need help with installing 10" g rilla lift
All Forums >> [OEM Discussions] >> Arctic Cat >> need help with installing 10" g rilla lift Page: [1]
need help with installing 10" g rilla lift - 7/21/2008 1:56:55 PM
jaidendarrell
i am trying to get my fourwheeler ready, so i can just install the lift as soon as it comes in, and i got a few questions.
1. how long does it take to install this lift?
2. how hard is this lift to install?
3. are the axle nuts, on the spindle always harder than **** to get off?
4. is there a secret to anything "tearing it down or the lift install"
5. should i remove the stock brake lines? or does this lift kit just come with something to extend the stock brake lines?
07 Arctic cat 700 LE, Custom snorkels, relocated radiator, 30" ITP's, warn 2500 with synthetic cable, Speed works belt/clutch kit, reverse override mod.
RE: need help with installing 10" g rilla lift - 7/21/2008 2:09:04 PM
squeak12
Its not hard, just takes time.  Id say 4 hours depending on how easy the axles come out.  You also have to bleed the brakes and adjust the tie rods.
Yea the spindle nuts are going to be hard to get of without an impact or a tool to hold the hub still so it doesn't spin.
No real secrets, just time consuming.
It comes with completely new brake lines.
2005 AC 500M
- Snorkeled - Rad Relocated - K&N - FMF - Clutch Kit - 6" Lift - 31" Outlaws - 14" Type 7's -
http://s18.photobucket.com/albums/b132/squeak12/AC500M/
(in reply to jaidendarrell)
RE: need help with installing 10" g rilla lift - 7/21/2008 6:35:43 PM
jaidendarrell
thanks a ton that helps alot lol i was hopeing 4 or 5 hours lol instead of days!
(in reply to squeak12)
RE: need help with installing 10" g rilla lift - 7/21/2008 6:44:07 PM
bustedknuckles
Congrats! You'll love it.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: need help with installing 10" g rilla lift - 7/22/2008 8:38:00 AM
jaidendarrell
im still screwing with these axle nuts, i had a three and a half foot breaker bar, and still couldnt break them loose with all my weight on it, and im no little guy. im afraid i am going to screw up the spindle as i am putting a tire tool in the spindle to keep it from turning and its aluminum.
im gonna try a pipe wrench on the axle bar. ya think that will work or is it a bad idea?
im thinking im going to have to put some heat to it today to see if it will help.
im kinda affraid putting heat to it will mess something up "any plastic or rubber seals in spindle/hub etc" does anyone know about this?
does anyone know did arctic cat use threadlock on these?
how are you all getting these freakin things off? theyre killing me, and it doesnt help that it is hotter than heck out side, i can only stay outside for a while then i gotta go in and get a drink and cool off, its a pain. its 100 degrees outside and feels like 120 in the garage, but it cooled off today so maybe i can get more done.
(in reply to bustedknuckles)
RE: need help with installing 10" g rilla lift - 7/22/2008 8:59:48 AM
BuLLg0d
Hmmm I always did them with an impact.
08 ARCTIC CAT 700H-1
with some stuff
09 Thundercat TRV
more to come
TEAM STEEL HORSES
POWERED BY
ARCTIC CAT
Moto Sport Alloy
Ricks Racing Fuel
CATVOS
Big Monkey Axles
Speed Werx
RE: need help with installing 10" g rilla lift - 7/22/2008 9:15:11 AM
jaidendarrell
well i got an impact, but it sucks, it will barely take off lugnuts so there is no way it will touch these.
(in reply to BuLLg0d)
RE: need help with installing 10" g rilla lift - 7/22/2008 9:15:08 AM
honda_suicide_squad
BETTER BORROW YOURSELF AN IMPACT!....
GOOD LUCK WITH IT AND CONGRATS!
YELLOW 2004 FOREMAN 450 S
GEAR REDUCTION
CLUTCH KIT
POLISHED CHROME HMF
29.5 LAWS
POLISHED MOTORSPORT ALLOY TELLURIDES
3000lb WINCH
DIAMOND PLATE BASH PLATE
STICK STOPPERS
PULL START LEAK SHEILD
CUSTOM 250 WATT AUDIOPIPE
2007 GSX-R 1000
ORANGE/BLACK
TWO BROTHERS EXHAUST
GEL SEAT
HOT BODIES BLACK WIND SCREEN
FRAME SLIDERS
(SOLD)
2007 CAMO FOREMAN 500
2005 FOREMAN 500
1999 FOREMAN 400
RE: need help with installing 10" g rilla lift - 7/22/2008 9:44:00 AM
BATTLE_CAT
We had the same problem with my buddys '07..There was some type of thread lock on the nuts and my impact would not break it loose. To get it broken loose we took a torch and heated the nut up, and then started hammering on it with a impact.  Good luck with it!
