the top of the RPM band and make it feel like a dog down low.  If you have a good muffler to add some restriction you can have the best of both worlds.  You loose the restrictive cat but keep a good flowing exaust.  Unless you are drag racing you are not going to see any gains from strait pipes, you will most likely see a loss.
RE: no cats and no mufflers - 8/14/2008 1:03:48 PM
rednk123
thanks for that indepth speach seriously not tryin to be a smart @$$
But yea he'll definitly be leavin the cats alone and hes not really tryin to gain any performance out of it just have a really loud truck
(in reply to Dock Rocker)
RE: no cats and no mufflers - 8/14/2008 8:01:27 PM
HondaGuy
Backpressure is not a good thing, you don't want any at all. If you run properly sized pipe you can do just fine without the cats or mufflers. But for simplicity and leagality I would just leave them there and run straight pipes the rest of the way. It will be loud that way.
I thought I was wrong once, but I was mistaken.
Supertrapp Mudslinger
HL EPI Clutch Kit
Relocated Radiator
Permacool 8" electric fan (covers the whole radiator)
12x7 ITP C Series Type 5 wheels
27in Bi/Tri Claw Magnum combo
Mud guard fender flares A-arm skid plates
88 Yamaha Banshee red and grey
stockish
21" Mud Sharks
RE: no cats and no mufflers - 8/14/2008 8:35:11 PM
popnfresh24
ah no......... backpressure is a good thing, you have to keep backpressure so you dont burn your valves and so you can actually keep power. the only way you can go with out running any backpressure is if you are running a super hopped up engine that can run open headers....thats the only way no back pressure will work
(in reply to HondaGuy)
RE: no cats and no mufflers - 8/14/2008 8:53:40 PM
03_VINSON
Older trucks don't have to have cats... I dont no the cut off line but mines a 85 and they cut mine off because they said mine were messed up anyway
03 vinson on 26 inch mudbugs
HMF
UNI Filter
Custom Snorks
(in reply to popnfresh24)
RE: no cats and no mufflers - 8/14/2008 9:03:43 PM
Guest
A good muffler will be tuned for the certain truck or car you ordered it for.  It should keep enough back pressure to make the car or truck run at its best peaks.  I run a flowmaster with the cats gutted on my Tahoe and it made a world of difference on my performance, towing, and mileage.  The converters are for the EPA regulations.
wide open or stopped
(in reply to 03_VINSON)
RE: no cats and no mufflers - 8/15/2008 9:04:37 AM
rednk123
I think the cut off line for chevys is 96' is when they started puting O2 sensosrs in the trucks
So you can burn up your engine runnin straight pipes?  But like honda guy said i heard if you run a small enough pipe like 2 1/4" you wont have to worry about back pressure
(in reply to Guest)
RE: no cats and no mufflers - 8/15/2008 6:06:05 PM
HondaGuy
ORIGINAL: popnfresh24
I am right on this one sorry, backpressure is a bad thing, however it is the easiest way to stop the valves from overheating and burning. If you run PROPERLY sized exhaust pipe then you will never have a problem. If you run 3" straight pipe true duals on a small V8 like (Dodge 4.7, Chevy 4.8, or Ford 4.6) then yes you will probably lose low end power and burn valves over time. But if you make it reasonable sized like 2-2 1/4" then you will be fine. The smaller the pipe the faster the exhaust flows through it but the pipe has less volume so even though the gasses are flowing faster less of it is going out, that acts like backpressure in a way but it doesn't restrict flow. You don't have to have a dragster motor to run open headers I did it for over a year on a bone stock 158 hp 2BBL 400 79 F-150, it ran perfect and is still like it 3yrs later, no burnt valves.
I'm not saying that type of exhaust is the best way to go,just if you use your head and pick a reasonable pipe size then you can do it very reliably and have a VERY loud truck. The truck probably would have more power if you got rid of the cats and put some good mufflers on it with an X-pipe.
< Message edited by HondaGuy -- 8/15/2008 6:07:58 PM >
HL EPI Clutch Kit
Relocated Radiator
stockish
21" Mud Sharks
RE: no cats and no mufflers - 8/15/2008 8:42:16 PM
rednk123
no he definitly has the 5.3 i went and looked with my dad at an 08 crew cab 4x4 chevy with the 4.8 and he had it in tow haul mode and it still didnt even come close to the 5.3 but its not really about hp with the 4.8 aint really much diff. than the 5.3 but its the torque or how ever you spell it but do yall think he'll be alright with a 2 1/2" - 3" pipe on a 5.3
RE: no cats and no mufflers - 8/15/2008 11:15:42 PM
CTownForeMan
If he is doing this to a new truck I say don't do it by far.  This not only will mess up everything but will freak out the computer or pcm and then you will have problems.
