RE: rhino question
RE: rhino question
All Forums >> [OEM Discussions] >> RUVs (Recreational Utility Vehicles) >> RE: rhino question Page: <<   < prev  1 [2]
RE: rhino question - 10/10/2008 9:58:12 PM
probus
so why cant we swich sides with the rear hubs? that would keep the calipers and the rear? that is what i am gonna try to do, might be a little more work but i think it will work out.
'09 700 camo rhino
top
fender flares
27 XTR's on SS112's
moose half windshield
rear bumper
4500 viper max winch
lots more to come!
http://www.flickr.com/photos/bud_light1978/
give ez his beer back,
MARIO will just have to wait!!
team WWMD!!!!!!!
(in reply to JB3231)
Post #: 31
RE: rhino question - 10/10/2008 10:40:14 PM
Pac
I would just like to know how a 3 inch lift can be more stable. I would love to have one but seems to me it would be more easy to roll it. Also anyone with the 3 inch lift having any problems  with cv joints or boots getting tore up?
09 Teryx LE FI
(in reply to probus)
Post #: 32
RE: rhino question - 10/10/2008 11:53:22 PM
Silveradols
ORIGINAL: probus
why exactly did you have to take the brake lines loose?
because you have to be able to rotate the brake line and you have to put the banjo bolt thru the other side of the hole at the end of the brake line where it bolts to the caliper.
http://s38.photobucket.com/albums/e135/Silveradols/
Post #: 33
RE: rhino question - 10/11/2008 12:00:29 AM
Silveradols
ORIGINAL: probus
I suppose you could, but it would be more involved.
Post #: 34
RE: rhino question - 10/11/2008 8:18:05 AM
probus
it may not work but when i go to flip mine i am gonna try it i think.
'09 700 camo rhino
top
fender flares
27 XTR's on SS112's
rear bumper
lots more to come!
team WWMD!!!!!!!
(in reply to Silveradols)
Post #: 35
RE: rhino question - 10/11/2008 12:08:18 PM
JB3231
According to the HL instructions for their lift they advice to swap sides on the hubs, left to right, right to left.  I'm not sure why though.  Give it a try and let us know how it works.
06 Dodge Ram 2500 4X4 5.9C
Post #: 36
RE: rhino question - 10/11/2008 3:54:08 PM
Silveradols
well, I'm gonna either have to flip my hubs back to the stock position or try switching sides, because for some reason I can't bleed all the air out of my brakes with the calipers on the front of the rotor.  I even bought a brake bleeder kit and it made no difference.
Post #: 37
RE: rhino question - 10/11/2008 5:25:30 PM
JB3231
Maybe that's why they swap sides.  I had a terrible time bleeding them and they never have felt as strong as original.
Silverdols----If you swap sides let me know how it works out.  I may swap mine also if the brakes bleed better.
Post #: 38
RE: rhino question - 10/11/2008 6:15:57 PM
Mrmojorisan
could it be because the calipers are upside down?  can you bleed them right side up just sitting on the rotor and then mount them upside down?  Don't have a lot of experience with brakes, but it seems like it might work
'08 Rhino 700 EFI
27" 589's
Aluminum Roof
Stereo
4000lb Viper Max Winch
Light Bar
Skinning / Gutting Lights
Bag Scabbard
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming... ****, What a ride!!
Post #: 39
RE: rhino question - 10/11/2008 6:24:09 PM
Silveradols
ORIGINAL: JB3231
I don't see any reason why it would work, but if it does I'll let you know.  It will be Monday or Tuesday before I can get it done though.  I need to buy a 32 mm socket.
Holy Cr@p Batman, the torque on the Rhino axle nut is 255 ft/lbs.
Post #: 40
RE: rhino question - 10/11/2008 6:43:09 PM
Silveradols
I'm gonna put mine back to stock.  This is gonna be much trouble and to expensive to do.  I would also have to buy a new torque wrench that reads over 255ft/lbs.
Post #: 41
RE: rhino question - 10/13/2008 11:51:28 AM
Silveradols
ORIGINAL: Mrmojorisan
That shouldn't make any difference, but you gave me an idea.  I just swapped sides with the calipers.  They're still on the front of the rotors, but they're right side up now.  I can see no discernible differences between the calipers, so it should work.  This is much easier to do than swap the spindles.  I'll let ya'll know after I can get the brakes bled sometime this afternoon.
