RE: Make a list of common numbers we need
All Forums >> [OEM Discussions] >> Polaris >> RE: Make a list of common numbers we need Page: <<   < prev  2 3 [4] 5 6   next >   >>
RE: Make a list of common numbers we need - 5/2/2007 5:22:54 PM
MRMARIO2U
http://www.highlifter.com/forum/john_deere_front_diff_parts_work/m_1942879/tm.htm
STICK TO YOUR GUNS....
HONESTY ALLWAYS PROVELS
http://bricks4x4farm.com/ A PLACE TO DEFFINATLY CHECK OUT
http://s194.photobucket.com/albums/z120/MRMARIO2U/
http://youtube.com/profile?user=MRMARIO2U
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=210811036 < local place to play
SOMEBODY HOLD MY BEER EZ IS COMEING TO HELP :)
TEAM WWMD?!!!!!
(in reply to PolarisTodd)
Post #: 91
RE: Make a list of common numbers we need - 5/3/2007 9:22:50 AM
Mexican Mudder
Anyone know of a belt for a 600??
Berni
http://s153.photobucket.com/albums/s206/MexicanMudder/
Polaris 600 2003
K&N Air Filter
DynoJet
Heelclicker Clutch Kit
Big Gun Exhaust
29.5x12x12 Laws
Motorsport Tork Wheels
1.5" spacers up front.
Custom 12" StateLine
SOLD BUT NOT FORGOTTEN
(in reply to MRMARIO2U)
Post #: 92
RE: Make a list of common numbers we need - 5/3/2007 3:13:18 PM
PolarisTodd
use the polaris belt
Polaris 500H.O.
Heel Clicker
Supertrapp IDSX Full System
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Highlifter Lift Springs
Swamp Witch 28's
Vision Wheels with 1.5" spacers all around.
Lot's of MONEY on Polaris required maintenance
(in reply to Mexican Mudder)
Post #: 93
RE: Make a list of common numbers we need - 5/3/2007 3:37:59 PM
Mexican Mudder
ORIGINAL: PolarisTodd
Yeah I just won't have much money right now to get one. I was looking for a cheap replacment for now..
Berni
Polaris 600 2003
K&N Air Filter
DynoJet
Big Gun Exhaust
29.5x12x12 Laws
Post #: 94
RE: Make a list of common numbers we need - 5/14/2007 1:54:52 PM
gotmuddy
The cheap replacements aren't but about $10 cheaper.  I have found that OEM belts are the best to buy.
www.****
Tires for sale
ORIGINAL: baf004
That'll buff right out.
Post #: 95
RE: Make a list of common numbers we need - 5/30/2007 9:36:57 AM
alwaysbroke
Two things I've recently replaced in my 2005 500H.O.
Spal fan #30100597. You will have to use your shroud and blade. The plug and motor are exactly the same as what comes with the bike. $74.96 plus shipping. Only took 10 minutes to swap the blade and shroud over to the new motor. No cutting or splicing any wires.
Spal Phone # 1-800-345-0327
Spal Website: http://www.spalusa.com/
The people at Spal are great. Easy to talk to and soooooooooooo helpful.
Rear Wheel Bearings:
Federal-Mogul Bearings 510013
Thanks to polaristodd for the help and info.
'05 Sportsman 500 H.O., 27" mud bugs, mobile jukebox, backrest, and a cooler!
My Wheeler
Ride Pics
My Vids
(in reply to gotmuddy)
Post #: 96
RE: Make a list of common numbers we need - 6/8/2007 2:44:23 PM
mud baron
anyone come up with a thermo-stat for a 05 400........mine keeps getting hung up (i think its warped)....$57from polaris...thats a ripoff....
(in reply to alwaysbroke)
Post #: 97
RE: Make a list of common numbers we need - 6/19/2007 9:39:08 AM
yellow06700
in case you need anything to do with boots or CV joints or anything of that nature American CV has all of it the # is 1-866-288-3003
2006 Polaris 700 Twin (Yellow)
2" Highlifter Lift Kit
AAEN Mega Power Exhaust
K&N Air Filter
27" Mud Bugs on ITP 7 Series Chrome
(in reply to mud baron)
Post #: 98
RE: Make a list of common numbers we need - 6/25/2007 9:44:43 AM
DaGrizz
ANYONE have a number for a fuel filter for 05-700 Polaris EFI.  Local dealer wants $40
If your goon be a bear, be a GRIZZLY!