Running straight exhaust no matter what size pipe will burn up the valves.  It's all in the fuel air ratio you through into the truck.  Backpressure is a good thing.
Hope he is ready for a lot of tickets.  Government is getting strict on that kind of stuff.
Custom 1998 Foreman 400!
foreman 450 frame, custom 4 inches of lift, EDL's on douglas wheels, custom rear suspension with single rhino shock, removable paddles, welded front diff, 450 jug with HC racing piston, gear reduction!
Got Paddles?
http://community.webshots.com/user/ctownnasty400
http://s186.photobucket.com/albums/x289/ctownforeman/
RE: no cats and no mufflers - 8/16/2008 12:38:28 PM
HondaGuy
If you leave the cats on then 2 1/2" true dual straight pipes will be fine on it and you won't really lose any power down low. If you go any bigger then that on a stock motor then you will start losing low end.
You do know he is talking about a fuel injected truck not an atv right?! The computer is more then capable of correcting the air/fuel ratio after an exhaust change thats what the front O2 sensors are for, measuring the air/fuel ratio and sending that info to the computer so it can make on the fly corrections. If you look at the PCM data with a scan tool and look at the air/fuel ratio or O2 sensor output, its constantly switching from lean to rich in order to keep the ratio in the proper place. This is OBVIOUSLY something you don't have your info right on, so please do some reasearch on it before trying to call out another ASE Master certified GM Dealership Tech out on this subject. I AM right on backpressure, its a crutch used by people that don't know any better.
HL EPI Clutch Kit
Relocated Radiator
stockish
21" Mud Sharks
(in reply to CTownForeMan)
RE: no cats and no mufflers - 8/16/2008 10:22:37 PM
CTownForeMan
The computer is more likely to freak out if something drastically changes right away.  I do not and will not recommend straight exhaust on any truck.  Too many things to go wrong.
Pretty sure i'm not talking about an atv.  This seems to be the truck forum atleast.
ASE certified gm tech huh?  Know many of them and they would never reccomend or inform somebody on how to run straight exhaust on a new truck.  Great work.
Got Paddles?
RE: no cats and no mufflers - 8/17/2008 12:37:15 AM
HondaGuy
I would generally agree that drastic changes will confuse the computer, however the computer and all of its sensors on that 5.3L are more then capable to compensate for a different exhaust. I call a drastic change a cam, supercharger, head work, or stroker kits, an exhaust change is by no means a drastic thing. My 99 Dakota 318 4x4 gets a new exhaust setup every couple of months, can't really find one that I like, its never freaked out and the check engine light has not come on yet even with the cat gutted. My 02 Dakota 4.7 has had a True dual catless setup with Spintech mufflers for over 4yrs now and has never freaked out or run bad because of it, quite the opposite as it has run a best time of 14.21@93mph in the qtr with simple bolt ons and a set of 27" slicks.
I know many other ASE certified Techs that would also say that doing this to a new truck is a bad idea, I feel as a younger tech that it is my responsibility to help the "young and dumb" crowd do things to their vehicles that many expecially older people don't agree with, but in a safe manner. Frankly no matter what you might think the best thing is, people like him and I are going to do things like this to our trucks and cars no matter what, so at least I can help by telling him the safest way to do it. It is the same arguemant that I am having at work right now with the older and more stubborn techs at my dealership, they are afraid that if we get into the GM Performance Parts and TRD Parts that we will get burnt by the warrantys. My argument is that the people that are willing to do this to their vehicles are going to do it no matter whos selling the stuff, it might as well be us. As I said above I don't think this is the best setup, BUT all he is interested in is the sound, he cares little about power, straight pipes are what he is looking for if he wants just noise. So I will say again, he IS fine running straight pipes on his truck if he runs the right size and cares nothing about any warrantys that might be left.
HL EPI Clutch Kit
Relocated Radiator
stockish
21" Mud Sharks
RE: no cats and no mufflers - 8/17/2008 10:22:24 PM
PRAIRIEMAN
I cut mine off and put a flowmaster on it and my engine light went off and I picked up power and gas milage. I have a 01 5.3
2002 P650 Few Mods
2001 z-71 Extended Cab
1972 Chevy Super Cheyyenne 4x4 http://community.webshots.com/user/allysuna
http://www.myspace.com/carolinaz71
RE: no cats and no mufflers - 8/18/2008 11:32:33 AM
CTownForeMan
Thats not my point.  Warreny is not orth a crap now a days.  We are having nothing but trouble at work for emmisions and I deal with diesel's.  Gasolines are by far worse and tellin people to run straights lead to nothing but bad emmisions and tickets.  These type of things here are why we are having to install DPF system on diesel's and restricting power and milage.  Trying to get the air cleaner cause nobody cares anymore.
Got Paddles?