THE Trail Machine...just got a little bigger.
'06 Slow Cat
CATVOS 10" lift
4.0 gears
18% gear reduction
and a few more mods...
LUNATICS
(in reply to honda_suicide_squad)
RE: need help with installing 10" g rilla lift - 7/22/2008 10:53:37 AM
BrokenKitty
Yea ive always had problems with my spindle nutts i sprayed pb blaster on it to help but i tryed using a 4 foot breaker bar to hold the axle from spinning and it bent the bar but i got it off eventually with using a big racket and big impact gun you just have to keep working it and not giving up .
07 650 h-1
- Tall snorkels
- Rad up top
- 29.5 outlaws
- 2 " lift kit
- Highlifter springs
- axle spacers
- Dalton clutch kit
- Hmf muffler
- K&N an jetted
- Front brush guard
- Rear brush guard
- 3000 lb monkey winch
- Handle guards
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=333810678
http://s218.photobucket.com/al
(in reply to BATTLE_CAT)
RE: need help with installing 10" g rilla lift - 7/22/2008 11:35:22 AM
HUNTER
ORIGINAL: BrokenKitty
where can a get a big racket..............LOL
2008 polaris razr
28" monkey tires
2" hl lift
custom jams
coustom snorks
2007 Arctic Cat 700 EFI
4" CATVOS lift
30" mudlites
stealth sorkels
HMF pipe
(in reply to BrokenKitty)
RE: need help with installing 10" g rilla lift - 7/22/2008 12:26:50 PM
BuLLg0d
My advise would be to heat it up just enough to melt the loctite then get on it with the breaker bar. Dont heat it up glowing red but just enough to heat the loctite.
with some stuff
09 Thundercat TRV
more to come
TEAM STEEL HORSES
POWERED BY
ARCTIC CAT
Moto Sport Alloy
Ricks Racing Fuel
CATVOS
Big Monkey Axles
Speed Werx
(in reply to HUNTER)
RE: need help with installing 10" g rilla lift - 7/23/2008 12:25:17 AM
jaidendarrell
tried heat and it got me nowhere, however  a good ole 3 pound sledge and chisel point punch did the trick. however i would have to say the threads are fubared.
thats what i call the point of no return!!!!!!!!!!!!!!
just because i know someone will ask,
fubared = past tense of fubar
fubar = abbreviation for F'ed up beyond all recognition
RE: need help with installing 10" g rilla lift - 7/23/2008 1:31:55 AM
redneck36049
well i puttin the lift on it took me and a buddy 8 hours to put my 6" monkey lift on cause it took 2hrs to get the ball joints in they was just a pain in the rear. and also they didnt send to directions either so that didnt help. but just take your time and make sure it all there and done right cause remember who you are representing.... TEAM AC. lol.
i had a 6 foot cheater bar to break mine lose with a 3/4 racket on the end. so mine wasnt that hard to get the nuts off.
2007 ARCTIC CAT 650 H1
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
WANT A CAT CALL STEEL HORSES WISH I DID
MY PICS http://www.myspace.com/redneck36049
RE: need help with installing 10" g rilla lift - 7/23/2008 9:58:28 AM
jaidendarrell
6 foot breaker bar? holly crap lol thats just asking to break bolts off lol its prolly a good thing i dont have one of those laying around
(in reply to redneck36049)
RE: need help with installing 10" g rilla lift - 7/23/2008 10:39:10 AM
BuLLg0d
The best thing to do with teh a arms before installing the ball joints is clean the powder coat out of the hole with a die grinder.
with some stuff
09 Thundercat TRV
more to come
TEAM STEEL HORSES
POWERED BY
ARCTIC CAT
Moto Sport Alloy
Ricks Racing Fuel
CATVOS
Big Monkey Axles
Speed Werx
RE: need help with installing 10" g rilla lift - 7/23/2008 12:38:39 PM
redneck36049
yea that is what we finially did
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
RE: need help with installing 10" g rilla lift - 7/24/2008 8:11:59 AM
jaidendarrell
wooo hoooo its on and looks baaaaaaad !!!!!!!!!!!!!!!!!
all my friends though are tellin me they aint goin to the bogs anymore cause i got a monster truck, so whose gonna come up with the prize money for me?
RE: need help with installing 10" g rilla lift - 7/24/2008 10:58:43 AM
bustedknuckles
Where's the pics?
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: need help with installing 10" g rilla lift - 7/24/2008 12:59:21 PM
redneck36049
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
0.719
