Sweet_Tooth
ORIGINAL: mrrpm quote:
ORIGINAL: ****715 quote:
ORIGINAL: Kratos Less boost, less rpms, 42 more horses. Good work. I think you're confused. He made 162CHP and 120WHP with the old set up that was 150CHP. So it's only 12HP more with less boost and less rpms...still pretty good though. It actually made 200hp, on the pull before it blew up, today. It had 170hp at 7000, then we turned it 8000, and it made 200hp, so we went for 8500, was going thru the pull, and around 8200 or so, it let go. So now, I'm 50 hp up from where I was, with less boost, and less rpm. 9000rpms will put it at prolly 230, add boost, and it'll prolly make 250-275hp. Soon as I get the jugs honed, and some alum rods, I'm gonna try the big bore with this setup. Maybe it'll make 300hp! That'll be five times what it had from the factory, I'm at 3.3 now. You should hold back on the RPMs. That monster jug at 9000RPMs sounds kinda scary specialy for all the work you have put up on it.
Real name: Lucas Fact: God hates fanboys!! 2007 Suzuki Vinson Manual UNI Filter Warn Bumper Round Foglamps Rear work light Viper MAX 3000lb winch Maxxis 4x4 wheels with 27" Dirt Devil II tires 10's front 12's rear 2003 Honda Rancher 4x4 ES "Gone but not forgotten"