(in reply to Mrmojorisan)
Post #: 42
RE: rhino question - 10/13/2008 1:49:59 PM
JB3231
We need an update.  How was the bleeding?
Post #: 43
RE: rhino question - 10/13/2008 1:54:09 PM
Silveradols
ORIGINAL: JB3231
It's going much better.  I haven't bleed them half as much as I did the other way and already the pedal is better.  I'm gonna bleed them one, maybe two more times and I think it will be there.
Post #: 44
RE: rhino question - 10/13/2008 3:18:07 PM
Silveradols
All done.  Swapping sides with the calipers did the trick.  I've bled my brakes and I have a very good pedal.  I'm uploading some pics now for a comparison between no hub flip and hub flip.
Post #: 45
RE: rhino question - 10/13/2008 3:26:56 PM
Silveradols
Before Rear Hub Flip with 29.5inch Swamplites and the Rear Shocks are in the Highest Setting:
After Rear Hub Flip with 28inch Swamplites and the Rear Shocks are in the Middle Setting:
< Message edited by Silveradols -- 10/13/2008 3:41:48 PM >
Post #: 46
RE: rhino question - 10/13/2008 5:28:07 PM
JB3231
Why did you change tire size?  It's kind of hard to tell with the different tires.  Did you take any measurements?
Post #: 47
RE: rhino question - 10/13/2008 7:20:58 PM
probus
yeah flipping the calipers will make them alot easier to bleed. it is hard to get the air out when the bleeder is on bottom. i ran into this when i helped my buddy bleed the brakes on a buggy he built to pull behind a team of mules. he used a car rear axle and had to flip it upside down to get the clearance that he needed.
'09 700 camo rhino
top
fender flares
27 XTR's on SS112's
rear bumper
lots more to come!
team WWMD!!!!!!!
Post #: 48
RE: rhino question - 10/13/2008 7:35:24 PM
JB3231
Starting to make sense why I had such a hard time bleeding mine.  I think I will take mine off and bleed them again and then put the calipers back on.  They never have felt as good as stock.  I always thought I still had a little air in there somewhere.
Post #: 49
RE: rhino question - 10/13/2008 8:09:40 PM
probus
i think i am gonna flip mine this week. will it look stupid with no lift in the front or is it not that noticeable?
'09 700 camo rhino
top
fender flares
27 XTR's on SS112's
rear bumper
lots more to come!
team WWMD!!!!!!!
Post #: 50
RE: rhino question - 10/13/2008 8:42:44 PM
Silveradols
ORIGINAL: JB3231
the 29.5inch Swamplites are actually for my Grizzly.  I'll install them and take some more pics.
Post #: 51
RE: rhino question - 10/13/2008 8:46:22 PM
Silveradols
ORIGINAL: probus
Swap sides with the calipers and then bleed them.  It should look ok with just the hubs flipped.  You may have to turn the shocks up in front.  No I didn't take any measurements.
Post #: 52
RE: rhino question - 10/13/2008 9:02:24 PM
Silveradols
I didn't take measurements, but it sits just as tall with smaller tires and the shocks turned down 2 notches.
Post #: 53
RE: rhino question - 10/13/2008 9:05:01 PM
probus
from the looks of the hubs it should raise it about an inch.
'09 700 camo rhino
top
fender flares
27 XTR's on SS112's
rear bumper
lots more to come!
team WWMD!!!!!!!
Post #: 54
RE: rhino question - 10/13/2008 9:14:00 PM
Silveradols
yea, it looks like about an inch.
Post #: 55
RE: rhino question - 10/15/2008 9:21:09 AM
Silveradols
switching sides with the calipers is definitely the way to go.
Post #: 56
RE: rhino question - 10/18/2008 6:38:18 AM
Silveradols
I think I'll put my 29.5 OutLaws on it and see what they look like.  I'll get pics with them and my 29.5inch Swamplites.
Post #: 57
RE: rhino question - 10/18/2008 6:06:47 PM
Silveradols
ORIGINAL: Silveradols
Pics of my Rhino on my Grizzlies 29.5's with the 3" Lift and rear hub flip.
< Message edited by Silveradols -- 10/18/2008 6:11:48 PM >
Post #: 58
