RE: TUNE YOUR BIKE!!
All Forums >> [OEM Discussions] >> Can-Am BRP >> RE: TUNE YOUR BIKE!! Page: <<   < prev  1 [2] 3   next >   >>
RE: TUNE YOUR BIKE!! - 10/6/2008 8:50:23 PM
bruterecoveryman
ORIGINAL: matprice
it helps to put the heads together to find the best spots to adjust.
This is probably the best addition to the tuning tool box. As Mat said here it really helps to have someone with equal/better knowledge, in the field, to bounce Ideas off of . I found the tunes went twice as fast when there was another person around to verify changes I had made
(in reply to matprice)
Post #: 31
RE: TUNE YOUR BIKE!! - 10/6/2008 8:54:00 PM
mrrpm
ORIGINAL: engie
ORIGINAL: mrrpm
Using an accelerometer won't really work well for dialing in A/F ratios, as there are too many variables, tire slip, belt slip, rider position, to name a few. The best way is with an engine dyno, so none of that stuff has a chance to mess with the tuneup.
The a/f ratios are already dialed in spot perfect everywhere but on the very bottom on this bike.  After toying with the setup, I can continuously accelerate with less than 5% deviation in the summation of the curves on each given run, so I think small modifications to the fuel maps will show on an accelerometer given these early tests.  It's true that these "variables" exist within single runs, but like anything else accuracy and precision is increased as more data is established and more runs are taken while maintaining the greatest level of consistency possible...
I don't have access to an engine dyno, so I have to find alternate methods to determine these things...
The very bottom is where your problem will be, because of spinning, or wheelies or whatever. You'll get close, but not quite rite. It doesn't matter anyway, just tune for good response, like no stuttering, crisp response, etc, and you'll be there. (I'm assuming a v-twin can am)
Forget the engine dyno, and just go to a chassis dyno. It's so easy, you can dial her in in a pull or two. Is this a CVT bike like the 800 can am, or another unit?
'07 Renegade 800 Turbo
'07 Renegade 800 Stock, Oldest boys machine
(in reply to engie)
Post #: 32
RE: TUNE YOUR BIKE!! - 10/6/2008 8:58:35 PM
bruterecoveryman
[/quote]
The standard minimum used for this type of analysis is 12 runs in each possible scenario.  After the 12 runs, it goes to the evaluation phase to determine if the process is within an acceptable deviation to continue.  Generally, I will run 12 and "throw out" any that fall more than 5% from my "average."  If any more than 2 of these twelve runs must be thrown out, then the process is considered unacceptable and must be repeated.  If it is repeatedly unacceptable, then the process is thrown out.
At least, that's the method I've been using with pretty decent success...
[/quote]
If  I understand you correctly.... your neighbors are alot more tolerant than mine . If I did 12 runs for each TP I would have the law out here in a minute
< Message edited by bruterecoveryman -- 10/6/2008 8:59:53 PM >
(in reply to engie)
Post #: 33
RE: TUNE YOUR BIKE!! - 10/6/2008 9:20:33 PM
007BF
 LOL!!  DON'T MAKE ME COME OVER THERE JJ!!
Casey, you're giving me a headache again!  No more statistics!!  I guess that class would have been ok if they could have spoken English!  Nothin like a foreign grad student!  Great guys, bad english!
We did a quick tune on my bike thus we did not spend alot of time at each throttle position to dial in a/f at all rpm's per tp.  There is a night and day difference between the way the bike runs now and how it ran before.  No more hesitation off the line, no mid range stumble, and the fan doesn't stay on all the time!  I am very pleased.
I-45 RACING
powered by Pit Proven Performance
Russell Coker #55
Texas A&M class of 07'
WHOOOOOP!!
C.M.R POINTS SEASON FINAL
1st OPEN/PRO SWAMPCROSS
1st CLASS 1 MUD BOG
3rd CLASS 2 SWAMPCROSS
3rd CLASS 2 MUD BOG
(in reply to mudder500)
Post #: 34
RE: TUNE YOUR BIKE!! - 10/6/2008 9:23:00 PM
mudder500
Sounds like u was a lil to lean there buddy
06 Dodge CTD 2500
smarty
66 over s480
studs
ats arc flow
air dog
(in reply to 007BF)
Post #: 35
RE: TUNE YOUR BIKE!! - 10/6/2008 9:23:01 PM
muddyfuzzy
i know right!!!!!!!!! sounds like you got a pretty solid program engie. it's nice to take that data push it thru a software like minitab and let it set-up your histogram(bell curve) against the pre determined standard deviation matrix. thanks for the dialog on the topic guys.