(in reply to yellow06700)
Post #: 99
RE: Make a list of common numbers we need - 7/26/2007 10:11:27 AM
DOZER77
try these
Front diff bearings and seal kit
rear bearing and seal kits
ball joint kits
tie rod end kits
http://www.goallballs.com/Product_lookup_results_shop.asp?zipcode=77389
bought the front diff kit looks good have not used it yet
2005 Sportsman 800
a couple of bumpers
a pull you out thang
Bling Bling wheels
and mud slinging tires
(in reply to DaGrizz)
Post #: 100
RE: Make a list of common numbers we need - 8/13/2007 5:02:04 PM
bamakc
http://www.ridgerunner.biz/parts.htm  Try this site for OEM parts.
(in reply to SemperVigilo)
Post #: 101
RE: Make a list of common numbers we need - 8/13/2007 8:00:06 PM
guyroy
what about oils? should i keep buying the expensive polaris oils for difs, tranny and engine or is regular oil OK?
(in reply to bamakc)
Post #: 102
RE: Make a list of common numbers we need - 8/13/2007 8:13:35 PM
PolarisTodd
For front diff...YES. On all other as long as it meets minimum requirements you are OK.
Polaris 500H.O.
Heel Clicker
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Swamp Witch 28's
(in reply to guyroy)
Post #: 103
RE: Make a list of common numbers we need - 8/15/2007 12:50:11 PM
KSCFIRE
It was time for me to replace my front and rear diff seals for my axles. I bit the bullet and purchased Polaris ones. I then took them down to my local seal and bearing shop, Miller Bearing. The guy at the counter measured them and found matches for the front and rear axle seals and the front shaft seal. I didn't have a rear shaft seal with me. The seals are Chicago Rawhide and the part #'s are: Rear axle- 19630 @ $7.14, Front axle- 692461 @ $4.53 and Front shaft- 692321 @ $ 4.04. I forgot to ask if they were single, double or triple lip seal. As for the flat lipped o-rings for the front that were in the seal kit from polaris, I was refered to a local hydralic shop. I was told there they could probably match up those, but would have better luck if I were to bring in the case so they could get a more accurate measurement off the groove in the case. I haven't got a chance to place these next to the Polaris seals yet to compare, but I hope to soon. If they are the same, what a savings. I should also mention this is for my 04' SP700.
< Message edited by KSCFIRE -- 8/15/2007 12:56:56 PM >
2004 Polaris Sportsman 700
3.0 Warn
26" MudLites
My other ATV is a tank.
Post #: 104
RE: Make a list of common numbers we need - 8/17/2007 6:12:25 PM
KSCFIRE
I got the seals today, matched them up at the counter with the parts guy. They're a match. Only one difference is they are single lip not triple. I ask him straight up "Will this make a difference"? He stated that the specs from Chicago Rawhide say the single one is equal. I asked him why the Polaris ones are triple, and he said he believes it's just an extra dust seal. If I get time next week I'm going to tear into my diffs and replace the seals. I'm going to go with the Chicago ones first to give them a try. If them don't work out I'll still have the Polaris ones in reserve. Cross you fingers we might have another $$$ saver.
3.0 Warn
26" MudLites
(in reply to KSCFIRE)
Post #: 105
RE: Re: Make a list of common numbers we need - 8/18/2007 10:16:11 PM
Dirtbmw20
ORIGINAL: chvylac
anybody have a part number for ball joint for the front struts??
Anybody ever get any info on this ???? I too would love some aftermarket part numbers on some ball joints.
05' Sportsman 500 H.O.
Rubber Down 3" Lift
Lots of "goodies" I couldn't afford
Dirtbmw20's Pics
(in reply to chvylac)
Post #: 106
RE: Make a list of common numbers we need - 8/20/2007 8:03:27 PM
ouch1175
Not likely to find one but what about the coil/plug wire assembly for an 06 500 EFI? Gonna go check the parts store tomorrow.. There has to be a replacement for something (I hope) OEM is 150 bucks?
