need help 06 660 grizz
All Forums >> [Most Popular Discussions] >> Tech Questions >> need help 06 660 grizz Page: [1]
need help 06 660 grizz - 8/14/2008 11:27:00 AM
jstanely
Hi guy im new to this forum i have a poblem and need help bad.I work on sport atvs but this grizz has me stumped.My boss sunk it up to the handle bars now it run good until you hit 30 mph then it acts the same as it does when you run it in reverse ad if you le off the gas it is like it is in low.We drained the side with the belts and changed the oil it look good.I would greatly appreciate it if someone coul help.
Thanks jamie
RE: need help 06 660 grizz - 8/14/2008 4:10:15 PM
sscard
open the right side, clutch cover,
pull the carrier bearing and remove the primary
clean the rollers and apply new grease, sounds like hes burned the clutch pad or the sheave drive, could also be a bad belt
www.grizzhopper.com for dissasembly and service instructions and pics
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
Pink Dipped Plastics
(in reply to jstanely)
RE: need help 06 660 grizz - 8/16/2008 8:40:46 AM
micheal
Go to grizzhoppers site. I would start by just cleaning and regreasing the primary.
(in reply to sscard)
RE: need help 06 660 grizz - 8/17/2008 11:48:52 PM
jstanely
Thanks for your fast replys i did that and it was full of mud and grime put it back togethr and ddnt help the top speed is only 40 and t has stck size tires  also messed up and te 22mil nut backed off and stripped the threads out of it i ordered another one.Any hlp on what could be causung thiswould help.thanks
(in reply to micheal)
RE: need help 06 660 grizz - 8/21/2008 8:18:41 PM
bboyette84
Whats done to it?
08 Grizz 660
custom snorkels
HL radiator kit
dyno jet kit
K&N filter
HL xtreme clutch kit
HMF pipe
28" SB
ITP ss108's
2.5 Warn winch
RE: need help 06 660 grizz - 8/22/2008 6:30:03 PM
BIG BEAR 08
did you clean the carb? sounds like some dirt and water in it.
2008 big bear: 2500lb warn winch, now riding on 27" ZILLA's on black 12" SS108's 2005 prarie 360: 26" mudlights, comet clutch, busted
front diff, finally got it moving again on april 17th
85 yamaha tri-moto 200: LONG GONE, but not forgotten
Quote from J_Fred
"I don't get stuck, I just lose traction and stop moving".
(in reply to bboyette84)
RE: need help 06 660 grizz - 8/27/2008 12:18:14 PM
jstanely
I have cleaned the carb and it does a little better but now it is 40 mph top speed.
(in reply to BIG BEAR 08)
RE: need help 06 660 grizz - 8/27/2008 11:30:44 PM
ectrip78
    mine did that win i first got it thin i cleaned the clutch and was bad mud in there but i did not do it good so i had done and it would fly that thing has to be rite or it will not work rite at all hope i helped see ya and good luck
03 hauck 800 big bore grizzly/29.5 laws on chrome ss 112s/hauck stage 3 cam/jet kit/pro com cdi/ported and polished head/titanium valves and springs/hauck match ported exhaust/full skid and a arm plates/winch/full snorkel kit//2inc lift /hl x clutch kit/rad relocated/turner axls the works but not done
