dgraham225
ORIGINAL: dgraham225 quote:
ORIGINAL: dgraham225 updated list: Frame w/ title, needs to be re-painted or powdercoated--300 frame w/ no title, broken rear diff mounts, would be good for a custom stretch, etc--175 complete engine, minus clutches. runs good, like 240 original hours. been sunk in clean water a couple of times but i have never had any problem with it smoking, etc.. im no dummy, i spent hours flushing it out with tranny fluid to avoid problems. i have inspected the inside of the casing through the rear output shaft and theres no visible signs of water damage, etc... the only problem with the motor is the holes where the CVT cover bolts up, needs to be re-tapped or studded like i did.--SOLD Front differential, great shape! clutch plates look good, no problems--sold rear differential, no problems also--150 front axles, front right sold, left still available gauge cluster, bout 240h, 550-600 miles.. i cant remember for sure, its been down a while--SOLD 4x4 actuator--SOLD KEBC actuator--SOLD radiator/fan--radiator sold, fan still available for $60 shipped! stock CDI--SOLD headlights w/ plastic shroud--40 each front arms--50/side rear arms--50/side front knuckles--50each shocks--100/whole set voltage regulator--30 prop shaft--40ea gas tank--75 primary CVT--SOLD secondary CVT--SOLD CVT cover--SOLD air box--SOLD
< Message edited by dgraham225 -- 10/2/2008 9:13:50 PM >
Danny Graham 08 RZR, snorkeled, 32" silverbacks, ITP ss212's, 1" spacers, 2" prolift, HL springs 02 Prairie 650, let the mods begin!