Post #: 107
RE: Make a list of common numbers we need - 8/21/2007 9:16:26 PM
green700efi
oil filter for the 06 700 popo wix 51356 but if you get in a bind its the  same filter that the 02-06 grizz uses its just a little longer the number on the grizz is 51358 but they are interchangeable
06 700 efi sportsman
heelclicker
scuba gear
custom 5/8 4140 tie rods
800 exhaust
07 800 sportsman
jams
snorkeled through the box
highlifter springs and spring spacers
3000# viper max
29.5x12's on visions
fmf exhaust
hid lights
blinky blinky lights
powered by jack daniels
(in reply to ouch1175)
Post #: 108
RE: Make a list of common numbers we need - 8/21/2007 9:23:29 PM
BigAl
The output seals measure 40X52X8, A 7 WILL WORK TOO.  The input seal measures 25X47X8,  A 7 WILL WORK TOO.  The output bearings are 6008-2RS, ORS brand and the input bearing is 6306-2RS, ORS brand.  2005 and up front diff's
2005 500 POPO
Relocated Radiator
28 Laws, spacers
06 EFI Drive Clutch
(in reply to green700efi)
Post #: 109
RE: Re: Make a list of common numbers we need - 8/22/2007 5:51:29 AM
PolarisTodd
ORIGINAL: Dirtbmw20
ORIGINAL: chvylac
Anybody on Tie Rod ends??
Polaris 500H.O.
Heel Clicker
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Swamp Witch 28's
(in reply to Dirtbmw20)
Post #: 110
RE: Re: Make a list of common numbers we need - 8/30/2007 11:34:29 AM
old ranger
Any numbers for water pump seals for a 500?
Post #: 111
RE: Re: Make a list of common numbers we need - 8/30/2007 10:01:33 PM
DOZER77
Ball joints  42-1030  1 ball joint 1 cotter pin       $19.95
Tie rod ends  51-1021  2 ends for one tie rod        $34.90
Front diff kit 25-2059  3 bearings and 3 seals         $51.75        have tried this one and it works
2005 Sportsman 800
a couple of bumpers
Bling Bling wheels
(in reply to old ranger)
Post #: 112
RE: Re: Make a list of common numbers we need - 9/3/2007 7:04:02 PM
Newfie Polaris
Has any one found a part replacment for the front bearings yet???
(in reply to DOZER77)
Post #: 113
RE: Re: Make a list of common numbers we need - 9/3/2007 7:13:24 PM
PolarisTodd
ORIGINAL: Newfie Polaris
Search this post. there is plenty of info.
Polaris 500H.O.
Heel Clicker
DynoJet Kit
K&N
Warn 2.5ci
Synthetic Rope
Swamp Witch 28's
(in reply to Newfie Polaris)
Post #: 114
RE: Re: Make a list of common numbers we need - 9/14/2007 6:57:12 PM
223s
Has anyone find a source for the Tranmission Switch. Mine is showing a E show I guess it a Error. I can pull the plug out and put it back in and it works for a while but starts messing up when I start shifting again.
Post #: 115
RE: Re: Make a list of common numbers we need - 9/29/2007 7:16:03 AM
ouch1175
Need a starter replacement and avoid that 300$ OEM? I got a starter for my 06 500 EFI with a one year warranty for like 80 bucks shipping and all and it is a 100% match to the OEM one. Apparently this model starter has been used on hundreds of applications. Anyways if you need a starter search for DB Electrical on google and you should find the place no problems or you can call 800-753-2242.. You can also get rebuild kits and all that but just buying the starter was like 15 bucks more.
(in reply to 223s)
Post #: 116
RE: Make a list of common numbers we need - 10/1/2007 12:50:35 PM
polarisgirl400
What are the tie rod ends that I would get for an 2000 -500?
Post #: 117
RE: Make a list of common numbers we need - 10/6/2007 8:52:00 AM
Rebel64
Ring, spring  (for front half shaft assembly)
# 7710581
Anybody know of an exact match to this?  Neither popo dealer around me has this in stock, and that's all I need to get my bike running.
07 800 Stealth
(in reply to polarisgirl400)
Post #: 118
RE: Make a list of common numbers we need - 10/8/2007 9:59:31 AM
mud_duck
Sportsman 700 2004.5 fan from Spal, $127.95
You will use only the motor and have to use your original waterproof plug.
'04.5 Polaris
TEAM CRUSHLOK
CLICKMy Pics
______________________________________________
I may be old, but I'm not boring
(in reply to Rebel64)
Post #: 119
EFI fuel filter - 10/10/2007 5:23:11 PM
DaButcher
 EFI fuel filter
NAPA #3199 will work, but is some smaller.
Mud Mafia
"We're in tha trash talkin business..........and business is good"
DaButcher Myspace
Mud Mafia Myspace
Pics
06 800 Sportsman
G O R I L L A lift
29.5 Outlaws
Post #: 120
© 1996-2008 High Lifter Products, Inc. - ATV After-Market Parts and A