(in reply to PRAIRIEMAN)
Post #: 22
RE: no cats and no mufflers - 8/18/2008 9:11:58 PM
PRAIRIEMAN
Yea, s.c. doesnt have inspections so we get away with it.
2002 P650 Few Mods
Post #: 23
RE: no cats and no mufflers - 8/18/2008 9:49:01 PM
BTTW
when you gut the cats (i do this so it still looks legal lol), as i have on old 5.7TBIs and 4.3vortecs, as said above it messes with o2 sensors, which cause it to think its running lean and it dumps more fuel which not only smells but mpg goes down. you can get it tuned out/off (the o2 sensors) as said above. Also, the 5.3 i would run a 2" or 2.5" pipe from the cat back(after gutted).  right now i have a NNBS gmc 6.0 with no cat and 44 flowmaster and its LOUD, not poppy either like most people say.
i say go for it :D thats just me though :P
05 650 v2
module
28 outlaws
red primary spring
snorkeled
LE racks
coming soon: Audiopipe
coming soon: green/white strobes
Post #: 24
RE: no cats and no mufflers - 8/20/2008 5:47:16 PM
HondaGuy
ORIGINAL: BTTW
No it does not, the rear O2 sensor has nothing to do with the air/fuel ratio they are a Catalyst (catalytic converter) monitor only. The front O2 sensor is what controls the air/fuel ratio and that is not affected by something you do behind it. I don't have a rear O2 sensor on my truck at all and it runs no different and gets no worse MPG with it gone.
HL EPI Clutch Kit
Relocated Radiator
stockish
21" Mud Sharks
(in reply to BTTW)
Post #: 25
RE: no cats and no mufflers - 8/20/2008 9:54:06 PM
nonnieselman
ORIGINAL: HondaGuy
ORIGINAL: BTTW
Gah.. im glad your tryin to teach them something.. Some people are just to dumb to listen..
Only thing thats goin to happen to the PCM if you gut/delete the cats is, your goin to throw codes. Thats it.
Here are the possible codes:
P0137       O2S Circuit Low Voltage Bank 1 Sensor 2
P0138       O2S Circuit High Voltage Bank 1 Sensor 2
P0140       O2S Circuit Insufficient Activity Bank 1 Sensor 2
P0141       O2S Heater Performance Bank 1 Sensor 2
P0157      O2S Circuit Low Voltage Bank 2 Sensor 2
P0158      O2S Circuit High Voltage Bank 2 Sensor 2
P0160      O2S Circuit Insufficient Activity Bank 2 Sensor 2
P0161      O2S Heater Performance Bank 2 Sensor 2
I didnt notice any loss of gas mileage when i gutted mine, but i had the full exhaust all the way to the stock tail pipe with just a small magnaflow muffler.
Didnt notice a gain or loss of power either. It made it alot louder tho. Now with the turbo i put another muffler behind it to quiet it down almost to stock levels.
If i were to do it again on a Stock NA truck. I would just gut the cats, and put a decent muffler where the stocker is.
Stock exhaust size is 2 7/8", Its actually Metric but thats what it measures. That will support plenty of flow for even a slightly modded engine.
2005 Red Foreman 4x4 S
-Rubi Rims w/ 26" MST
2000 Silverado ECSB
LQ4 4L80E STS Nitrous
Post #: 26
RE: no cats and no mufflers - 8/22/2008 8:51:38 PM
jhendersonsanity
i have an 03 GMC 2500 and I have true duals from engine to tips. I cut my mufflers off but left the cats. I is loud but sounds great!!! A friend of mine has an older bronco that has true duals with no cats and no muffler, he's had no problems and is just a little louder than mine, but mine sounds much better. If I were u i would run true duals and cut the mufflers off but leave the cats.
(in reply to nonnieselman)
Post #: 27
RE: no cats and no mufflers - 8/24/2008 10:08:22 PM
HondaGuy
ORIGINAL: nonnieselman
ORIGINAL: HondaGuy
ORIGINAL: BTTW
Thanks for the help, I am trying some people just don't get it, even though they think they do. Have you run your truck at the track? How much faster is it with that STS setup, and how much boost does it make? I'm getting ready to start a custom turbo setup on my 02 Dakota 4.7L rcsb, going to be in the neighborhood of 400-450hp at 12psi (properly tuned of course).
HL EPI Clutch Kit
Relocated Radiator
stockish
21" Mud Sharks
Post #: 28
RE: no cats and no mufflers - 8/30/2008 11:49:34 PM
backinblack700
 i have 3'' straights from the headers out the back on my '94 5.8L F-150, no cats or mufflers with 6'' tips, its crazy loud...
CHASE
'01 HONDA RECON 250-
25'' MUDLITES, ITP WHEELS, SNORKEL...
'79
