need help with 400cc polaris
All Forums >> [OEM Discussions] >> Polaris >> need help with 400cc polaris Page: [1]
need help with 400cc polaris - 8/17/2008 9:02:30 AM
linkzg2001
I need help with a 1996 400cc 2stroke polaris its not running right now but its because of the oil pump not working i would put the gas/oil mix in fuel tank but it will gum up my carb has anyone taken off there oil pump?and when i remove the pump cover what do i do next help is appreciated im thinking the oil pump is bad because the oil that was in it sat for about a year and i drained it and it was very thick im sure the pump is clogged is there a way i can tell if its not clogged? and another question does anybody polaris make air noises when you pull the pullstarter 7 times im thinking its the pullstarter decompressor my 4wheeler was running but it sat for awhile
Thumbnail Image
Attachment (1)
heres a picture of my fourwheeler - 8/17/2008 9:12:28 AM
linkzg2001
this is what my 4wheeler looks like
Thumbnail Image
Attachment (1)
(in reply to linkzg2001)
RE: need help with 400cc polaris - 8/17/2008 9:13:41 AM
Foulplay
Welcome to the forum! I don't know the answer to your question but some one will chime in with an answer eventually. Highlifter is usually pretty slow on the weekends but wait and see how many people are on here during the week!
'06 Popo 800 EFI on 29.5" Outlaws
'05 Popo 700 carb on 29.5" Outlaws
'07 Popo 500 H.O. EFI (hers) on 27" Outlaws
'78 Jeep CJ-7 w/304 V8
http://s125.photobucket.com/albums/p44/Foulplay_photo/
This Honda's gone...
http://video.yahoo.com/watch/341841/2183512
RE: need help with 400cc polaris - 8/17/2008 9:59:05 AM
Foulplay
Did you take the pump off and clean it real well with maybe some carb cleaner? Did you put fresh gas and oil in it? Why would mixing your gas and oil gum up your carb? Isn't that all the pump does? It would be the same thing as the pump doing it for you...unless you got the mixture all wrong.
(in reply to Foulplay)
RE: need help with 400cc polaris - 8/17/2008 12:07:28 PM
linkzg2001
well my next task is to take out the oil pump i put gas and oil in the pump an it seems to gum up the carb i took the three bolts of the pump and it still will not come out thanks for the info
RE: need help with 400cc polaris - 8/17/2008 1:51:03 PM
Corndwg01
Running pre-mix in your gas tank won't hurt anything or gum up your carb.  Mix it at 40:1.  You should buy an oil pump block off kit from somewhere like HPD.  They're pretty cheap.  This way, you don't ever have to wonder if your oil pump is working or not.  If the bike set up for a while, it's very likely your carb is gummed up from gas sitting it.  Take your carb off and clean it up real good also.  While you're at it, you might as well put a new plug in it.  I think it takes an NKG BRE8ES.  Check with the guys on www.gen3usa.com they will tell you anything you need to know about it!
PICS
2008 Sunset Red Polaris Sportsman 800
Polaris Winch
Snorkeled
Radiator Relocated
28" Mudzillas
3 Light Mod
Reverse Override Mod
Auto Backup Lights
My Site
RE: need help with 400cc polaris - 8/17/2008 11:12:23 PM
Xplorer470
It's best to get rid of the oil pump on the 2 stroke polaris' they go out very often.  You can pick up a block off kit from several manufacturers, such as HSP, HPD, and aaen.  And when mixing your gas you can mix it anywhere between 32:1 to 40:1 as mentioned above.  And the carb is gummed up from the gas sitting in it so long, you need to take it apart and clean it out, mixing the gas in the gas tank doesn't affect that.
96 Xplorer 400.AAEN 470 bbk,44mm carb,14:1 compression,aluminum head,roller clutch,6"lift.31"laws, axle paddles.80-85 hp at the fly =)
03 sp 700.800 bbk,6"lift,32" sbacks,stage 3 motor work,gear reduction,pinned crank,cam,42mm carb, 12:1 pistons
(in reply to Corndwg01)
RE: need help with 400cc polaris - 8/18/2008 9:36:32 AM
linkzg2001
hey i plan on buying that oil pump block off kit what will happen if i dont buy the kit and leave the oil pump on will it mess up my bike
(in reply to Xplorer470)
