mudhole didnt answer...can yall?
All Forums >> [OEM Discussions] >> Honda >> mudhole didnt answer...can yall? Page: [1]
mudhole didnt answer...can yall? - 11/24/2008 10:50:43 PM
HONDA 4x4
okay im bringing my baby (see below) to finally get snorkeled. now before i get the "do it yourself"...im not. i dont care if its easy blah blah blah. he's my local mechanic, and i want intake, lines, exhaust (just welded extended pipe), snorkeled. how much would be a reasonble amount to pay. if any more info is needed, shoot. thanks in advance.
also i saw these "lockers" for sale on here for like 30 something bucks for the 300, will these do the same as the gearless lockers for hundreds more?
Honda Fourtrax 300
2'' HL Lift Kit
25'' Swamplites
Red/
White Strobes
Intake Snorkel
Exhaust Snorkel
Stereo Box
Backup/Spotlight
ORIGINAL: C1iffBurton
BRUTE750ii could quite possibly be the most hated man on highlifter
RE: mudhole didnt answer...can yall? - 11/24/2008 11:02:26 PM
RidinRed420
I would say 50hr plus materials, just a guess how much does he charge for an hour of labor normally? dont know anything about the locker
Honda 420 Rancher 4x4 ES
26inch Swampwitches
Uni and pc3
(in reply to HONDA 4x4)
RE: mudhole didnt answer...can yall? - 11/24/2008 11:03:58 PM
oldtrx
highlifter spool locker makes it hard to steer no matter what and wears parts out faster, dgr makes it easier to steer when combined with 4-2-4 it feels like factory 2x4. but put it in 4x4 and it will pull.
i have $35 in my intake and vent lines and another $30 in my exhaust, it is REALLLLLYYYYYY simple to do on the 300. just pull your tank off with the one bolt, undo your factory intake and slide it out, slide in a piece of 1.25 and and adapter to 1.5 over that and then either go straight forewrd and up and cut a hole and secure with threaded pipe fittings or get a 22.58 and go to the fender, get another 22.5* and go up to a 45* and over to the front rack and 90* to a threaded fitting and up as tall as you want
as for exhaust, go to autozone and buy a larger 90* of the size you want and a straight piece of the size you want, i got mine with a 35* angle on it
vent lines- follow the lines and either replace or extend them to desired length
-abunch of stuff i dont need
-http://www.youtube.com/user/oldtrx2
-www.gaorc.com
-www.myspace.com/haro_bikes_91
ORIGINAL: ydopen
ORIGINAL: white
with a passenger my tires rub my fenders will highlifter springs fix the problem or does my wife need to lose weight
RE: mudhole didnt answer...can yall? - 11/25/2008 2:26:56 PM
hondarider94
lol oldtrx that looks ridiculus.. or how ever you spell it.. but if it works why not
(in reply to oldtrx)
RE: mudhole didnt answer...can yall? - 11/25/2008 2:56:06 PM
gordo
This is the easiest and cheapest snork you can come up with,,,, and no re-jetting of the carb,,,, bout $20 worth of material from Home Depot and a couple hours of time ,,,, and I've never had to do the exhaust,,, found out if you left the oem exhaust on the bike it did fine in the water,,,,,
Thumbnail Image
Attachment (1)
2000 Honda Fourtrax
Warn 424/Warn 2500 Winch
HL Front Disk Brake Kit/Snorkeled
1997 Honda Fourtrax
Warn 424/Viper 2500 Max Winch
1996 Honda Fourtrax
HL Disk Brakes/Warn 424
G o r i l l a XT3000 Winch/Snorkeled
1994 Honda Fourtrax Blue!
Got a winch,,, Nothing Else,,, Yet
1990 Honda Fourtrax
Warn 424/Viper Max 2500 Winch
HL Disk Brakes
(in reply to hondarider94)
RE: mudhole didnt answer...can yall? - 11/25/2008 6:23:21 PM
oldtrx
i know it looks rediculos. but i rode alot of water over the summer.
im currently working on making my own version of gordo's snork
-www.gaorc.com
ORIGINAL: ydopen
ORIGINAL: white
(in reply to gordo)
RE: mudhole didnt answer...can yall? - 11/25/2008 6:40:51 PM
HONDA 4x4
im doing the exhaust just in case id have to turn it off with it over the pipe.....better safe than sorry
Honda Fourtrax 300
2'' HL Lift Kit
25'' Swamplites
Red/
White Strobes
Intake Snorkel
Exhaust Snorkel
Stereo Box
Backup/Spotlight
RE: mudhole didnt answer...can yall? - 11/26/2008 8:24:45 AM
rancher12
300 minimum
2008 Can Am Outlander 800 XT
Ricochet Skid Plates
In the words of Gunther from the Longest Yard,"She's fast, she's real fast!!!"
RE: mudhole didnt answer...can yall? - 11/26/2008 8:49:07 AM
bruterecoveryman
I agree it is cheaper to do it yourself, but you should be looking at around 2-300 dollars to fabricate and install a snorkle. then if you want the carb tuned, the going rate around here is about 250 for a tune. either way you do it I would reccomend the carb tune since you are planning on altering the air flow so much with the intake/exhaust snorkle.
(in reply to rancher12)
RE: mudhole didnt answer...can yall? - 11/26/2008 11:28:14 AM
HondaGuy
If you do it yourself you will save a ton of money but instead of having someone fabricate one why don't you look into buying a bolt on kit and installing it yourself, that way you don't have to deal with rounding up the parts but you won't have to pay labor leaving you with some money for other things. Extreme Snorkles makes one for the 300, and I'm sure there is someone else Bayou or Triangle maybe.
Supertrapp Mudslinger
HL EPI Clutch Kit
Relocated Radiator Permacool 8" electric fan
12x7 ITP C Series Type 5s
27in Bi/Tri Claws
Extreme Snorkle
some other stuff
88 Yamaha Banshee (kinda sorta for sale or trade)
Looking for a 4-stroke 400cc or bigger, anybody got any offers pm them to me anything is considered 2wd 4wd etc etc.
RE: mudhole didnt answer...can yall? - 11/26/2008 11:49:26 AM
[Got $pL?]
ORIGINAL: HONDA 4x4
True but with just a airbox snorkel you'll be alot better off - exhaust snorkels are NOT needed
RE: mudhole didnt answer...can yall? - 11/26/2008 11:57:23 AM
gmcz71
I would help you to build a intake snorkel for free as long as you buy the materials.  I just like doing it.  do you want to cut plastic?
1998 Suzuki Quadrunner 500 4x4 -
Possibly for sale/trade? Send me a PM.
2000 GMC Sierra Z71
- 285/70-17 Kumho AT's on HELO HE835 rims
- Blackbear tune (75% TM removed)
- Cherrybomb Extreme muffler
- Vette servo's
- torsion crank
- Clear corners
- ABS fuse removed
- Clear third brakelight
My Pics...
(in reply to [Got $pL?])