MINE-08'outty800max-xt/lawed with28"skinnys/ snorked/w2"intake/radiator relocated/skidded out
"Power down in the hole"
WIFE'S-07'trx420fm/uni/lawed with 28" skinnys/custom snorked/supertrapp mudslinger/high lifter outlaw clutch kit/dynojet pcIII power commander(tuned by "THE JOHN CANNON")
Post #: 36
RE: TUNE YOUR BIKE!! - 10/6/2008 9:33:51 PM
007BF
f'n a!  NO MINITAB!! LOL!
As Greg said, if you can get a smooth A/F ratio across the board then you are good to go.  Let'r eat!!
I-45 RACING
Russell Coker #55
WHOOOOOP!!
1st CLASS 1 MUD BOG
3rd CLASS 2 MUD BOG
(in reply to muddyfuzzy)
Post #: 37
RE: TUNE YOUR BIKE!! - 10/6/2008 9:40:17 PM
matprice
russel did you save your runs? if so mail them over and we can take a look at them for ya and give ya some feedback man. And yeah we did an 800 this weekend and the dude got on it and could not stop smiling after a couple min. Its like a whole diff ride. Forget the power gains when you have a well tuned bike so much more smooth and has such great throttle response. I love doing them it is a good feeling to have one come in running like poo and have it leave and the guy ride a 300 foot wheelie after it rolls out
Mat Price
BitMore Performance Race Team
mine BITMORE TUNED
2007 Can Am 800 Outlander
2007 outlander 800 xt
Post #: 38
RE: TUNE YOUR BIKE!! - 10/6/2008 9:43:12 PM
bruterecoveryman
ORIGINAL: 007BF
Do I need to bring my WBC to Mudstock??????? LOL We'll be doing runs till the races start !!!!
(in reply to 007BF)
Post #: 39
RE: TUNE YOUR BIKE!! - 10/6/2008 9:49:33 PM
007BF
Thanks Mat, I appreciate the offer but we were in a hurry and didn't save any of the runs.  I'll remember to save them next time for research.  I feel like a little kid in the candy store again!  its like a new bike! LOL!
I-45 RACING
Russell Coker #55
WHOOOOOP!!
1st CLASS 1 MUD BOG
3rd CLASS 2 MUD BOG
Post #: 40
RE: TUNE YOUR BIKE!! - 10/6/2008 9:52:04 PM
Nutmeg
ORIGINAL: bruterecoveryman
ORIGINAL: 007BF
Casey is ban from riding in the cow fields while tuning.
Coker, glad to hear you got your bike running good again.
Barry Ladner
MSMudNutZ FUELED By COMPETITION SPORTS
Rollin On CRuSHLoK's
Ladner & LaFountaine Race Edition
YouTube
http://www.youtube.com/MSMudNutZ
WebSite http://www.MSMudNutZ.com
MySpace http://www.myspace.com/MSMudNutZ
Personal MySpace http://www.myspace.com/BarrysPlayHouse
Post #: 41
RE: TUNE YOUR BIKE!! - 10/6/2008 9:57:35 PM
bruterecoveryman
ORIGINAL: 007BF
wanna feel like a "BIG" kid in the candy store??????? let us get our hands on it for a lil while. No peeking though..... just pick it up when We're done and hold on....
(in reply to 007BF)
Post #: 42
RE: TUNE YOUR BIKE!! - 10/6/2008 9:57:46 PM
engie
ORIGINAL: 007BF
At the current pace, I'll be there with the LM1/LMA3.  So when you see me doing WOT runs through the campground pulling a large log, don't think of me as an idiot!  GOTTA tune for that underwater start on the Muddacross track!!!  Failure to do so cost me a race last time I was at Mud Creek...not this time!!!
Building a motor or two with a few other little projects...
Victory is not achieved on raceday. It is achieved in the preparation leading up to it.
Post #: 43
RE: TUNE YOUR BIKE!! - 10/6/2008 10:03:17 PM
bruterecoveryman
ORIGINAL: Nutmeg
DERN BARRY
Thats supposed to be my lil secret!!!
I got somthing for Stevie's clutches once I get my handle bars back on
(in reply to Nutmeg)
Post #: 44
RE: TUNE YOUR BIKE!! - 10/6/2008 10:05:15 PM
007BF
ORIGINAL: 007BF
Looks like i'm gonna have to get someone a few drinks this weekend so they'll start talk'n!!
Barry, you going to make Mudstock???  You've gotta get the gade ready to hit the trails after the races!!  Its gonna be an all nighter!!!
I-45 RACING
Russell Coker #55
WHOOOOOP!!
1st CLASS 1 MUD BOG
3rd CLASS 2 MUD BOG
Post #: 45
RE: TUNE YOUR BIKE!! - 10/6/2008 10:06:49 PM
Nutmeg
DERN BARRY
Yeah, I was wondering why you left so quick. . By the way, I couldn't stand it. I went ahead and order one tonight.
< Message edited by Nutmeg -- 10/6/2008 10:11:01 PM >
Barry Ladner
YouTube
Post #: 46
RE: TUNE YOUR BIKE!! - 10/6/2008 10:07:54 PM
bruterecoveryman
one day..... I'll figure out how to post on this #$!$& forum.
Engie, look us up friday when ya'll are tunning. I wouldnt mind you dropping some of those "pearls of wisdom" my way..... Actually, I just wanna learn some different software....
Post #: 47
RE: TUNE YOUR BIKE!! - 10/6/2008 10:17:15 PM
snowhite
ORIGINAL: 007BF
Russell, I think we need to finish your bike, then let them hold on....   4000 rpms!!!!!!!!!!!!!!!!!!!!
www.I45Racing.com
Pit Proven Performance Custom Dynojet Tuning and Clutching
Post #: 48
RE: TUNE YOUR BIKE!! - 10/6/2008 10:18:28 PM
matprice
DERN BARRY
thats them special bitmore edition handle bars good for at least 5.279 RWHP
Mat Price
mine BITMORE TUNED
Post #: 49
RE: TUNE YOUR BIKE!! - 10/6/2008 10:35:05 PM
bruterecoveryman
ORIGINAL: matprice
DERN BARRY
Actually its them "Ladner Edition" handle bars  and its AT LEAST 6.279 RWHP.... GET IT RIGHT!!!!!.
Glad to hear about the Purchase Barry... Take The "Ladner Edition" to the next level.
All I can Say is....... "It's All About To Change"
< Message edited by bruterecoveryman -- 10/6/2008 10:36:48 PM >
Post #: 50
RE: TUNE YOUR BIKE!! - 10/7/2008 11:11:30 AM
JohnCannon
Are you welding in O2 ports on every tune or replacing the muffler just for the tune??
MaD MOTORSPORTS
.: www.MUDandDIRT.com :.
YouTube:. http://www.youtube.com/mudanddirt
MaD MOTORSPORTS CUSTOM EFI TUNING
07 Competition Sports/MaD Outlander X
PROUND SPONSOR OF
Team Gander Mtn
Bama Boggers
Matt Thompson
Brutewise
I support the troops 100%. You guys are my heros..
Post #: 51
RE: TUNE YOUR BIKE!! - 10/7/2008 11:38:50 AM
007BF
John, we just did a quick 1 map tune using a bung in the exhaust that can be swapped from bike to bike for quick tuning.  After mudstock, we'll be tuning individual cylinders if need be.
< Message edited by 007BF -- 10/7/2008 11:39:56 AM >
I-45 RACING
Russell Coker #55
WHOOOOOP!!
1st CLASS 1 MUD BOG
3rd CLASS 2 MUD BOG
(in reply to JohnCannon)
Post #: 52
RE: TUNE YOUR BIKE!! - 10/7/2008 11:39:38 AM
Nutmeg
ORIGINAL: 007BF
Yep, I will be there. I wont be riding the gade after the races though. I got something better for the trails. I'm taking the 400 out on the trails.
Barry Ladner
YouTube
(in reply to 007BF)
Post #: 53
RE: TUNE YOUR BIKE!! - 10/7/2008 11:40:49 AM
007BF
ORIGINAL: Nutmeg
ORIGINAL: 007BF
LOL!  You know you can't handle that 400!!!
I-45 RACING
Russell Coker #55
WHOOOOOP!!
1st CLASS 1 MUD BOG
3rd CLASS 2 MUD BOG
Post #: 54
RE: TUNE YOUR BIKE!! - 10/7/2008 11:46:58 AM
BruteWise
man man man russell it has taken you THIS long to realize that after you add ANYTHING you need to TUNE IT???  man your so smart with clutching.............i didn't realize you were that much dumb on the tuning side of the spectrum.  LOLOL
IF YOU CHANGE IT.................TUNE IT!
TEAM GORILLLA POWERED BY CAN AM
Flynt's Custom Performance
Custom ATV or Shreveport
MaD MOTORSPORTS
**WISE #11**
SOUTHERN SWAMP BOYZ
"I AM NOT A NICE GUY.......I AM A WISE GUY!!"
(in reply to 007BF)
Post #: 55
RE: TUNE YOUR BIKE!! - 10/7/2008 12:02:23 PM
007BF
ORIGINAL: BruteWise
LOL!! DON'T MAKE ME COME DOWN THERE MARK !!
I-45 RACING
Russell Coker #55
WHOOOOOP!!
1st CLASS 1 MUD BOG
3rd CLASS 2 MUD BOG
(in reply to BruteWise)
Post #: 56
RE: TUNE YOUR BIKE!! - 10/7/2008 12:11:02 PM
